Results 1 to 20 of 20
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    stud conversion kit?
    http://www.wheeldude.com/catalog/pro...oducts_id=6318
    would this work with our cars? I am waiting for my grids to come in soon and was thinking about this and using lug nuts instead of wobble bolts. Would this work?
    Veteran Member Four Rings Dangler's Avatar
    PA
    here is the issue, the bolt holes on the grids are for m12 bolts, we use m14. Also the bolt pattern on the grids are 5x114.3 vs the audi 5x112. So if you use those bolts, you still need to drill out the bolt hols to 5x112 on the wheel because the stud positions will be 5x112. All these studs allow you to do is run m12 tuner lugs that you see commonly on jdm wheels. Though if you find wobble nuts with an m12 internal thread. maybe this will work, but i haven't researched wobble nuts much.
    Also if you try and run wobble bolts, you still need to open up the holes to about 16mm from what i believe they are 14mm right now, because you need 14mm wobble bolts, and they won't go through the holes in the wheels.
    F.T.W.L.T.B.D.W.I.C.T.W
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by Dangler View Post
    so are these the 12mm you are talking about?
    http://www.ecstuning.com/Search/Wobble_Bolts/ES2142849/
    or these at 14mm
    http://www.ecstuning.com/Search/Wobble_Bolts/ES2130074/
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Jhm sells stud conversions that look like it stays m14 on both sides if I were to do it I would use those.
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by martin0079 View Post
    http://jhmotorsports.com/shop/catalo...886caa98b6d520
    anyone? to me it looks like it will still be a 5x112 but I don't know much about this.
    Jun 19 2009
    17 ram 1500
    Hartford CT
    So I am going to do this to make them work.
    - 14mm to 12mm stud conversion
    - PCD Variation (Wobble) Lug Nuts,12x1.50 Threadpitch
    - 73 To 57.10 Hub Centric Ring
    should be all set
    Oct 16 2008
    South Florida - Ft Lauderdale
    and great shimmy in the horizon
    Phil
    Veteran Member Four Rings S4 Big Head's Avatar
    Dec 09 2009
    2000 Audi S4
    Tri-State area
    Quote Originally Posted by groundround View Post
    should be all set
    Yes, that will work.
    B8.5 Monsoon Grey Allroad - Airlift 3H / BC Forged Wheels
    Anthracite B5 S4 6MT //J-Fonz Tuned - SOLD
    Flickr
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Phil
    great shimmy?
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Phil means: "Don't drive over 33.5 MPH or your fillings will fall out".
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by A4 Centaur View Post
    should be fine, don't see why this would cause vibration.
    Veteran Member Three Rings misterjj2u's Avatar
    Apr 26 2008
    2007 A6 Avant
    Newport Beach
    Raven MS sells stud kits too. Just another option.
    Sold - 2005 A4 Avant, B6 with B7 front end
    Veteran Member Four Rings MCT9891's Avatar
    Jul 06 2009
    2008 VW Jetta Wolfsburg 2.0T 6DSG
    Staten Island, NY
    what he said is true, BUT... I'm running 5x114.3 with using the OP's method.
    Is it safe? I would say hell yeah, with proper hub rings... I've gone 85 mph with no vibration at all. (remember, the hub takes all the weight of the wheel, not the bolts/nuts)
    Are wobble nuts necessary? No, they're about $80 more than regular lug nuts, but hey... some people like that peace of mind and I don't blame them.
    But I definitely say no to wobble bolts, they won't fit the sleeve of the wheel and re-drilling sometimes looks like shit.
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    Drill the wheels to m14. Get a m14 to m12 stud conversion. Run said wheels with said setup. Case solved.
    Dec 09 2009
    2000 Audi S4
    Tri-State area
    Quote Originally Posted by cam View Post
    I'm pretty sure the rota grids are already drilled to m14.. I know my Rota G Forces were.
    Using wobble bolts, you'd have to drill it out another 2mm to m16 to give the wobble bolts enough room to.. well, wobble... as Dangler stated.
    Flickr
    Veteran Member Four Rings Zac's Avatar
    Mar 26 2010
    B8.5 A4, MK6 Golf R, F30 330I, 06 Explorer
    So Cal
    studs ftw
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Yea gonna do the stud 14m-12m and use a lug nut. Also 73-57.1 hub centric ring
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    Did you get the stud kit yet? if yes, wonder where did you buy them?
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Three Rings digitalAUDI's Avatar
    Apr 14 2010
    Union, NJ
    I ran conversion studs last year with my friends GSR wheels, 18x8.5 - 5x114.3 with 245/40-18 and his stock lug nuts and the car ran just fine. Ran well over 33.5mph and no shakes or shimies...
    Current: 2004 Audi Allroad 6MT, APR Stage 1 (for now)
    Previous: 2006 Audi A4 6MT, Revo Stage 2, 034 Motorsports HFC, B&B Performance Exhaust, Tein S.Tech Springs, RS4 Rear Sway Bar, Upgraded DV, CXRacing Intercooler w/Piping, TSW wheels
    Did you miss a 1 there and meant to say 133mph?
    Anyhiw, where did yiu get yoyr stud conversion kit?
