    Veteran Member Three Rings Satummoo's Avatar
    May 04 2009
    Boulder, CO
    Bought some 18" OZ Ultraleggera off craigslist - How do I tell the offset
    I got a really good deal on some ultraleggera's from craigslist but I don't know the offset is. They came off of an A3 which I know they have a higher offset than an A4. Unfortunatly, there are no markings on the wheel that tells the offset, is there anyway to tell? I'm hoping that they are 35 and not 45 as I don't want to run spacers.
    2014 Jetta 1.8t 5spd
    Just OEM+
    Veteran Member Four Rings vbrad26's Avatar
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    you sure there is nothing stamped on the back?
    and you can always measure offsets...
    https://www.rsracing.com/tech-wheel.html
    Mar 26 2007
    Colorado
    put them on your car, it is pretty easy to tell if they are +45 or +35 in relation to how flush they are
    CURRENT:
    2021 Atlas
    Veteran Member Four Rings GA42.0T's Avatar
    Jul 26 2010
    Atlanta, GA
    Quote Originally Posted by vbrad26 View Post
    Quote Originally Posted by vdubjetta02 View Post
    both these
    Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
    S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | S4 Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi | 034 Catch Can. Go: Still Stage Zero
    Veteran Member Three Rings $lick's Avatar
    Nov 06 2009
    2013 Audi S6 Lexus IS300 Turbo
    Chii
    it should def be stamped on the back of the wheel
    ive seen some with 32 offsets as well so it might be a little harder to tell 35 and 32 apart
    -Mike
    2013 S6
    APR Tuned / Lowered / 20x10 Rohana RF2 / Custom Dual K&N Intake
    2003 Lexus IS300T
    2008 A4 2.0t Quattro Avant APR Stage 2+ $old
    Instagram: TwinTurbo_Mike
