Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
  1. #41
    Veteran Member Three Rings Jurjen's Avatar
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    ^^^^ Yep, fits right in, carpet bulges a bit, hardly noticeable.
    b5 s4
  2. #42
    Established Member Two Rings crc364's Avatar
    Feb 11 2011
    GA
    Really worth it? I see these going for cheap.
  3. #43
    Senior Member Two Rings YnotS4's Avatar
    Jun 22 2008
    S4
    Chicago
    Totally worth it. It will expose the speakers as a weak link. There is more headroom and deeper base and better high end. Its not ADS or Soundstream etc but much better than the original factory piece
    Quote Originally Posted by crc364 View Post
    Stage 3 VAST TUNED / EV 14 injectors/ ported intake/ ARD bi pipes/ VAST meth/ h20 / AWE ICs / APR DP / AWE Twin 2 / VAST EFK /
    034 SLFW / 17Z w 300mm rear/ 2.0 CP ICM delete/ plus other stuff
    11.92 @ 122.07 with 1.6119 60ft .
  4. #44
    Feb 11 2011
    GA
    Thanks man, ill pick one up.
  5. #45
    Established Member Two Rings DynomiteTT's Avatar
    Oct 22 2011
    DALLAS
    Anyone know if this works for C5s and TTs too?
    I seem to remember the C5, B5 and TT all using very similar bose amps.. I could be wrong
    2002 Audi TT 225QC: Too many mods to list- NOW TTOASTED
    2002 Audi Allroad 2.7t: Mods: Vast stage 3 -, 517 trans:VB/TC upgrade. Arnott Gen 2 Air suspension
    2000 Audi S4- ASP Stage 3
    2004 VW Phaeton W12 Premier Edition: Mods: 19 inch black A8 W12 wheels,EBC Brakes
  6. #46
    Jul 19 2009
    Aspen, CO
    Hey sorry to bring this thread back from the dead, but did anybody do this mod and find out that the rear deck wasn't getting the right bass signals? I did this in my 01.5 A4 the other day and it seems like I'm not getting any of the lows sent to my subs. Everything else sounds great but the rear deck isn't getting anything below say 50hz and isn't nearly as loud as the rest. Its still getting sound but its really weak. Speakers and headunit are still stock, and the amp is from a 2001 S8. I also tried adjusting the hidden EQ settings to no avail, and the amp smells fine (not burnt out or anything) and everything coming from the rest of the speakers is clean and clear!
    Any ideas?
    2001 1.8T>APR Tune>Custom 2.5 in. resonated exhaust>3000k HID fogs>ebay short shift kit>B7 A4 sport and S4 Avus rims>ECS Porsche/A8 BBK
  7. #47
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    Is this also plug n play for non-Bose systems? I can't seem to find the 25pin harness in my trunk.
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
  8. #48
    May 08 2014
    CLFX, Denver
    Bump for edited question in post #47. Anyone know if non-Bose system is plug n play?
  9. #49
    Established Member Two Rings RicoSuave's Avatar
    Jun 15 2011
    '01 Audi S4
    ↑state, NY
    Quote Originally Posted by bmoreS4 View Post
    where from?
    Can't speak on his behalf, but I would assume any junkyard could source one for you.
    Might not be $50, but still cheaper than buying it off someone here.
    keep drooling, i'm spooling | flickr
  10. #50
    Jun 03 2013
    Nanaimo, BC Canada
    Quote Originally Posted by northcarohio View Post
    Any ideas?
    Had this same thing happen to me... I have the stock bose system with infinity reference in the rear doors, stock 6.5" parcel shelf subs, stock front components, and a kicker comp s 10" sub/hertz hcp1-dv spliced into the line-level wiring harness to the factory amp in the trunk. Up until today I was using the stock bose amp and I just installed a 200w A8 D2 amp. The sound was much, much fuller and sounded properly bassy with the stock S4 amp. The new amp seems to have a way different eq. The only different speakers the A8 has are the front door woofers/subs. Should I try the bose eq grounding wire on the back of my (stock) hu to see if that makes a difference? Surprised it sounds so much worse than the stock amp.
  11. #51
    Sep 11 2009
    NE
    That's because:
    This amp is EQed to not give any bass to pins 20-23.
    pins 14-15 are sub out pins for a subwoofer, I don't think S4 has a dedicated subwoofer like S8/avants (S4 avant probably has that!).
    pins 1-2 are mono loudspeaker which also gets lows but S4 doesn't have that.
    I actually have this amp in my allroad. Fronts get bass, rears don't but my subwoofer takes up the slack there so overall I actually have quite a lot of bass. I don't use pins 1-2 either. I had to move subwoofer pins on my allroad harness to new position since stock pinout was different.
    So....not all upgrades are necessarily proper upgrades
  12. #52
    May 09 2012
    Virginia
    Quote Originally Posted by julex View Post
    That's because:
    Thanks for the info. Did this swap and there was a noticeable loss of the low frequency. Wish I would have come across this first. The avant and A6 (with factory Bose) have separate sub boxes in the rear.
  13. #53
    Sep 11 2009
    NE
    Quote Originally Posted by jbain2 View Post
    Either way it will be in effect a downgrade since there will be a loss of bass from rear door speakers regardless of what you do... unless you crack the amp open and try to figure out how to change that, if that's even possible. They are fairly complicated animals.
  14. #54
    May 09 2012
    Virginia
    Yup. Put the factory amp back in.
  15. #55
    Jun 03 2013
    Nanaimo, BC Canada
    Haha damn well I suppose I'll put the old amp back in. Thanks for the great posts man, you had all the info that hours of googling couldn't find.
  16. #56
    Veteran Member Three Rings R1CH-5100's Avatar
    Jun 27 2005
    '13 Triumph Street Triple
    San Diego
    This is strange to me. I ran the stock amp like 7 years and when I switched to the D2 amp the sound blatantly much fuller. I had repaired my deck subs years back and with the D2 amp I have to lower the bass setting way down (about 3 notches from the bottom) because its so strong now. I can't speak about the the door speakers loss of bass though. I haven't noticed it as the deck speakers definitely pick up any slack.
    I'm probably just not a audiophile, but to me the stock system sounds better with the D2 amp.
  17. #57
    Senior Member Two Rings auditechnik's Avatar
    May 08 2010
    2001.5 Audi S4, 1980 Audi 4000, 2018 Audi A4 Premium Plus ultra S-line
    Sunnyvale, CA, USA
    4D0035225C == Audi A8/S8 200W Bose Amplifier = Plug-n-play for our cars
    Sorry for waking an old thread but I have new information to share that might be of interest to some of you.
    I have known for a long time that the D2 A8/S8 Bose amplifier is pin-for-pin compatible with the 2000-2002 B5 A4/S4 (sedan*) unit, and is also mount-compatible. But I have read mixed results from various places including this thread. I have been on the lookout to purchase the D2 unit to try, but it seems that (at least on eBay) most of them are in the UK and the shipping cost leaves a bit to be desired. As luck would have it, one came up for sale in a facebook group that I belong to, and it's located not far from me, so the shipping cost is minimal. I bought it and within 2 days it was delivered in great shape.
    * Someone correct me if I'm wrong, but looking at the Bentley repair manual wiring diagrams for the Bose systems, the Avants appear to have quite a different setup, and might not even use the 8D0 035 225 A amp at all.
    The basics: I have a 2001.5 Audi S4 sedan with Bose option. The stock Bose amp part number is 8D0 035 225 A. The D2 Bose amp I purchased has part number 4D0 035 225 (no suffix). Many people used the latter with C suffix but I don't know if there is any substantive difference. My car was originally equipped with the Symphony I radio, but I had retrofitted a RNS-E (8E0 035 192 J) Navi Plus instead.
    For simplicity, I'll refer to the S4's stock amp as "stock amp", and the A8/S8 unit as "new amp" from here on.
    Because I'm an audio engineer, I want to see real data just as much as I rely on listening to evaluate any piece of audio equipment. Thus after I removed the stock amp from the car, and before installing the new amp, I put both of them on my test bench for some frequency response measurements. This is important because the equalization curves are different and will impact how they sound. I used my Audio Precision SYS2322A Dual Domain audio analyzer to perform the measurements. I measured each of the six output channels on both amps. I used a bench power supply dialed to 12V DC, and connected the +12V to both pin 13 (power) and pin 25 (switched positive from radio), and the ground to pin 24. On both amps, pin 11 is also ground, but on the B5, the car's wiring harness ground goes to pin 24.
    For the measurements, I set the Audio Precision's analog output channel 1 to produce a 1Vrms output signal, which is swept from 20KHz down to 20Hz. This signal is fed into the inputs of the amplifier, and then the output of the amp is then captured by the Audio Precision's analog input 1 for analysis. The output channels are done one at a time. The results are as follows. I am only showing the right channel results here because the left channel is identical (except for the left rear, but I'll get to that later). The vertical axis of the graphs is set with a fairly high resolution (2dB/div) to illustrate deviations from flat prominently.
    All graphs, except where noted, is the stock amp on the left, new amp on the right (If your browser window isn't wide enough to show both graphs side-by-side, then they will appear stacked, the stock amp on top, and the new amp on bottom).
    Right Front output (for right door speakers including tweeter):
    Comments:
    - The gain of the stock amp (at flat ares of the curve) is just a hair under 16dB, the new amp is slightly higher than the stock amp, by about 0.5dB.
    - There is a bass rolloff, starting a little lower in frequency on the new amp but cuts off at a steeper slope than the stock amp. This helps to protect the speaker from excessive cone excursion and potential damage.
    - There is a notch at around 1.2KHz on both amps, but on the stock amp it's about 3.6dB deep whereas on the new amp it's about 1dB.
    - This notch is probably to equalize an opposite bump in the speaker's frequency response, but the amplitudes here are not huge.
    - The stock amp has a flat high frequency response, but the new amp has a sharp boost in the upper treble region, leading to a peak of 8dB above flat at around 15KHz.
    - The treble boost is a good thing for the B5, because I always thought that the stock front door tweeters' were lackluster. When I had the Symphony radio, I adjusted the upper band of the radio's hidden equalizer to maximum and that helped a lot. Now, on the RNS-E there is no such hidden EQ, and dialing up the treble control causes too much boost in the mid-treble region and the high treble was still a bit dull. This treble peak will go a long way toward "fixing" the treble problem.
    Note that the vertical scale of the new amp is is 2.5dB/div in order to accommodate the top of the treble peak.
    Right Rear output (for right door speaker)
    Comments:
    - As for the front right output, the stock amp's gain is just a hair below 16dB, the new amp is about 0.5dB higher.
    - The stock amp has a bass rolloff below 100Hz, whereas the new amp has it starting at about 150Hz, and is a steeper curve. Interestingly, the rolloff stops and rebounds up to about -11dB from flat at around 50-63Hz, before falling off again below that.
    - This shows that the rear speakers will receive less bass energy. I don't think this will be of any detriment to the sound, because even with the stock amp, I found that the rear door speakers to be bass-shy anyway. I like to set the fader to about 10 o'clock position to let the front speakers do more of the work. This gives a more natural stereo image and reduces the amount of boominess from the bass speakers on the rear deck. Sitting in the front seat, the difference of the two rear door speaker curves actually didn't sound at all dramatic.
    - On the stock amp, there is a dip in the response at around 400Hz, and about 2dB deep. On the new amp, there is a dip at 1KHz instead, also about 2dB deep. These are not large amounts so the audibility is minimal.
    - The rest of the midrange and treble spectrum are flat to 20KHz on both amps.
    Right Bass output (for right rear deck speaker)
    Comments:
    - It's obvious that on both amps, this output is meant to be a bass-only channel with most of its output in the low bass region. On the stock amp, the bass plateau is 32Hz-60Hz, on the new amp, it's 32Hz-70Hz. But on the new amp, the gain of this frequency region is about 1.5dB higher and flatter.
    - Above the low bass region, the two amps exhibit vastly different response characteristics.
    - On the stock amp, it dips to -9dB from flat at about 180Hz, then rises again to -4dB at around 500Hz. Then it falls off quickly above that.
    - On the new amp, it dips to -6dB at 100Hz, but rebounds to -5dB at 150Hz, then goes into a shallow drop above that to a minimum of -13dB before rising to a treble boost of about 4dB at 20KHz.
    - The reble boost is probably of no consequence on the B5 rear deck speakers, because they are woofers with non-existent high frequency response.
    - The 100Hz to 400Hz area is interesting, because the two amps exhibit just about the opposite behavior. The stock amp is a trough whereas the new amp is a bump, although both are in low amplitudes. I think the result of this is that whatever low frequency loss there is in the rear door speakers (between the stock and new amps), it's made up for here. The new amp's missing peak at 500Hz should probably help to make the low-midrange region a bit cleaner.
    I mentioned above that the left channel graphs are the same as the right channel graphs, except for the rear door speakers on the new amp (the stock amp has identical curves left and right). The left graph below shows the left rear output while the right graph shows the right rear. The right rear is already shown above, but repeated here for ease of comparison.
    New amp only: Left Rear vs. Right Rear output (for rear door speakers)
    Comments:
    - I already described the right rear response above. Compared to the right rear, the left rear's frequency response has a similar shape with a bass rolloff and the midrange notch at the same frequencies.
    - However, in the bass region, the left rear has about 3.5-4dB less output than the right, and in the upper midrange to 20KHz, it's 6dB less.
    - This creates a channel imbalance, which is curious. At first I wondered if this was an anomaly, so I retested several times and got the same results. I also thought that it might be due to a malfunction. But after checking other performance parameters and doing listening tests, I now think that this is by deliberate design. When sitting in the driver's seat, the far side rear door speaker has more output, but the near side door speaker is closer to the ear so they actually sound well balanced.
    Before the bench tests, I listended to a few recordings on the stock amp to establish a baseline of sonic character in my memory. After installing the new amp, I played the same recordings to hear the differences in sound.
    One thing that was immediately apparent was the change in treble response. I no longer have to tweak the treble control on my RNS-E to maximum to get the "sparkle" from the front tweeters. The sound is now much more extended in the highs, cymbals crashes have the proper brilliance and attack, etc. Now I set the treble to only 2 notches above flat and I'm still experimenting with the optimum setting, because different recordings vary. But in my opinion this is the biggest improvement by swapping the amps.
    The next thing that is almost as dramatic is the cleaniness of the sound, particularly when the volume is turned up. I think the 80W output of the stock amp vs. 200W for the new amp is at play here. Since the amp has 6 outputs, and the gain is approximately the same on each of them (ignoring some small dips and the treble peaks from the EQ), it's fair to say that the output power on the stock amp is 13.3W per output, whereas it's 33.3W per output on the new amp. Neither of these are big numbers, but keep in mind we're driving 2 ohm speakers, so the equivalent SPL is twice that on a standard 4 ohm car system, assuming the same speaker efficiency. The new amp's added power means that even when you crank the volume up, you are much less likely to drive them into clipping. The amplifier will operate in a low-distortion zone for cleaner sound.
    The bass response, surprisingly, also sounded better than the new amp. It's not more or less bass, it's the quality of the bass that is improved. I think there are several factors at play here:
    1. The steeper rolloff of the response at the front door speakers eliminate sub-bass cone movement, so there is less modulation of the midrange frequencies. There is no perceived loss of bass at the front speakers. In fact it sounds just as strong or perhaps slightly stronger than stock. Just don't expect to hear 32Hz notes from a pipe organ or synthesizer.
    2. As mentioned above, the higher bass rolloff frequency at the rear door speakers is more than made up by the rear deck bass drivers. The bass drivers are driven with slightly more gain and a different upper bass response that tends to "fill in" where the rear door speakers leave off.
    3. Higher amplifier maximum power output.
    Overall, I am very happy with the swap. Your mileage may vary of course, depending on which radio you have, whether you still have the stock speakers, and which version of the D2 Bose amp you have (not sure if it makes a difference). Without ripping apart the system and doing major surgery on wiring, and mounting aftermarket amps and speakers, I think this mod is a good bang for the buck. It is also a simple installation, and keeps everything factory and tidy.
    http://www.tikan.org/ti/audi/autiq/bose_amps.jpg
  18. #58
    Jan 11 2007
    Salt Lake City, Utah
    ^^^ Wow, excellent post. Well done.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
  19. #59
    May 08 2010
    Sunnyvale, CA, USA
    Thanks! :)
  20. #60
    Feb 20 2012
    Portland, Oregon
    Does anyone know what the wattage of a c5 a6 or rs6 Bose amp is and if this upgrade to the d2 amp is compatible
  21. #61
    Apr 07 2011
    Home of the mighty beaver
    any thoughts on using one of the two sub outs on the D2 amp with one of these? 4E0035412A
  22. #62
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Sound is a very subjective thing--TRY this 76567656 as a start.
    I'm sure you know the numbers range from 1(min) to 9(max) with the factory setting at 55555555
    ALSO the OE speakers are a bit limiting---then again the interior of an automobile is not the "best" place for quality sound.
    FWIW- I changed my speakers a LONG while ago to a set of 2 ohm Infinity Reference speakers---6032CF for the rear deck, 4022i for the front door and 5022i for the rear door.
    I'm not sure these are still available.
    I'm surprised these amps are still available on the cheap.
  23. #63
    Oct 28 2018
    Chicago / Winnetka
    Quote Originally Posted by LJS View Post
    So I upgraded my speakers to the same and will do the amp upgrade on a B5 S4 Avant. It sounds like there is an issue with lost bass in the sedan, but is the Avant wired more like the S8 to utilize the sub in the rear?
  24. #64
    May 08 2010
    Sunnyvale, CA, USA
    As far as I know, B5 Avants don’t even use this amp at all. They have a different setup including the rear sub.
    By the way, there is no bass loss on B5 sedans with Bose. I’m running this amp in my ‘01.5 S4 and bass is fine. See. My measurements in another post above.
