Results 1 to 10 of 10
    Dec 07 2010
    Orange County, CA
    How much sanding before plastidip?
    Hey guys,
    I am planning on plasti dipping my grill and have been told to sand the parts I am painting. But how much do I have to sand? And if you know which sandpaper is best, I would really appreciate it. Pics will surely follow when I am done. Thanks alot!
    Nov 01 2010
    Brooklyn, NY
    If you're plastidipping, no reason to scuff your mint grille. Just clean it with some rubbing alcohol, wipe it down and spray it.
    Jun 25 2008
    Cleveland
    Quote Originally Posted by 180Custom View Post
    x2
    Dec 07 2010
    Orange County, CA
    Thanks guys
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    yea no need for sanding especially since it's temporary. I need to redo my rear valence though cause its pealing, but this time i might actually use spray paint. good luck though
    Dec 07 2010
    Orange County, CA
    Quote Originally Posted by EHesh14 View Post
    thanks! why is it peeling? too much heat from the exhaust? or just wear and tear?
    Sep 21 2004
    B8 S4
    LA
    I did mine, no need to rough it up. Just wash and DRY WELL, isopropyl alcohol, and start slow and apply as many coats as you need until youre happy with it and its got an even solid coat. I did mine, this shit works well.
    B5 S4, B6 S4, D3 A8, B7 A4, B8 S4
    Veteran Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    I usually run 1000 grit the 3M rubbing compound (1500 or above) then primer over metals or just spray on plastics.
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Bridgestone RE-11 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI-5mm-Fr+10mm-Rear & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, Seat Bins, Trunk Triangle, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
    Senior Member Two Rings Matt336's Avatar
    May 28 2008
    Minneapolis, MN
    Is one can enough for one grille? How many coats did you guys use?
    2010 Audi S4-APR Stage 2+ Pulley/Tune, AWE Catback Exhaust, Injen Intake, H&R OE Springs, RS4 Grille, CF Lip/Splitters/Diffuser, 19x9.5 ET45 VMR V718s, E-Code Headlights
    2004 Audi S4-Sold
    2010 Audi S4-Sold
    2005 Volkswagen Jetta TDI-Sold
    2001 Audi TT-Sold
    Jul 16 2010
    Colorado
    Quote Originally Posted by zdarwish-10 View Post
    I'm pretty sure its just wear and tear, but I would recommend 4 layers if you don't want to end up like me.
