Results 1 to 7 of 7
    Jan 24 2010
    melbourne australia
    Larger throttle body for 1.8T BT.
    Is there a direct fit larger throttle body for the AEB 1.8T? Or does it require an adapter?
    96 A4 1.8TQ
    FRANKEN TURBO K03-073, 1 BAR CHIP, SUPERTECH VALVES, PORT N POLISH, JE PISTONS, SCAT RODS, 034 MANIFOLD & FMIC, FIDANZA FW & SOUTHBEND STG 3, BILSTEIN & H&R, 3IN EXHAUST, CUSTOM AIR BOX, APR DV, DBA SLOTTED, RED STUFF.
    Active Member Two Rings V4VanGelder's Avatar
    Oct 26 2008
    SC 2.8 Passat;3076R 1.8 Passat
    Queens, NY
    they all require an adapter plate. bigger throttle body= larger mounting flange
    99 B5 Passat 2.8 Supercharged & Widebodied - UNDER CONSTRUCTION
    01 B5 Passat 1.8T GT3076R - Daily Driven @ 25psi
    motor work done by ME.
    Veteran Member Three Rings Oceanside's Avatar
    Dec 12 2008
    2001 A4
    St Pete FL
    pretty straight forward with the plate
    AWM BAT A4 / AGP D42 .48 / Tapp 630 / IE Rods / LwFw+ S4 SB / APR Stealth / Garrett-Precision 450 / 2001 FWD Highway Menace
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    If you want to get the most of it, you should bore the IM opening to match.
    00 A4 1.8TQ MT (AJL)
    12 1M
    18*8 RPF1 | Vogtland GT 575F/675R | H-Sport Sways | 320mm B8 Brakes, 300mm S4 rear |
    GT2871R Elim | QMS tuned AJL 627cc EV14 @ 4.3bar | 034 3" DP (8psi backpressure!) | Milltek | JHM SSK
    3090lbs
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Larger TB isn't really needed for FT power. Now if your looking to make over 450whp then maybe.
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    yeah there was a huge test on different TB and the power increase and such on a BAT setup, ill see if i can find it, but results for cars making under 300hp was very minimal like around 7-10whp, all need adapter plates i would also hone the inlet a little for a smoother transistion.
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    The other issue that you may run into is that you'll need to get your tune adjusted to run the new throttle body. Like Mike said, unless you're running a GT30 or larger it's probably not worth it for the gains.
    That said, I'm looking at your sig and about the only thing that you don't have is a GT or larger turbo. Any reason that you're still running the FT?
