Originally Posted by
horchamol
Hi Folks,
it's been a long time since my last visit here. I am currently retrofitting ACC to my B8 2.0TDI 143hp w/o quattro manual gear. I bought a second hand radar sensor from a B8 allroad (quattro), manual gear and trailer hitch. In order to find out how to code ECU 13 correctly I am asking you if anyone having installed ACC could post his/her coding of ECU13 including some information on engine, gear and special equipment (trailer hitch, etc.).
So far I have this available:
A4 CDNC 2.0l TFSI Coding: 00C7E0 Automatic Gear
Q5 CCWA 3.0l Tdi Coding: 0079C0 Manual Gear
S5 - Coding: 002BA0 Automatic Gear
S5 - Coding: 002B99 Automatic Gear, trailer hitch
A4 CAHA 2.0TDI Coding: 00EEE9 Manual Gear, trailer hitch, Avant
A4 - 2.0 TDI 143hp Coding 00A0C9 Manual Gear, trailer hitch, Allroad (quattro)
Tnx a lot!
Best regards from Germany
Hi guys,
although i have dedicated myself to this particular transformation, it is a fantastic option for own cars.
I have finished all installations and programming of various modules, without encountering any errors with the exception of the engine control unit:
Address 01 At the time i am going to set the new bits i always get the same error:
31 ...
I noticed that you also have the same type of engine of my A4: CAGA, 2.0 TDI 143 hp and then I'd be infinitely grateful if you could indicate which codes you have entered on your ECU: which bits have changed?
Below my details, including current programming of my unit: Address 01: Engine (CagA-J623) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 C HW: 03L 906 022 B
Component: R4 2,0 L EDC H01 3216
Revision: - H01 **-
Coding:
0104002C02072118
Below you back instead of my programming from a radar module A4 Avant TDI 2008: 0079C0
Thank you so much for everything, I no longer know how to do otherwise...
Best regards Enrico
