Results 1 to 15 of 15
    Established Member Two Rings slow&low's Avatar
    Mar 15 2008
    Spokane, WA
    variable geometry turbo
    So I was just watching Trucks! on Spike and the 2011 Ford super duty comes with a variable geometry turbo. I don't know much about diesels, but I wonder how the size on a 6.7l compares with a big turbo for our cars. I assume it would be bigger as compared to a GT35 series, but being a variable vane type, maybe it wouldn't be so bad. Just spit ballin here but it got my curiosity raised. Anybody else thought the same thing?
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    One guy has done a holset variable geometry build. I've seen some vids of it accelerating and it's quick. However (and correct me if I'm wrong) it seems as though he never quite got it running the way he wanted. Long story short, it's been done, but it requires a lot of fabrication and know-how.
    Senior Member Three Rings Outerfroggy1's Avatar
    Nov 18 2009
    Newfoundland, Canada
    VGT's are pretty mainstream in the diesel world these days. They started really catching on about 6 or 7 years ago.
    However the units I am familiar with are all ECU controlled. Either using a high pressure oil solenoid (like fords) or a small electric motor/pushrod assembly (like hinos).
    I haven't done much research into VGT's on gasoline setups, but I'm guessing it would be quite alot of work to graft one on to a car that did not come with a VGT from the factory. These units are the future of turbochargers and you will see them more and more on factory applications.
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    Industry-standard VGT componentry for diesel motors doesn't do well in higher-temperature gas engine exhaust streams. BorgWarner has their BV50-series units on Porsche's turbos but it is difficult and costly.
    Oct 09 2008
    Don't Audi's new turbo engines have VGT's? Atleast thats what the guys over in the mk6 section of vortex think.
    Mar 27 2010
    solar system
    What people don't know on Vortex could fill a warehouse. Where are they saying this?
    Sep 12 2008
    South Central PA
    VGT is cool. apparently a bitch to tune because of how fast they spool. but thats just what I've heard.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Oct 09 2008
    Quote Originally Posted by ZimbutheMonkey View Post
    Quote Originally Posted by JoshDub View Post
    I thought I read on the front page of AZ one time that audi was using a VGT on some new model.
    The Awesome™
    Mar 15 2008
    Spokane, WA
    Quote Originally Posted by Dan[FN]5857 View Post
    That is wicked awesome. Know I understand how they work on the inside. Thanks for the little vid!
    Jun 30 2008
    Erie, Pennsylvania
    I think they guy who was using the variable holset turbo on his Audi had a problem with steady state cruise. He had the "gate" spring loaded towards the smallest setting, so it would get bigger as the boost increased using a normal wastegate actuator. The problem was at steady state cruise there was no boost, so the gate (variable nozzle part of the thing) would be at the smallest size and the thing would overheat. To fix it, it would need to be computer controlled so when there is no boost request, the thing would open up wide to help with exhaust flow and not overheat the turbine parts.
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Google DSM VGT Holset. You'll find some threads about a guy who did one up on his talon. Ithink he even has some vids on YouTube. The actuator really needs to be electronically controlled to get the most out of it. Iirc, he was hitting 24psi around 4k rpms on a 2.3 but had very good spool at cruise.
    It's definately the way of the future for turbo systems. We just need a few motivated people to work the kinks out.
    Mar 27 2010
    solar system
    Quote Originally Posted by slow&low View Post
    The Holsets are a little different. Instead of vanes they have what could best be described as a notched cylindrical sleeve that slides back and forth over the turbine area (lengthwise of the turbo). Also, I find it really funny when Porsche makes themselves out to be the first to implement VGT turbos on a production car. The vid that Dan posted is of a turbo on an 80's Chrysler Shelby Daytona.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by slappy_dunbar View Post
    nice copy-paste.
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Senior Member Three Rings westie180's Avatar
    Mar 01 2011
    Indy
    the main issue with vgt's right now is that most of them are designed for cooler diesel exhaust gases rather than gasoline exhaust gases. until more are produced with materials that can take more heat (and perhaps with the implementation of titanium-aluminide in rotating components as well), it'll be difficult to make them work reliably on our gasoline engines. i do have a nice big borg warner vgt sitting at work though. however, the vanes are seized, and i snapped a bolt off the turbine housing.
    Oct 15 2006
    From a few to one...
    Arlington, VA
    +1 for the moving image. definitely gives me a clear idea of how they work.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
