- He brings the car to me for an oil change. I change the oil and reccomend that he does his valve cover gaskets and replace the serpentine belt.
- About a week later I change the valve cover gaskets with the full victor-reinz kit and replace just the belt with the Continental belt
- About a week later, he calls me and tells me that battery light is on and by the time he get's home, the car dies I go look at the car that day, and guess what....yeah it threw the belt. we got the the stealership and get a new OEM belt and I tear the front end off again....in the rain
- I get the front end off and pull off the broken belt that happened to be resting in the engine bay. The belt look like something sheared off about 5mm from one side of it. he admitted to me that he was being hard on the car when it happened. So i put on the new Audi belt, button it up and it runs great (this was yesterday mind you)
- Today, he calls me with the same issue, battery light on. This time he was cruising in 6th at 45mph when it happened. He brings the car to my house and the car is dripping oil from the bottom front of the engine. I get out my light and inspect and it threw the belt again....this time the belt is nowhere to be found. Here is where I am stumped, the front of the motor is now DRENCHED in oil. Looks like it is coming from more the driver's side. The oil is on the entire face of the engine-top to bottom.
So what the fuck is happening here? Why would the car throw 2 belts and now the second time the front of the motor is drenched in oil? He is going on vacation for the next week so i have some time. I'd like to fix it instead of him taking it to the dealer. I called JHM and keaton is going to ask jay and get back to me on it.
My current thought is one of two things: Original pulleys are worn causing the belt to snap and upon the belt being thrown, it hit some oil line somewhere? Aux. rad feed maybe? OR.....the crank seal/bearing is bad causing two things: the crank pulley vibrates causing the belt to be thrown and the bad seal causes, well, the oil everywhere.
