Results 1 to 8 of 8
    Mar 29 2008
    1998 Acura GS-R sedan
    Coastal North Carolina
    Difference between GBT and FPT transmission
    Are there any? I know older transmissions use different flanges, but are these two interchangeable? How about the electrical hookups?
    Oct 29 2005
    10speed
    San Francisco, CA
    what are they out of? all 5 speed transmission from 94-03 are interchangable. Only things that have changed are rear diff cases, ratios (only between the B5 1.8, B5 2.8, and B6 1.8), and axle flanges
    - Clint
    Mar 29 2008
    The GBT is out of my 2003, the FPT is out of a 2002 in a junkyard somewhere and is cheaper than a junkyard GBT. I was mostly wondering about things like speed sensors.
    Is is fair to say that any 5 speed from a B6 1.8 quattro will bolt into any other B6 1.8 quattro with no issues? I've done a lot of searching on forums, and this is hinted at, but I've never seen anyone come right out and say it.
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    sorry for bumping an old thread but I really need some info on this.
    I also have transmission troubles and the GBT is quite expensive at the wreckers I know its my best bet but, the dealership told me that it "MIGHT" be interchangeable with GBT FNU FTP AND FPT.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by iamshayan View Post
    All you need is a 5spd manual quattro transmission. Don't worry about the codes. The codes just reference gear ratios and such. Going rate is anywhere from $100 to $500 USD for a used 5spd quattro trans.
    If it is out of a B5 you will have to swap the front driveshaft flanges and the tailshaft housing from your existing B6 transmission to the new B5 transmission.
    Search function would have found these answers for both the OP and yourself. Its been covered quite a few times in the B6 section over the past three or four years.
    -Doug
    Jun 21 2005
    Milton, Ontario
    Just find a B6 5 speed tranny so you don't have to have the flanges and tailshaft swapped over. I'm using the B5 2.8 because Doug had already swapped the flanges and tailshaft over for me.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Jan 13 2010
    Toronto Canada
    Thank you very much, I did search and this is the thread that I found :-p
    it sucks because everywhere in Canada wants $1000+ for the transmission...
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Aug 19 2013
    minnesota
    Thanks for the thread. GBT it is. For the record car-part.com lists all of these befittin' the b6 5sp quattro. fnu fpt ftz gbt.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
