I'm at 65k, just tuned, but by how everything is on the car, the guy before me babied it. even just doing a throttle body resync, it made a huge difference. I think I'll do it before winter.
So do we have a KMD rep on here? I am curious about the plunger possibly bottoming out? That could be pretty bad. I would assume if it doesnt bottom out then it would be same as stock though.
Vizi, do you run the roller now? I feel like the bearings could get worn and it could get stuck, causing the same issue but for a much higher price tag.
Finally, with my tune, Mike @ VAST left my rail pressure at 3BAR which is OEM which means the HPFP stays at stock load, and basically, the fuel map, wastegate, and rev limit, were the things changed involving my Stage 1 tune. I should have no issues running an OEM follower for mucho miles?
