Ok, just a quick update. I rebuilt my engine and now my car doesn't start. I have the p0685 ecm/pcm open circuit. I replaced j271 and fuel pump relay. Fuse 29 appears to be good and i replaced it anyway.
I was checking the CP wires and i found that with the car on, none of the wires have power. Also, when i checked if they are grounded with the car on, Pin 1 was barely lit up, Pin 2 was lit, Pin 3 had nothing and Pin 4 was lit. I've read that Pin 1 should have power with the car on but i'm not seeing that. However, it lights up when i put positive to it almost acting like a weak ground. I'm using a typical test light to check because i'm frustrated and running out of cheap options. I have no clue how it got like this and it's driving me nuts.
Audicrazy said i should be seeing the volts of the battery on pin 1 but instead it acts like a ground because it faintly lights up when i put power to it.
