Results 1 to 8 of 8
    Jun 22 2009
    Socket size for lug bolts?
    I searched but couldn't find the actual socket size.
    The bolt, as far as I know, is an M14. What size socket do I need?
    Background info: I'm planning on buying this torque wrench and wanted to see what socket to order along. I'm using the standard (S-Line) 19" wheels.
    Senior Member Three Rings elf_cruiser's Avatar
    Mar 01 2010
    GT-R, F350, rockwell cruiser buggy
    Phoenix
    17mm is stock. Some of the aftermarket bolts you can get are 19mm (same as 3/4")
    Jun 22 2009
    thanks! do I need a "thin wall" style socket or just standard?
    Veteran Member Four Rings BlkS5's Avatar
    Nov 20 2009
    2017 Tesla S Loaded
    La Quinta, CA
    ^^ standard
    2007 A6 , Blk/Blk/Sport - Traded for S5
    2009 S5 6M , Phantom Black/Tuscan Brn/Loaded - Totaled
    2009 S5 6Tip , Phantom Black/Blk/Loaded SOLD - 30* tint/KW ADS Coil Overs, Überlegenes Stabilisatoren System/RS5 instrument trim/ClearBra/BB Sport Exhaust/AWE S-filter/Hoen zenon/Blk Ops Grill & Valence/LoJacked/trunk panel net/led's & 42 Catch Can
    2011 A4 2.0 TQ Premium Plus/Brillant Black/Blk/30* tint/back up cam
    Senior Member Three Rings jneutron's Avatar
    Mar 06 2009
    2009 A5, 2010 FX35
    Evergreen, CO
    I use an impact wrench socket (thicker walls) on stock S5 and the stock 18 wheels and it fits w/o a problem.
    2009 A5 [] Deep Sea Blue [] Light Grey Int [] Nav [] Tech [] B&O [] Stock S5 Wheels [] A dipstick [] STaSIS ARB [] STaSIS Exhaust [] Heon Xenonmatch [] Racing Dash LED Plate Lamp [] Rieger Rear Spoiler [] H&R 20mm F 25mm R [] Volant CAI []
    Jun 22 2009
    thanks everybody!
    Veteran Member Three Rings Huey52's Avatar
    Dec 22 2010
    New England
    'course if you're as anal as I am, you use a plastic sleeved socket. http://www.griotsgarage.com/product/...o?code=FROOGLE ;)
    I also lug by hand and torque (never an impact wrench).
    2016 TTS Sepang blue/rotor gray Tech B&O
    Prior: 2013 allroad; 2011 A5
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    Quote Originally Posted by Huey52 View Post
    +1 to the hand and torque
