Results 1 to 11 of 11
    Senior Member Three Rings Vegas34's Avatar
    Mar 04 2008
    2001.5 Nogaro/Alcantara/6speed
    Vegas
    Annoying rattle, goes away when i apply the brakes...
    And I'm super pissed because I can't seem to find this one my own (thus this post), but it's at any speed over bumps (small or large) a metal clanging/rattling sound. As SOON as I touch the brake pedal, whether a little or a lot of pressure, the rattle IMMEDIATELY goes away until I let off the brake pedal.
    Could this be anything other than something in the brake components?
    Front End Parts/Info (less than 4k miles):
    All new upper control arms and tie rod ends
    Hawk pads, resurfaced rotors, stock calipers, new brake fluid
    New front axles (drives side china one blew up a while back, now tight n no leaks)
    H&R sports/Billsteins (all bolts high n low seem snug as hell)
    034 street tranny mounts, and 1 tranny bracket has a small crack (don't think this is the culprit)
    APR Snub Mount
    Brake shields and axle shields are all tight as hell
    Anyone? What the heck am I not seeing? It's annoying as hell. Maybe a bolt on the brake carrier? I'm 99% sure we tightened everything up when we did my brakes...as usual any help is appreciated!
    Rob B. - Kansas City, MO
    2001.5 Nogaro S4 | 6 speed | Alcantara | DD with no major mods
    2008 A4 2.0T | Wife's car
    Mar 04 2008
    Vegas
    stock wheels, stage 2, complete TB job recent...just trying to list as much about the car as I can...it's probably something simple that I'm missing. You can hear it all the time with windows down, not hear it with them up...
    anyone?
    Aug 05 2008
    Chicago
    im pretty sure my problem has to do with the bushing on my coils going bad or collapsing springs but I have the same type of rattling sound. I put the car on a lift and banged against the springs and it made teh same rattling noise...I can also moe the spring with my fhand 2 inches up. Maybe you have the same thing going on...
    Mar 04 2008
    Vegas
    I've had the car up, and the suspension is super snug. I've installed quite a few suspension on B5's, so I don't "think" that's it. It's just very odd that the noise COMPLETELY stops when the brakes are applied.
    Does yours continue to rattle when the brakes are applied wan2play?
    Established Member Two Rings GiantBean's Avatar
    Mar 28 2011
    are you missing any retaining clips? The rattling may be the pads moving around in the caliper(I have seen this before) Dont forget to check the rear brakes as well.
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Quote Originally Posted by GiantBean View Post
    Check this. Also, check the rotor gaurds, or
    whatthefuckever they're called.
    Veteran Member Three Rings joe dub's Avatar
    Sep 01 2008
    Illinois
    ive had this issue. rear caliper pins need grease. jack car up, and with e-brake off check the rear caliper for the wobble. it will make this noise. pull brakes and grease the shit outa teh pins
    silver - RIP
    black - TAILS
    Mar 04 2008
    Vegas
    ok, will try that with the rears, thanks guys...it's a pretty loud noise, but it's gotta being in the brake system somewhere...
    Mar 04 2008
    Vegas
    Quote Originally Posted by joe dub View Post
    Does it matter what kind of grease?
    Sep 01 2008
    Illinois
    just snag some brake part lube/ grease permatex from advanced auto. or something that wont eat the boots (silicone, synthetic
    silver - RIP
    black - TAILS
    Mar 28 2011
    As long as its a high temp brake grease
