Results 1 to 29 of 29
    Registered User Four Rings Fonzie@DipYourCar's Avatar
    Oct 16 2010
    Coconut Creek
    Plasti Dip How to and Tips - for those brave enough
    OK, i've had literally over a dozen requests for this, so i figure the demand is high enough to write it up.
    I'll start by saying that it was way easier the second time I did it. Took me about an hour and a half less the second time (5 hours total), because i knew what i was doing, and how to avoid cetain mistakes.
    What you'll need:
    - A MINIMUM of 13 cans of your choice color of plasti dip. Don't think you can get it done with less.. you can't. If you can't find 13+ cans, order some online. I ordered my white from amazon through acehardwareoutlet. If you don't use enough, the coat will be too thin; and then A. it won't cover, especially if you're trying to change the color of your car, and B. it won't be thick enough to peel off when you're done with it.
    - 4 or 5 microfiber cloths - these are for helping you clean up overspray and whatnot
    - Some sort of spray disolvent - Goo Gone, Goof Off, something that's made to dissolve adhesive and rubber - this is key, because you can't tape off everything, and wiping the glass/roof off with this sprayed onto a cloth makes things much easier
    - LOTS of blue painters tape - i used the 3" roll
    - something to mask the car - i used plastic dropcloths from home depot
    - not necessary - but i have one of those trigger guns that you can pop a spray can into - then you just pull the trigger and hold it like a spraygun instead of using your finger on top of a spray can. makes it easier and more controllable.
    Process:
    Wash the car thoroughly. Make sure there are no bugs, dirt, crap - it has to be baby ass smooth.
    I prepped the whole car at once. i didn't chose a panel, finish it, and move on. So start by taping and masking everything. EVERYTHING. all lights, backup camera, license plate, wheels, tires, mirrors, windows, window trim, windshield wipers, grille, foglights - everything that is not going to get painted. I traced large sections of the car and cut out pieces of the plastic drop cloth to cover the large areas. open the doors and put tape on the inside of the frame - in between the cracks. open the trunk and do the same thing - anywhere there is a crack, open it up and tape underneath. cover the exhaust tips too. walk around the the car 2 times making sure nothing is exposed.
    Shake the hell out of the cans - they will spray clear if you don't mix them up. Start by picking one panel at a time, and your objective is to lay down a THIN coat at first. work your way from the door, to the next door, trunk, ect. the first coat is THIN, barely noticeable. You need to build it up slowly - trust me i learned the hard way.
    You should go through about 3-4 cans laying down the first and second thin coats. Then the idea after that, is workin on one panel at a time per coat, move around the car, building up coat after coat - basically until you run out of paint. I think with the white i laid down 6 coats.
    MOST IMPORTANT THING - there is a very small forgiveness zone as far as the distance of the spray. Too close - and it will be too thick, show streaks, and bubble up with little pin holes. Too far away - and it won't bond, will be way too textured, and will look like crap. The issue here is that once you find the good distance - which is about 6 inches away - you CAN NOT f*ck up. it doesn't matter if it's the first coat, or the last - if you go in too close on even one spray - you will have to redo the entire panel - because it will stick out like a sore thumb. Use a sweeping motion, releasing the trigger on each side to side pass.. and pay close attention to the distance of the spray.
    The Hood - the hood is the biggest pain in the ass. For one, it's the largest surface area and a mistake will show big time.. Secondly, because it's horizontal. You can't turn the can sideways and face the can towards it -it will drip out of the nozzle. so here's how you do the hood. Lay down the first two light coats as close to the 6" distance as you can. When you get past the first two coats, you need to pop the hood - and spray it from the side as it's popped. That will give you that vertical surface to spray on to. MAKE SURE you get the middle of the hood. It's so easy to get the front and sides of the hood and leave it thin in the middle. Take your time and make sure you have even coverage on the hood - it's so difficult to get even.
    this is where extra paint comes in - because there's a good chance you will create a wet spot, thick spot, pinhole bubbles, ect - and have to rip it off and do it again. take your time, and focus on keeping the right distance and even coverage.
    I did it in my garage, and drove the car out into the sun to bake between coats. i waited about an hour, then removed all the tape and masking. then you start trimming. use the microfiber towels to rub off any plastidip that's not supposed to be there. for large areas with plasti dip "dust", spray some of the disolvent onto a cloth and wipe it off. after it's all cleaned up , i waited another hour in the sun, then gave it a wash. i used a soft microfiber washing mit, regular car wash soap, and never sprayed the car with water, i just let the hose dump water onto it without a nozzle.
    then i dried with a shamee cloth, and let it settle. today it looks super smooth, very even, and borderline perfect. i hope i covered everything, if i left anything out - just ask.
    Dec 03 2010
    SF
    how long do you think it's gonna last? i am planning on painting my roof with these.
    Veteran Member Four Rings bez101's Avatar
    Oct 06 2009
    sheffield
    you plasti dipped your full car ?
    pics !
    Registered User Four Rings primetime's Avatar
    Mar 05 2010
    5 four ring cars and 1 P-car...
    Quote Originally Posted by bez101 View Post
    pics !
    No he plasti dipped his car TWICE!
    Oct 06 2009
    sheffield
    thing i need to see a few pics
    Veteran Member Four Rings B8 S FOR's Avatar
    Feb 15 2011
    Pittsburgh, PA
    Quote Originally Posted by primetime View Post
    +2 LOL! Looked awesome especially the "Stealth Fighter!!" Fonz got some balz!!!!
    AUDI 4 LIFE.........B9 S5 Cab Prestige/ Mythos Blk Met
    Gone but not forgotten:
    2015 B8.5 S5 Cab
    2011 B8 S4
    Oct 16 2010
    Coconut Creek
    "stealth fighter s4" and "stormtrooper s4" threads.. lots of pics
    Senior Member Three Rings DrnknCamel's Avatar
    May 05 2011
    14 BMW X1, 17 F150, 02 S8, 99 A6 Avant,
    Macon, GA
    Thanks for the write up man. I have been thinking about doing my wheels.
    I know this has probably been asked before, so dont rip my head off, but how easy does it come off. If i did multispoke wheels, will it come off in 1 or 2 big pieces, or have to take like an hour and some goo gone to get it off?
    Veteran Member Four Rings praudi's Avatar
    Jul 31 2007
    R8 power wheels , Tiguan and Ferrari F1 power wheels
    Tampa,Fl
    pics nowwwwwwwwwwwwwwww (in a nice tone lol)
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    When it was Matte Black - Stealth Fighter S4
    And now Matte White - Stormtrooper S4 - matte white pd #2
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Oct 16 2010
    Coconut Creek
    Quote Originally Posted by DrnknCamel View Post
    if you put enough layers on, it comes off in one piece (multi spoke wheels, maybe a couple pieces.. but it'll be ok). the only trouble you run into is if you put it on too thin or you spray from too far away
    Quote Originally Posted by praudi View Post
    lol dude there are dozens of pics - check the stealth figter and stormtrooper threads in this forum.
    Oct 16 2010
    Coconut Creek
    Quote Originally Posted by b6bydesign04 View Post
    thank you sir
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Wow, crazy stuff! Nice work, very ambitious!
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
    Dec 22 2010
    ny
    how hard was it to get the black off? did you notice any problems?
    Oct 16 2010
    Coconut Creek
    it was easy. took 5 minutes plus 10 minutes of spot cleaning. no problems
    Veteran Member Four Rings Chestlock's Avatar
    May 30 2010
    Victoria, BC
    Thanks for the writeup Fonz - do they have plasti-dip in Sepang?
    Aug 19 2008
    Boston
    I would like to throw in...
    Whole car...
    After:
    Before:
    White is a little thinner so to get even coverage of panels, you are going to need more than 13 cans for full color change. I went through 21 cans on my B5 wagon...
    Oct 16 2010
    Coconut Creek
    f'n sweet man! PM'd
    www.dipyourcar.com
    Jul 06 2013
    United States
    hello everyone, we are distributor and fabricator of plastic products. Acetal, Acrylic Sheets, UHMW, rods, tubes, polycarbonate sheet, styrene, Novus plastic polish, plastic cleaners and supplies, plasti dip, milling, etc. Heavy focus on custom fabrication.
    Veteran Member Four Rings morris400's Avatar
    Dec 18 2008
    2016 VW GTI, 1994 Audi S4
    Alberta, Canada
    Did this today on my 94s4
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    2016 VW Jetta 1.4T Daily Driver
    1994 Audi S4 20V Turbo, K24 7400 EFI EXPRESS
    2001 Audi S4 - Gone! Dropped valve cyl 4
    Account Terminated One Ring
    Jul 15 2013
    New Zealand
    CHECK THIS OUT!!! I just did an awesome write up on how to plasti dip emblems and badges!
    Click here: http://bit.ly/1aDdRAz
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Any tips for doing the Chrome trim on my car? I will be doing it this week. I ordered a bunch of DIP should be here Wednesday.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Established Member Two Rings West.point1's Avatar
    Dec 29 2013
    [/IMG]
    my 2008 audi a4 plasti dipped
    Dec 29 2013
    Oct 15 2012
    1995 M3, 2004 R1, 94 F2
    Minnesnowda
    Whatchoooo know about dip:-)
    Established Member Two Rings CassiesandraLee's Avatar
    Jan 10 2014
    No garage, just single apartment life!
    Abilene, TX
    Any tips on the best way to do more than one color on wheels? I'd like to do two spokes a different color than the rest just for a little bit of flash, but couldn't quite make it work the first time out. Has anyone else tried this and found a good way to do it?
    2006 A4 2.0T quattro
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by Stackdeezy View Post
    Alex did those wheels, right? They look good. Much better on the B7 than the B8.
    Jan 03 2014
    Calgary
    I want to do my b8 grill and 4 wheels. How many cans you thibk? 3?
    Black spray. Do a glossifier affer?
    Aug 01 2013
    Austin
    ^ i used 4 cans on my wheels.
    maybe a can on my grill.
