Results 1 to 11 of 11
    Established Member Two Rings AllBlackA4's Avatar
    Dec 01 2010
    texture of plasti dip on grille?
    hey guys i just plasti-diped my grill and it looks really good but it has a rough texture to it. i was wondering if any of you that have plastidiped their grill have a rough or smoothe finish and what can i do it make it have a smoothe finish?
    Oct 27 2009
    Miami, FL | Boone, NC
    Quote Originally Posted by AllBlackA4 View Post
    I think you sprayed it from too far away. According to fonzie, our resident plastidip expert, the optimal distance from tip to surface is 6in. Too close and the coating will be blotchy. Too far and the coating will be rough.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Dec 01 2010
    so should i go over it with more plast dip or should i do the whole thing over?
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    plasti dip will always have a texture ... how rough it is all depends on your spraying skillzz... smooth is only from a vinyl wrap or satin type paint.
    here is what painted looks like ....
    here is a mirror as well
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Never having done Plasti-Dip myself, my understanding from a multitude of posts here is that it can be 'peeled off' without much difficulty.
    That said, I would recommend removing and trying again.
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Jun 02 2009
    San Francisco
    When applied, it should have the consistency of spray paint, but when it dries, it will have a bit of a rough texture like ultra fine sand paper.
    Veteran Member Four Rings Audacious's Avatar
    May 03 2011
    Just rip it right off and do it again. Texture also depends on how many coats you put on.
    Senior Member Three Rings Debow's Avatar
    Nov 28 2010
    2000 A6 2.7t MT Snow blower.
    Southington ct
    so what is the pro of doing this the the grill? never saw it or heard of it?
    Nov 28 2010
    Southington ct
    oh and where do you buy it ??
    May 03 2011
    You can check out these threads for any questions, they literally cover everything:
    http://www.audizine.com/forum/showth...Plasti-Dipping
    http://www.audizine.com/forum/showth...eets-Plastidip
    http://www.audizine.com/forum/showth...nd-Trim-Pieces
    Just search next time. Good luck.
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    plasti-dip is classified as a rubberized coating. it will have texture no matter what. how much depends on how you apply, but no, it will not be smooth and glossy like tremclad when you're done with it.
