Results 1 to 10 of 10
    Established Member Two Rings b0nzai213's Avatar
    Oct 08 2009
    queens
    Help with Fuel Injector! 2 broken/lost pintle caps
    So I properly let the PB Blaster settle in before trying to remove the fuel rail with the injectors.
    As careful as I was, 2 of the injectors had the rubber gaskets and the plastic pintle cap (little ring that holds the rubber gasket down) broken off.
    I retrieved the gasket fine, I just don't know where the plastic Pintle cap is.
    So here's my concern.....
    1) did the pintle cap somehow fall into the cylinder? I don't know where else it would go.
    1a) If it did fall in, how do i get it out? And it seems dumb from a design perspective as these things can easily break on removal and would always fall in.
    2) Can I reinstall the injectors without a pintle cap?
    Here are some pics showing the missing plastic pintle cap (farthest to right).
    There is one with a white ring..that is a brand new one I just installed.
    B6 Black on black - 6 speed
    JHM Lightweight Flywheel and Clutch Combo
    JHM Shortshifter w/ linkage
    Magnaflow mufflers
    Philips 6000K xenon headlights
    DDM 3500K xenon foglights
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    If you need extra injectors I have some for sale.
    If the plastic piece did fall into the cylinder, do not worry it will simply disintegrate into ash/carbon when you start the car…plastic vs metal = metal wins
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Sep 13 2008
    Western Chicago Burbs
    Quote Originally Posted by CHECKERED View Post
    not too sure about that. i mean......paper beats rock....so yeah......
    Senior Member Three Rings alwaysaudi's Avatar
    Mar 11 2008
    2008 RS4, 2011 A3 2.0T Quattro, 73 MG Miget, 87 325is Chumpcar, 2000 323i SCCA racecar
    VIR
    Had the same problem with mine when I did my IM spacers...I saw a few pieces on the the top of the valve I could get at with so of my old surgical instruments I keep in my tool box but didn't worry about it. I just ordered some extra pintle caps from JHM with my latest order so the rubber bushings stay in place.
    2008 Ibis RS4 Titanium package - Milltek CB - Stasis MS - H-sways F&R - EBwerk droplinks - JHM R3 clutch + LWFW - JHM LW Crank pulley - JHM IM spacers - Roti SNAs with 275 Supersports
    Oct 08 2009
    queens
    thanks for all the tips. i was freaking out that I would have to remove my entire engine to find a stupid piece of plastic. Then began cursing the Germans for a dumb design.
    Anyways, upon cleaning the injectors, do you guys use Carb Cleaner?
    i noticed a lot of sandy debris surrounding the rubber grommets.
    Magnaflow mufflers
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    You can buy a new o-ring and pintle cap from an injector service place, you could try injector rehab. I would try anything I could to get that cap out. First thing I would do would be to use a very thin vacuum extension and try to suck it out. You could rig something with lots of tape and a (car) vacuum line attached to your shop vac. Then stick it into the injector hole and see if you can suck it up.
    You are going to misfire and have an abnormal idle if the pintle caps are not on there. Either grab some from JHM (best invention ever) or try to source some from a local store. I have two dozen spares at home for when i work on these cars.
    Oct 08 2009
    queens
    Anyone know where I can get pintle caps in the NYC area for today?
    Regular parts shops don't carry such a specific part. I'll even buy from any members and pickup today also.
    Magnaflow mufflers
    You can take a ride out to my house, i have a few spares. Not sure if you want to make the ride though
    Oct 08 2009
    queens
    Thanks to all. I replaced the injector just to be safe and now the engine fires like a raging stallion.
    *TIP ON FRAGMENTS OF PINTLE CAP THAT MAY FALL IN*
    -Jason from JHM says he would just turn on the car and let it burn out.
    -I used a wooden stick with some Painter's Putty ($2 for can at home depot) at the end to get any loose fragments out, then started her up to burn out the rest.
    NOTES: when plugging the injector connectors back in, be careful to line up the 2 prongs into the black housing perfectly. I bent a prong and it threw an engine code with rough idle. Luckily I just realigned it and it ran smoothly.
    Magnaflow mufflers
