Results 1 to 12 of 12
    Veteran Member Four Rings The_Auto_Tech's Avatar
    Nov 29 2010
    2001 Audi allroad 6MT
    Des Moines, IA
    Planning on purchasing B5 A4, want to lower it, what coilovers to go with?
    Hey guys, looking to purchase a B5 A4 this weekend. It's on stock suspension right now and I want to get a set of coilovers and lower it. My B5 S4 has a set of Stasis Street Sports and love them, but they are quite pricey. I'm wanting to go cheaper on the A4 as it won't be put through the turns and is just going to be a nice looking daily driver. I know there's cheaper options like Vogtlands, VMAXX, Racelands, etc. but wasn't sure if you guys had any recommendations. Thanks!
    2006 Ford F-250 Amarillo Edition - MOARYLW - Mine
    2001 Audi allroad 6MT - Wife's
    Previous - MKIII Jetta, MKIV Jetta x2, MKIV GTi, B5.5 Passat x3, B5 A4 x2, B5 S4 x2, and tons of Domestic/Japanese crap
    - Cody T.
    Veteran Member Three Rings murdered APR a4's Avatar
    Jan 26 2011
    2002 Audi S8, 2003 Audi RS6, 2009 Audi Q5, 2002 Audi S4
    Hudson, Wisconsin
    before you get flamed, use the search box, you will find that most run with ST's
    2003 daytona gray RS6
    2002 avus silver B5S4
    2002 black S8
    2009 deep sea blue Q5
    Jan 26 2011
    Hudson, Wisconsin
    also you kind of answered with your s4 having them so gl
    2002 black S8
    Aug 19 2008
    Boston
    I ran BC Racing on my E46M3 they are about $1000 delivered height and rebound adjustable with shock adjuster extensions. They came with a one year replacement warranty and then if they break after that, you can purchase a whole corner for $95... I have a set sitting in my garage right now that were destined for my A4 sedan, they will be going on my Wagon as soon as I get it
    Oct 02 2006
    Wadsworth,OH
    We carry FK coils which are great for someone on a budget. They offer adjustable ride height from 30-60mm. Check them out below.
    Free shipping is available on these coils as well!
    Click HERE to order or for more information.
    Jason
    Active Member Two Rings rbleka's Avatar
    Mar 14 2011
    Chicago
    i'm running bilstein pss9's and i love them. smooth ride and great handling. also cant beat a lifetime warranty iirc. I paid 1400 for them new. height & stiffness(without removing wheels) adjustability.
    98 30vQM -Bambus Metallic/Cognac - Anthrazite|18" A8 Flat Fives|Continental DWS|H&R 5/10mm|
    |6000K|50% Tinted '01 Tails|Debadged|35% Tint|Bilstein PSS9|Reiger Illuminated Shift Knob|Illuminated Engine Start|Roach Custom Intake|AEM Dryflow|Borla Cat-Back|Hardwood Trunk| Double Din Conversion|AVIC-D3
    Dec 05 2007
    The same option that exist on the B5 S4 exist on the B5 A4 platform. You can even place your B5 s4 coilovers onto the B5 A4 if you wanted to, as long as it is Quattro. And as mentioned before, I also run ST coilovers. Great bang for the buck, but I purchased mine when they released last year and am entitled to a lifetime warranty (what really sold me) vs 5 years. Warranty policies are a biggie with me when spending roughly over $100 on anything.
    When I was coilover shopping, the Votgland GT coilovers were at the top of my list. The GT version recieved better reviews than the Stasis Streetsports. But the regular version, not so much. Only thing holding me back was the price on them (came with 10 year warranty). Then the ST deal popped up and was just too good of a deal to pass up (made by KW).
    Oct 02 2006
    Wadsworth,OH
    This is partially correct.
    Yes S4 coil-overs bolt up completely fine but the spring rates are different to support the added weight of the 2.7T motor.
    This may cause issues with ride quality and how the car sits.
    It could be very possible that by even turning the coils all the way down you wont get the desired ride height as you want due to the springs not compressing enough since the 1.8T motor weighs less.
    Jason
    Dec 05 2007
    He wants coilovers, not a spring/shock combo where it would make a significant difference. Only difference would be the way the springs compress, with end results of a stiffer spring rate. I have B5 S4 coilovers on my 1.8t, and chose these units for that very reason (stiffer spring rates). I am not the only person who has done this, and don't regret my decidion one bit (was at first shakey of a too harsh ride quality, but that proved to be far from the case with my particular coilover choice). Placing 1.8t Quattro coilovers on a B5 S4 would cause an issue on the 2.7t, but not the other way around. Not so much if you were to place on coilovers for the 2.8 N/A Quattro onto the 2.7t. I have even noticed that some PNs for coilovers coincide for the 2.8 Quattro and 2.7t.
    To the OP, if you are going the ST route, they have now changed all the B5 platform with Qauttro to one unit. Meaning, the 1.8t, 2.8, and 2.7t all use the same coilover. This was not the case when I first purchased, and it seems they have changed up their line-up a bit (even in design).
    Quote Originally Posted by Jason@ECSTuning View Post
    Jason
    Just realised what you last posted. If this is the case, then a different coilover option should be in the works. And ironically, the new design of the ST coilovers have this flaw with a couple people. I have a very nice stance (I don't slam my vehicle), and have a lot of threads left in the front and a fair amount left on the rear.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Please search,
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Two Rings Jordan80's Avatar
    Feb 22 2010
    Saratoga, NY
    Running Vogtlands that were $800 shipped and I love them. Ride like coils that are $1k+
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Jason
    Your link for coils says they work with all B5 A4... The 2.8 can't be that much different weight then 2.7tt. But the coils are good for 1.8t and 2.8. You guys should work on your stories.
    I would look for a set of used coils in the classifieds.
    97 Audi A4 Laser Red 1.8t Quattro 5spd STOCK FOR NOW
