Results 1 to 23 of 23
    Active Member Two Rings hjian23's Avatar
    Nov 20 2010
    2011 Audi S4 Premium S-Tronic
    Ontario,Toronto
    Burnt smell from the car after high rpm
    i just done break in at 1500km
    and i went over 5000 rpm today, after i release gas pedal, i got burnt smell for few seconds.
    is there any problem with my car?
    sorry for noob questions.
    Thank you.
    2011 Audi S4,
    Brilliant Black, Black Silk Nappa, Audi Sport Differential (Audi drive select Lite), Bang & Olufsen Sound System, Navigation, Carbon Fiber inlays.
    20% All around Tinted. AWE resonated Exhaust. C-Style Carbon Spoiler. Smoked Taillight, White Fog, Stvbek Lip spoiler, Black Optic Grille.
    Coming Soon: Roc-Euro Intake, Forgestar F14, KW v2
    Aug 18 2008
    Florida
    Yup, sounds like you need a new muffler bearing ASAP.
    '24 RS3 Daytona Grey Pearl
    Nov 20 2010
    Ontario,Toronto
    Quote Originally Posted by joneze93tsi View Post
    what if it comes from the hood?
    2011 Audi S4,
    Aug 18 2008
    Florida
    Quote Originally Posted by hjian23 View Post
    I'd still go to the dealer and ask them to check the muffler bearings.
    If it was beat on past 5000 rpm's they tend to get hot and get overheated easily.
    Veteran Member Three Rings redrocker55's Avatar
    Feb 21 2010
    St Louis, MO (USA)
    This is a joke right?
    2016 S6 Prestige, Misano Red Pearl, Driver Assist, B and O, Sport Pkg, Carbon Atlas, Black Headliner,
    Alu Kreuz, 034 Motor Sport DSG Insert, RS7 Intake Box, APR Stage 1 w/ Dongle
    Sold 2010 S4 Brilliant Red DSG with Prestige Pkg
    Sold 2008 VW GTI DSG
    Veteran Member Four Rings dumpedb5's Avatar
    Nov 22 2009
    B5 Imola Avant and a MK4.
    City Of Roses
    No all seriousness.
    SQUISHEDTWINKIE
    Jan 10 2011
    Boston, MA
    Edit: S-Tronic - go see the dealer.
    Does it smell like burnt newspaper? If so, then you probably glazed the clutch disk slightly. As long as the smell goes away and there's no loss of power then you're fine. If you don't like that burning smell then make sure you're not slipping the clutch at high (>4500) RPM. If it happens a lot and you aren't slipping the clutch intentionally or accidentally, bring it back to the dealer and ask them to check the transmission synchros.
    My 2010 S4 actually had a problem at about 2500 miles where I would get that smell no matter how careful I was when shifting. Audi ended up keeping my car for about 5 weeks while they replaced the entire tranny before the center differential because the engineers were baffled by the problem.
    2010 S4 Prestige 6MT
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    When will owners learn that waiting until the car has 1500K or 1000 miles to take the engine over 5k is just not good or the right thing to do to a new engine. Now that I have vented, the smell could be from oil, coolant or clutch. Probably nothing bad. PLEASE!!!! run the engine WOT(gas pedal to the floor) to the red line MORE THAN ONCE, followed by engine braking(let the car cost back to speed in gear without using the brake pedal) and try to get the piston rings to seat ASAP before it is too late and you end up with a car that consumes more oil than it should. You need to do this multiple times/day for the next week or so. I assure you, that if you take the car to the red line, NOTHING unusual or bad will happen. You've been babying this engine too long.
    Nov 20 2010
    Ontario,Toronto
    Quote Originally Posted by Matt427 View Post
    I can't explain the smell, but im sure its not like burnt newspaper. it only happen once, and its gone after like 3 seconds.
    i did a research and most people said its just the engine overheating due to high rpm.
    Thank You for you advice. it really helpful. so DSG is different than 6MT for the fact?
    2011 Audi S4,
    Nov 20 2010
    Ontario,Toronto
    Quote Originally Posted by Dr GP View Post
    this could be true becuz i never went to red line. i did a soft break in, not hard.
    2011 Audi S4,
    Feb 21 2010
    St Louis, MO (USA)
    Could you have sucked up a plastic grocery store bag that is melting on the exhaust? I've had this happen before and it is definitely a burning smell that goes away pretty quickly after you shut down the engine. Eventually it goes away as it melts off...the high speed runs Dr GP will help burn this off if that is what is causing the smell.
    Nov 20 2010
    Ontario,Toronto
    Quote Originally Posted by redrocker55 View Post
    the smell gone while im still running the car at higher gear and low rpm.
    2011 Audi S4,
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    did your passenger let out a 1 cheek sneak? Sounds like it oxidized quickly and was gone. I'd look for a mark on the front seats/
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    GUYS GUYS GUYS. We know that muffler bearing only fail at 8k RPMS. the smell coming from under the hood MUST be from low BLINKER fluid. Check that, top it off and you should be all set!
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Veteran Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    Yep, like the others said, if it were a 6MT clutch is a very distinctive odor, every enthusiast will smell it from time to time, the main rule is not too often or you will need a clutch job.
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Bridgestone RE-11 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI-5mm-Fr+10mm-Rear & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, Seat Bins, Trunk Triangle, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    Quote Originally Posted by seanj130 View Post
    No, No, No. Come on man, it's obviously the rotator splint!
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Nov 22 2009
    City Of Roses
    New apex seal!
    SQUISHEDTWINKIE
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    must be the clutch if it is the 6MT.
    Veteran Member Three Rings DATZ's Avatar
    Oct 17 2010
    Northern NJ
    Quote Originally Posted by helix139 View Post
    __
    Quote Originally Posted by George Costanza
    He needs a new Johnson rod!
    2015 S4 - Sepang Blue - 6mt - Black/Silver Nappa - Sports Diff - Black Optics - B&O - Tech Package - Carbon Atlas
    Bilstein PSS10 - Milltek non res - Eurocode sways/links/AluKreuz/STS - StopTech Trophy 380mm BBK - APR intake
    Veteran Member Four Rings Chestlock's Avatar
    May 30 2010
    Victoria, BC
    I was waiting for this. It's like Doc's kryptonite
    Aug 18 2008
    Florida
    Firm believer in both a hard break-in and regular thrashing. It's good for the girl, she was built for it.
    My a4 is a prime example 106k miles of what some might call "abuse" and she burns no oil and does everything better than new.
    Get out there and drive the car like it was built to be driven.
    Veteran Member Four Rings CBRmatt600's Avatar
    Mar 15 2009
    2011 S4 / 2008 BMW X3
    Atlanta
    I'm at 400 miles and saw redline about 6 times yesterday. Open that car up or you will regret the results.
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    Quote Originally Posted by Kandiru View Post
    just caught a whiff of mine yesterday...lots of fun.
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
