Page 1 of 3 123 LastLast
Results 1 to 40 of 113
Thread: best cams?
    Established Member Two Rings b5briand's Avatar
    Apr 19 2011
    2003 Chevrolet Suburban z71
    nowhere
    best cams?
    what are the best aftermarket cams for my 99 audi a4 1.8t? any suggetsions
    full fiberglass bucket seats w/ brackets for a b5-pm me for more info
    Feb 27 2005
    North Wales, PA
    whats your engine set up? don't bother on a stock turbo until you have the ability to move more air.
    Veteran Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, 2022 Outback, 97 civic ex(blew up), 95 Toyota pickup(sold)
    Parkland,FL
    I would so go with some of IE's new camshafts hearing some really good things about them
    99.5 A4 1.8TM AEB Fronttrak - Volcano Black Mica - AutoFlex'd Signal Green - E85 - Clutchmasters 725 series twindisk - ID1000cc - Precision 5858 cea Ball Bearing Turbo - JE Pistons/IE Rods - EurodyneMe - Coilovers - AWE DTS - 034 Mounts - Team Dynamic Wheels -Nitto INVO -Working @ DipYourCar.com - Usp Motorsports -
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
    Apr 19 2011
    nowhere
    farthest from stock...
    atp gt28rs bt kit
    ecs rs clutch
    660 injectors
    eurodyne tuning
    fmic
    apr exhaust
    hitachi 4 prong coilpacks
    thats what i can think of off the top of my head
    Apr 19 2011
    nowhere
    can you send me like more detials on those/ a link maybe
    Feb 27 2005
    North Wales, PA
    catcams are whats available now. Integrated might be releasing theirs soon. Just do a google search
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by b5briand View Post
    atp gt28rs bt kit
    ecs rs clutch
    660 injectors
    eurodyne tuning
    fmic
    apr exhaust
    lol that's not the farthest from stock, but regardless is your motor built?
    - Clint
    Dec 05 2007
    OP, you would want at least forged rods (for protection) and be able to rev past 8k to be able to utilise aftermarket cams. Depending on your setup, aftermarket cams would really not be worth it when it comes to cost vs gains. A more reasonabale thing to look into if I were you would be forged connecting rods and a turbo upgrade. Then build the cylinder head with cams after that, which in turn can make the larger turbo on stock displacement spool faster with more top end power.
    Apr 19 2011
    nowhere
    like i said thats what i can think of off the top of my head...je pistons, cadoza rods, my shit is pretty built, i wouldnta posted this thread if i didnt think cams would add power...
    like i said i have a big turbo and internals are all done...i saved up now the next step is building the head...suggestions pleaseee lol im a little iffy on what setup to do
    Dec 05 2007
    Why not step up from the GT2860RS, if you have a built engine. That is what people throw onto a completely stock block. I actually just placed in my order for a T3 GT2871R last week, and I have a completely stock block. That flows more than your turbo does.
    Just saying, there are other options. For example, you can spend $650+ on a set of cams. Or you can spend $600 and send your turbo to Forced Performance and have them make your turbo that currently flows at 35lbs/min to 51lbs/min (this option exists, but people are just waiting on a test rabbit for it. the HTA 68 upgrade has been tried and proven and flows at 45lbs/min I think it is). Just throwing in other options that exist.
    Veteran Member Three Rings MarcMiller's Avatar
    Feb 22 2011
    Philly215
    Anyone know any cams for 30v v6?
    Apr 19 2011
    nowhere
    oh good for you buddy i bet my cars still faster then yours
    Veteran Member Four Rings revolution337's Avatar
    Apr 03 2009
    4.2 A4, 82 Vanagon, Mk7 Sportwagen
    Pennsylvania
    and there goes the thread
    Life is too short to drive ugly cars.
    Dec 05 2007
    Was that directed towards me? I was not showing any form of malice or disdain towards you, if you thought that I was. I am simply trying to give you other options other than cams. To utilise cams, you would need to build the cylinder head to be able to rev up to ~8500 rpm. Otherwise, it would be a waste.
    Edit: just realised that was directed towards me. you are a complete dickhead. I am over here trying to give you other options that could be more beneficial than cams, and you reply that your car is faster than mine. grow the fuck up
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Chill out. He is right. Cam choice depends on airflow and that tater isn't moving enough air to be a problem yet. If you step up to a 30r or bigger then some cams will help. It also depends on how you're tuning the thing.
    Jim
    I Do Werk.
    Apr 19 2011
    nowhere
    ik im a dickhead lol. whats that gonna run me(swappin my turbo) i mean like i gotta get alllll new shitt
    Dec 05 2007
    By ATP turbo kit, do you mean an eliminator kit or full frame t25/t3 flanged setup? But from a thread on the topic of the HTA68,71,73 upgrade, it can also be done to eliminator turbochargers. I am just trying to help you make a better decision, because you really just want more power. There are better routes at your current stage to get more power, than cams. And once you reach the point of being able to really utilize cams, then decide on which cams to get.
    The HTA was just one example of a better route than cams, at your current juncture. There are others, such as meth/race gas with file.
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    Yet you don't have the slightest clue as to which cams you should buy? You do realize that cams aren't going to do you a whole lot of good on a GT28RS right? Seems a little odd that someone with as much of a built setup as you wouldn't have any idea as to what cams to buy. I'm callin' trolling on this one.
    Veteran Member Three Rings CamrideA4's Avatar
    Jan 05 2011
    Raleigh, NC
    Did you build your car or did you buy it as is (or maybe have someone build it for you)? Because you sure don't seem to know much about how this process works for someone that has "their shit pretty built".
    2001.5 A4 1.8TQ Tiptronic - FrankenTurbo F4 - 440cc Green Giants - TT225 MAF - Borla exhaust - ST Coilovers - Malone Tuning - Garrett FMIC
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Quote Originally Posted by Poopie View Post
    Schrick cams were being used years before people started using CAT cams. LOL
    Have been running Schrick cams in my car for 7 years now and Lucas in Australia was running Schricks for years before me.
    Yes they cost almost twice as much as CATs but at least they haven't ever fallen apart.
    Schrick offers a 252 and 260 intake cam for the 1.8t, exhaust cam is 260. The 252/260 should show some good gains on a GT28rs setup.
    Apr 19 2011
    nowhere
    thats why i posted this thread..because shrick was a little too much $ right now and i wanted too see what other options there where. so i had an idea what cams to put in my car. as for how built my car is the guy b4 me did about half of the work and half assed it...so i did more stuff and fixed what he did wrong
    Feb 08 2011
    Well twice the price for cams you dont have to worry about is well worth the money spent.
    Going with cheap cams that end up failing means spending a much larger amount of money to fix the damage.
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    If you're looking for more power, I'd suggest stepping up your turbo game before you do cams, really....
    1990 Audi Coupe Quattro - 4.0t 6spd swapped
    4.60 60-130mph Xona 10569s E70
    Apr 19 2011
    nowhere
    can i step up my turbo game for 2500$...thats what i have lol
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    here, if you wanna go fast
    http://www.audizine.com/classifieds/...fs-2fft&cat=21
    Mar 27 2010
    solar system
    Quote Originally Posted by M-Hood View Post
    I don't know how much gain you're going to be seeing on a GT2860, especially when changing the exhaust cam. When I spoke to Pete at IE, he said that given the exhaust side backpressure on a 2860, changing the cams won't give you much. More to the point, you're just creating the possibility of reversion with the extra overlap + high backpressure.
    Dec 05 2007
    Did everything I write go right over your head? I mean, really?
    Let me reiterate: You can send your current turbo to Forced Performance for a $600 upgrade to have your current turbo that flows at 35lbs/min to either 45lbs/min (HTA68 upgrade) or 51lbs/min (HTA71 upgrade). That is exactly what I would do if I were you, and why I even suggested it. It is not only cost effecient because you already have a GT2860RS, but have been proven to not lose effeciency in the higher RPM. Or you can go the route of moving up to a 30 series turbocharger, which Jim aka onemoremile suggested.
    Mar 27 2010
    solar system
    If you're doing your own work, (which you said you are) $2500 is more than enough to upgrade your turbo. Talk to Jess at usedturbos.net (he actually sells lots of new ones too). He can set you up with a precision turbo for about $700 or so. $200 for new injectors, $900 (tops) for a new tune and that still leaves you with $700.
    Hell, between the $2500 cash and the money I should be able to get from selling my elim setup I'm hoping to complete a full engine/turbo build for about that price.
    Feb 08 2011
    Quote Originally Posted by ZimbutheMonkey View Post
    Did Jordan in CO put in cams or his he still running stock? The last thing I would do is cams on any turbo setup, if he did cams on the 2860 setup and didn't get much gains he will at least already have cams in the motor if he swaps to a larger turbo.
    Apr 19 2011
    nowhere
    i have siemens 660cc injectors. i do MOST of my own work...for example wiring is one thing i dont do but ill put my own turbo in. the reason i dont know alot about this turbo setup i have is because i didnt put the turbo in the car or the rods and pistons...the guy before me did. sorry for being a dickhead/douchebag...all considering you guys win im gonna do a turbo haha thanks
    Mar 27 2010
    solar system
    Seconding what he said. Also, props on apologizing. Not too many people willing to do that, so points earned.
    Edit, depending on which head you have you may want to consider a few other options:
    1) if you have a small port head, upgrade to an AEB head
    2) If you have an AEB head, get some porting work done on the exhaust side. I'm bringing my head over to a fellow in my neck of the woods who's probably one of the best race engine builders I've ever seen (been doing it for over 60 years). His opinion was that doing the intake side wasn't going to net me much gain. He did, however, think that doing the exhaust side would help. I'm going to report back once he has a good look at the head and see what we decide on.
    In either case, upgrading the head or getting work done to it to help it flow better will net you gains without the worry of what your engine will run like with more aggressive cams (i.e. low vacuum, bad idle, loss of low end power etc...) In my opinion, if you're looking into cams, wait for the IE ones to come out. Check into the intake cam upgrade first as it's the one with the least risk in terms of performance tradeoffs.
    Dec 05 2007
    i have siemens 630cc injectors. i do MOST of my own work...for example wiring is one thing i dont do but ill put my own turbo in. the reason i dont know alot about this turbo setup i have is because i didnt put the turbo in the car or the rods and pistons...the guy before me did. sorry for being a dickhead/douchebag...all considering you guys win im gonna do a turbo haha thanks
    Fixed. And good decision on the turbo upgrade.
    You should really find out what your turbo specs are. If it is a T3, T25, or eliminator setup? If you don't know this, you won't know what path to take for your upgrade.
    Apr 19 2011
    nowhere
    i have an aeb head. and seerlah...its in eleminator
    Dec 05 2007
    This is one reason I don't suggest the eliminator kit. If it wasn't for Forced Performance, you would really be stuck on the GT2871R eliminator upgrade or the GT3071R upgrade (which many think to be a bad combination, like the GT2876R). I would give a call to Forced Performance or ask Mike Hood (M-Hood, who posted in this same thread) about what can be done to your current turbo, to save on as much cost as possible. Only change that looks like would be necessary is a retune when finished, to compensate for the added air flow. Or up your fuel pressure and keep an eye on your A/F ratio. But having a proper tune would be the better route.
    Apr 03 2009
    Pennsylvania
    due to the small size of that compressor housing/outlet, you will be limited to the amount power you can squeeze out of it
    Dec 05 2007
    ^I am pretty sure Mike said that the new compressor housing FP sends you with new compressor blade has a 3" inlet. So, the OP would need to rig up a custom intake. I forgot about that.
    Mar 27 2010
    solar system
    So here's a response from Pete at IE regarding the GT2860 and cams.
    Hi there,
    No, we do not have any dyno results from a small turbo like the gt28r. For a turbo like that I would suggest either the intake cam or none at all- those turbos are pretty easy to max out.
    Mar 27 2010
    solar system
    Quote Originally Posted by revolution337 View Post
    Although it plays some role, The compressor inlet isn't going to be your biggest limiting factor. The fact that you can't go larger than a .64 A/R on the turbine side will cost you more power than a smaller compressor inlet.
    Apr 19 2011
    nowhere
    yo i feel so dumb right now. i was talking to the guy who sold me the cars best friend and he was like "dude we put high lift cams in there and without porting the head" so now what im going to do is save up for the entire summer and redo my whole turbo setup; going to the 35 rather then the 30 or 28(what i have now). what u guys think? p.s. other then me being an asshole (sorry again) this has been a great thread so far you guys have been a sick help!
    Dec 05 2007
    I would not recommend the GT35R for stock displacement for a comfortable daily driver. It would spool rather late, in the upper rpm range. It isn't always about the power, but the powerband. A full frame GT30 series turbo route would be the better route on stock displacement. There are other turbo otpions you can look into.
    My plans is to do a full frame T3 GT2871R and run it at like 18psi till I can do drop in rods. After I do drop in rods, then up the boost and have my turbo sent to FP afterwards to do an HTA71 upgrade. This will bring the turbo to the same power level of the GT30 series. Then purchase a built AEB cylinder head. And I think that will be it for my vehicle.
    There are many otpions to choose from if starting from the ground up. Since you already have a built block, your options become that much more greater.
