Page 1 of 29 12311 ... LastLast
Results 1 to 40 of 1153
    Oct 14 2009
    Okinawa Japan
    (Draklore's) GT3071R Big Turbo Build and DG Avant Project
    So I' got this gt3071r and I've slowly been working up to a big turbo. It just came in tonight and I'm pretty stoked to put it in! I will be diy just like everything else on the car so I figured I post pics as things came together cause I really couldn't find much for the 2.0t gt3071r as far as build up threads...
    car like a year ago lol, sorry I'm not gonna pull out a photo of it with that grille! I'm sure someones got it saved in a special folder hahaha
    put in the fmic, I cleaned off the Godspeed cause I thought it was gay like a week later.. Lol
    went to a 3" exhaust setup. I think was like the third diff setup I ran on the car!
    installed the BSR opti flow intake and heat shield.
    tore a hole in my g dv
    did my own PVC revamp, works amaZing!
    got my gt3071r kit in today just trying to figure out the puzzle, came with knock sensors? And two weird step down pieces?? Right here...
    don't know what he used those for? Also I'm missing a bunch of in between stuff like my gay grille tha I bought at first. Then I got tuned stage 2 revo at waterfest. I have the kmd hpfp. Also installed a nuespeed torque damper and nuespeed underdrive. And right now how im going insane in a tuner dead zone in Biloxi ms! Right now I'm waiting to get a diverter valve relocator and some 1/4 silicone tubing. And then lastly im wondering what I'm gonna do because the guy who had the kit previos to Geoffafa put a different flange on the test pipe??
    Oct 14 2009
    Okinawa Japan
    car looks like this now :-)
    Oct 14 2009
    Okinawa Japan
    Horrible pic of the back
    Veteran Member Four Rings pw211's Avatar
    Dec 14 2008
    Bay Area
    Where you were when you first came here <<<<<<<<<<<<<< where you are now.
    Not a fan of the uber blacked out, would love to see you lost the headlight tint, but its a huge step from where you were haha. Don't like the bumpers now that I see them....
    Almost had it. At least it will be quick
    Pat
    F.T.W.L.T.B.D.W.I.C.T.W
    P.I.I.T.B
    IG: pwwhite
    "I bet if Sean posted a picture of toast it would get 50 likes. And more than 3 people would say 'specs?'" - Solarsuplex
    Jul 15 2009
    CA
    VERY nice....................I might just make that my screen saver if that's ok. Very well done. How much power do you think you're making?
    Veteran Member Four Rings MCT9891's Avatar
    Jul 06 2009
    2008 VW Jetta Wolfsburg 2.0T 6DSG
    Staten Island, NY
    Can't wait to make my build thread. Good luck! And thanks for the rs4 injectors!
    Oct 14 2009
    Okinawa Japan
    i will try to get some hd pics up, as you can see its iphone qaulity lol. not sure how much power, its bassically stg2 revo now, i might go to there stg2+ tune while i wait to get the rest of the pieces for the turbo, bassically im finding out now that they have no file for the gt3071r so i am going to either try to make it by with a ko4 revo file until i can afford to get vast or unitronic. the tune is the only thing holding me back, spent all my money on the parts up to this point lol
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    DO NOT, I REPEAT DO NOT BUY the ATP DV relocator as it is NOT compatable with the piston DV you will need to contact Eurojet for their S3 Dv fitting!!!!! I battled this for a while until I figured out that it does not make a complete seal....
    http://www.eurojetracing.com/Product...Code=MK5DV%2DK
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    B7 RS4
    Québec
    Looks good, Keep it up.
    Damn those tires are thin, whats the setup?
    B7 RS4
    Oct 14 2009
    Okinawa Japan
    Quote Originally Posted by viziers View Post
    vizi
    Holy cows, thank you so much, I was literally about to purchase the ATP one when I saw this post!!! I have seen that they don't mate with the forge dv... Glad I didn't make that mistake! Thx for the link
    Oct 14 2009
    Okinawa Japan
    Learned something new, found out the flange on the turbo test pipe is a "v-band" found the hardware to convert my exhaust to the flange for about 60$ 30 for a clamp and 30$ for the flange! Found it at >>http://vibrantperformance.com/catalo...Path=1022_1125 thanks Tucker!
    -Shane Drake-
    >DRAKLOREs Build<
    Senior Member Three Rings rick1.8t's Avatar
    Jun 15 2007
    2007 Audi A4 S-Line, 2003 Audi A4 GTRS
    Hillsboro, OR
    I remember the day you posted that post with the disgusting grill....... Great progress and amazing car now! Even though I know everyone will say "its your car what you want" I'm glad you went with "what looks good" Can't wait to see the final product. Great job man!!! +1
    Oct 14 2009
    Okinawa Japan
    Also found the solution to my dv problem, was looking at AWE tuning dv adapter housing which I'm 90% sure fits the revision d dv. But I don't think they will part there kit which I don't need any of it. Soo was looking on craiglist and found a forge splitter... For freakin 50$ it's gotta be a scam but I emailed him anyways lol
    http://nh.craigslist.org/pts/2347983979.html
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    Nice! Glad to see another build popping up! You're car was my background for a while btw, that first pic "as the car sits now :-)"
    I like what you did with the whole blacked out theme, it intrigues me
    RIP QG TI B7 A4
    Oct 14 2009
    Okinawa Japan
    Quote Originally Posted by Mc Suly View Post
    225/35/19 had falken 452s.... Never buy those tires IMHO. Broke three belts in three weeks... running exclaims, not bad for the money.
    Thanks LEO! I change my mind on this car weekly, I think I know what I want, and im so impatient I do it or half ass it, then I see a member ride and get sick of what I've done and hate myself for it... Thus explains the amount of bodywork I really need! Maybe if I spent less time touching the damn thing lol
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2009
    Okinawa Japan
    Found some v-band flanges and silicone piping at http://www.siliconeintakes.com/ . Also got a clamp. Now I'm just waiting on a reply about the forge splitter and should be ready to start assembling this beast. All in all should start taking form in a week when I start to get pieces in. In the meanwhile I will be contacting revo, vast and Unitronic again till I figure out the route I'm gonna take for the tune.
    Oct 14 2009
    Okinawa Japan
    Heres something some people prob won't thumbsup on but it's my car lol here's my clean gps install
    And here is a
    Pic of my headlamps at night... I'm sure 90% of the people on here will not like it because it's not fly. But I like it, and they can be turned off via a switch so I don't have to run them when I don't want to.
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2009
    Okinawa Japan
    Here's a pic from when the fk coils went on, pita!!
    Oct 14 2009
    Okinawa Japan
    Idk why but I never have my nikon on me when I decide to stop for a pic! Would def love to have some of these pics in hq!!!
    Mar 18 2011
    mk2 gti golf currently in restoration
    n-ireland
    Quote Originally Posted by pw211 View Post
    x2 bumpers are awfull and the ricer exhaust definate no no.
    but its only my opinion oh and pw211 but as long as your happy
    Oct 14 2009
    Okinawa Japan
    Honestly I wish I could have that money back from the bumpers. I hate the front, and don't mind the rear, but with the money I spent on them I prob coulda bought different oem style that i would like 100xs more, and it's cool u don't like the exhaust lol it's good to be different sometimes :-)
    -Shane Drake-
    >DRAKLOREs Build<
    Mar 18 2011
    n-ireland
    id say if you were going for a time attack look with the exhausts poking out through a carbon diffuser the would look classssss
    Oct 14 2009
    Okinawa Japan
    Haha I guess? Cool man lol
    -Shane Drake-
    >DRAKLOREs Build<
    Jan 27 2007
    NC
    Quote Originally Posted by DRAKLORE View Post
    Your best bet it to call Joel at Eurojet as he will prob sell you just what you need!!!!!
    vizi
    Oct 14 2009
    Okinawa Japan
    Thanks again Vizi, called Joel just now and left a message, the more I think about it, that is the route I would rather go :-) thank you lol
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2009
    Okinawa Japan
    Called Paul again at revo and it's a big let down, not only do they not have a file for the 3071r they don't even have a file for the k04 something I wish I knew before I got revo last year. I am going to call vast then Unitronic, but I fear no matter what they tell me it will be a bit before I can afford to get tuned by them
    Oct 14 2009
    Okinawa Japan
    Called vast and Unitronic, both quoted me right around 950$ for bt software, Unitronic had a lot of info and really sounded like they had everything ironed out for every circumstance. Also Unitronic said it would be in and out if I called in advance before going in to get flashed, vast Is going to call me back but said they would need it for about 2-3 days. I'm still not sure, I'm sure both these companys are very reputable! Now it's time for me to save up! Anybody want to buy my sps lol maybe I could even trade outy revo ecu? Not sure I'f that's possible but I'd rather someone enjoy it than it go to waste lol
    Jan 27 2007
    NC
    I'm pretty sure Vast wants your car for the three days is so they can make sure everything installed on the car is correct and not leaking (they basically check your work (another set of eyes) and more experience)..Then a day to dyno tune/street tune your car while making sure nothing goes wrong the the install.... and get the most possible where Uni gives you a generic tune that all use....(Nothing against Uni as they have been known to make nice numbers!!).....
    With Vast you get a straight custom tune for YOUR car specifically.....
    vizi
    Oct 14 2009
    Okinawa Japan
    I'm leaning towards vast because of that reason, after talking on the phone again it sounds like they also know there stuff and are a quality company. I also called back Joel at eurojet. He checked their inventory and they have an even number of adapters to hoses so he can't part it out, he said there's are billet machined but ecs has a cast one that is essentially the same. He hooked me up with the part number and I'm about to order it. Here is the link for fellow ziners who want the info!
    http://www.ecstuning.com/Search_VW/06f145751/ES1042108/
    -Shane Drake-
    >DRAKLOREs Build<
    Jan 27 2007
    NC
    If thats for the S3 which it looks like it is that is the alternative one I was going to tell you about if Joel couldn't come through for (Can't blame them for not breaking up a set unless it was for a defective part that broke on their customer) the problem with the one from ECS is the backorder date if you haven't noticed aready (I needed mine real quick)....
    vizi
    Oct 14 2009
    Okinawa Japan
    Haha that's just it! As I'm placing the order I noticed the ETA, makes it a no go for me because I pcs to robins afb a week before the eta, Can't have the next people living here get it
    -Shane Drake-
    >DRAKLOREs Build<
    Jan 27 2007
    NC
    This is your next best bet then. Buy my ATP adapter and use your Diaphram DV and maybe buy an extra Diaphram DV as a spare or 2 (Aduizine classifieds or Vortex classifieds) until you can get the correct updated S3 aadapter.......
    vizi
    Oct 14 2009
    Okinawa Japan
    I see your trying to get rid of that ATP one lol, my diaphragm dv has a hole in it. And lookin in the classifieds I didn't see a one, called the dealer and the said unless it was one that was left on the shelf they don't have any and don't expect any other dealer to! I'm sorry that ATP screwed u on that one! I wonder if a machine shop could take off some of the mounting surface so that our d dv would work with them? Also got some news from eurocode tuning, it seems he has a direct connection to revo in the uk... Can't really say what's in the works tho
    -Shane Drake-
    >DRAKLOREs Build<
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    What do you do in the AF?
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Oct 14 2009
    Okinawa Japan
    I'm training in RF transmissions, basically radio... But much much more complex lol
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2009
    Okinawa Japan
    Going to get the 2+ flash tomm..... I can't promise anything. But for you revo tuned cars out there wanting to go big turbo but don't want to swap tuning companies, there just may be a solution... :-) :-) but no promises
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2009
    Okinawa Japan
    All the parts come in on the 10th and 11th. In the mail from ecs are some exhaust hardware, a new g17 (because mine got ripped
    Off) some 4mm silicone, a forge MBC. Also have a Forge 007 coming with all the springs :-) I will be reselling it as soon as I can get the s3 dv flange. All in all almost there except tune. Now I plan on putting everything on before sowo regardless of tune. Still no word from eurocode :-/ but I need some pointers, like...
    1. Should I run the rs4 injectors on the stg2+ tune?
    2. How should I adjust my timing and boost via the sps tuner to be safe with the setup?
    3. Should I limit my boost below 10psi with the MBC?
    4. Should I let my forge n75 do it's job and just use the MBC to prevent overboosting?
    5. After the tune. Is 21-22psi a safe limit for a motor with stock internals, and would putting in ARP head bolts and a new gasket hold me over until I can afford connecting rods?
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2009
    Okinawa Japan
    Waiting for tune $$$ then will put this badboy on! I will prob build the bottom end as well :-)
    -Shane Drake-
    >DRAKLOREs Build<
    Jul 06 2009
    Staten Island, NY
    Nice! so am I. I was thinking rods, meth, retune and hopefully be happy enough to not spend any more money lol.
    Oct 14 2009
    Okinawa Japan
    Got some parts in today :-) too bad the forge MBC ended up being a bleed type... not what I was expecting... Oh well it will be a bit before I can get her tuned!
    -Shane Drake-
    >DRAKLOREs Build<
