Page 5 of 5 FirstFirst ... 345
Results 161 to 186 of 186
  1. #161
    Jun 22 2010
    Sydney,Australia
    Hi All,
    If I get Audi to install the reverse sensors will they protude out? for rear reverse sensors.
    Thanks,
    K.
  2. #162
    Jul 16 2008
    Finland
    If you go to Audi, they will use an aftermarket kit from someone like Cobra. It's unlikely they're willing to retrofit the OEM sensors this thread is about.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
  3. #163
    Veteran Member Four Rings kwbdc's Avatar
    Mar 29 2012
    2006 Mazdaspeed6 RIP
    Seattle/WA/United States
    I'm thinking of getting this and have contacted the seller to get the instructions. Think it will work? http://www.carsystems.pl/audi-a4-b8-...ops,id728.html
    2012 Audi A4 Premium +MT, Quattro, Xpel bra, SLine BBS CI-R 20x8.5 ET 32
    Mods: APR HFC/DP, APR K04, Bilstein PSS10 Coilovers, Okada Coilpacks, AWE Boost Gauge, Eurocode SSK, OSIR CF Spoiler, APR Carbonio Intake, AWE Exhaust, OSIR CF valence, ÜSS Adjustable Stabilizer set, Alu Kreuz, RS4 grille, Fluidampr,Apikol differential, folding mirrors,Brembo GT BBK, Deval CF splitter,ECS skid plate, RS4 rear brakes, Snow performance Stage3
  4. #164
    Veteran Member Three Rings endy1's Avatar
    May 04 2014
    Sweden
    Quote Originally Posted by kwbdc View Post
    Go for it ! Dident think b8s came without sensors?
    I fitted front sensors on mine so let me know if you need help on that front.
  5. #165
    Mar 29 2012
    Quote Originally Posted by endy1 View Post
    Thanks I have an aftermarket rear camera but no sensors. If this works it would be cool to have both front and rear camera/sensors.
  6. #166
    Jun 22 2010
    Sydney,Australia
    Hi Guys,
    Thinking to do this retrofit. Front+Rear Audi Parking System Plus with graphics but no camera. My car has no sensors at all.
    I believe for the rear, there are markings of where the sensors are supposed to go inside the rear bumper.
    How about the front bumper? Are there markings of where the sensors are supposed to go?
    Also where in the grill do we place the 2 front sensors? Are they marked? Do they retrofit kit comes with brackets?
    I have an Audi A4 B8 2009 model (Sedan).
    Cheers,
    K.
  7. #167
    Apr 18 2014
    Slovenija
    HY ;) I have same car and im about to retrofit MMI 3g + front PDC + rear cam ;) So basicly what i can tell you - front bumper and rear has marked position of hole for pdc sensor (you need to drill it and position bracket in the kit on back side). Retrofit kit from carsystems or Kufatec dont provide you with front bumper grill sensor bracket (left (1) - 8K0919268A and right (1) - 8K0919267A --- thease are OK for normal grill NOT S4) -> but other stuff is in the kit. This is from my frend experiance of retrofiting front PDC in his car - he also encourage me, to do same process ;)
  8. #168
    Veteran Member Four Rings pwdrskr's Avatar
    Aug 21 2010
    Carlsbad, CA
    Has anyone tried to add front parking sensors on a US spec B8/5 allroad?
    '19RS5 Coupe: Prestige, Daytona Grey, Blk Interior, Carbon Pkg, Driver Pkgs, APR+/TCU/Intake, CETE AVC, ABT Coils, Vossen EVO-1R 20x10et20
    '22RS6: Glacier White, Blk/Gray Interior, Blk Optics, Exec, Driver Pkgs, Sport Exhaust, APR+, Akrapovič Exhaust, CETE AVC/ASC, Vossen GNS-1 22x10.5 et7, Stealth wrapped Piano Black Interior
  9. #169
    Jun 22 2010
    Sydney,Australia
    Ok thanks. How about oem kit directly from Audi? Will it have the brackets? How do we attach the brackets on the grill?
  10. #170
    Jul 16 2008
    Finland
    Once again, you CANNOT get an "OEM kit" from Audi. They do not have an SWM code in their system for adding parking sensors, so they sell the Cobra aftermarket kit as an option. You can order all the parts separately apart from some of the wiring looms, but it'll cost you $$$$. I would suggest you get the kit from navisystem.pl or Kufatec.de.
  11. #171
    Jun 22 2010
    Sydney,Australia
    What is the part number for the front sensors brackets for the grill? Are they available only in 1 colour the brackets?
  12. #172
    May 04 2014
    Sweden
    Just wanted to share this if someone have or will have this problem.
    Got it from another forum.
    Hi.
    I have done this retrofit on my A4 B8. I got everything working fine except that i cant turn it on/off via the button. The button lights up when car is put in R.
    Any ideas?
    I would personally check the pin numbers to the button and pin numbers in the rear module, i think that is all it can be.
    at the rear module it should be pin 13 and pin 4 in to the beige connector
    at the switch it should be Pin 1 and Pin 3
    If you used the Kufatec wiring loom it will have the wire numbers on the wires (even though they hard to read) if you have used the Kufatech english instructions these are incorrect they will tell you to use pins 13 and 14 in the beige connector when it should actually be 13 and 4.
    If everything else is working i would suspect this is the issue
  13. #173
    May 07 2011
    Philadelphia, PA
    Does anyone have a part number for the grille sensor holders? Thanks.
    Sent from my Nexus 7 using Tapatalk
  14. #174
    Active Member Two Rings Brian77's Avatar
    Jul 06 2013
    North Carolina
    This is the shop that I used, they use OEM parts only. The website is in German, but if you use Google Chrome, it will translate.
    http://www.k-electronic-shop.de/
    Also, if shipped outside of the EU, you can subtract 19% (German VAT)
  15. #175
    Apr 18 2014
    Slovenija
    Can anyone post real PICTURE of front pdc buzzer position... I realy tray to find where is originaly mounted but i did not find any clear pictures (i know it shoud be somwere under the dash)... So please i hope someone can post some pictures where it is and how to install it there ;)
  16. #176
    Jul 06 2013
    North Carolina
    This is the best one that I have, I hope it helps.
  17. #177
    Apr 18 2014
    Slovenija
    This is GREAT - thanks Brian77 for hellp.
  18. #178
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Bump, I have a 3G+ (google maps) retrofit in my b8 s4, I can get the display to come up with coding, the sensors reflect the distance in reverse, but the display switches out of the sensor/reverse camera within a few seconds of shifting into reverse.
    Any thoughts on getting this to stay on? Or is this the limitation folks are talking about with the module? The modules don't complain of any errors. It's just that the rear view camera doesn't stay on in reverse. Disabling the view restores function to the reverse camera.
  19. #179
    Feb 17 2018
    liverpool
    Hi guys
    Doing this on my car
    A4 2009 2.7tdi right-hand drive already fitted the rears now d o ing the fronts.
    Where do you get the wires from the cabin to the engine bay left or right side of the car thanks
    Sent from my SM-N950F using Tapatalk
  20. #180
    Feb 17 2018
    liverpool
    well front and rear all fitted.
    can anybody help with radio mute.
    with my old 4 rear sensors and still with front and rear sensors the radio still doesnt mute or lower when in reverse.
    i have a4 b8 2009 with 2g High
    https://photos.google.com/photo/AF1Q...ifg2LK8Z75u3nC
  21. #181
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    Front Parking sensor upgrade working. Pictures inside.
    Awesome thread - thank you !
  22. #182
    May 11 2016
    CA
    Help on PDC overlay on camera issue
    Quote Originally Posted by miztahsparklez View Post
    Hello,
    I have same issue in my 3G+ Q5 ie camera not working with PDC OPS settings with my rear only PDC and camera install. Can you share how did you get PDC graphics on camera view? My 09 module is 8K0 919 475 H . Thanks
  23. #183
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by andybq5 View Post
    Hello,
    You cant get pdc optic view working on retrofitted 3g+
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
  24. #184
    May 11 2016
    CA
    Quote Originally Posted by Gunnark100 View Post
    YeahI heard abysame and others giving up. I just came across this and its trying..
    https://www.a5oc.com/threads/audi-parking-assist-system.28170/
    - - - Updated - - -
    YeahI heard about same and others giving up. I just came across this and its worth trying..
  25. #185
    Oct 21 2012
    Earth...
    https://www.a5oc.com/threads/audi-pa...-system.28170/
    Cant see any solution there for retrofitted 3g+ and i would know :)
  26. #186
    Active Member One Ring Nemet_tt's Avatar
    Jun 29 2018
    România
    I have a 2011 a4 b8 with front and rear sensors and I installed an aftermarket camera, do you have any idea where to supply the camera with 12 v from the front sensors? that is, if I press the button on the board from the face sensors, the camera will also be powered
