The chemicals within plastic cleaners can actually be harmful to the film if left on for an extended period of time. Certain propellants within aerosol canisters are responsible for excessively drying out the pores of the clear bra, which then leaves them open to the elements and yellowing.
Plexus tends to yellow just take a look at the white nozzle after some time; it actually turns yellow. It also contains butane, which dries out the micro-pores of the urethane film
Maintenance / Care
• Premier Protective Films - PF1 TT is an advanced agent that attacks the marks and transfers at the micro-level to loosen up these particles so that it may be safely wiped off with a clean micro fibre towel. Most importantly, it can be utilized on paint protection film with a clear coat safely. Simply clean the area in which it will be applied. Next spray on and in five seconds; begin wiping with a clean micro fibre towel. Repeat these steps as needed.
• Zaino Z-CS Clear Seal or PF1 Crystalline - wipe on, and wipe off (WOWO) walk away, no buffing, just allow to air dry. Use on paint, glass, wheels, plastic, clear bra, or trim for the protection, durability, slickness, and gloss. All surfaces are protected against potentially damaging exposure to sun or ultra-violet light with UV inhibitors.
