Results 1 to 15 of 15
    Sep 03 2009
    San Antonio, TX
    DIY: B6 A4 E-Brake Cable replacement (PIC HEAVY)
    NOTE: I originally tried to post this in the DIY section, but it didn't work. A few people have already been asking for it so I thought I would just repost it in here instead.
    The problem: My e-brake "popped" one day and I immediately lost my e-brake. After dissecting the center console, I found that one of my e-brake cables seized and would not move back and forth to accommodate the handle pulling/pushing.
    The engineering: Audi made these e-brakes "self-adjusting" meaning there is a swivel at the base of the handle that rotates left/right to ensure an equal and firm pull and release. The cables are steel braided wires with a thick plastic/composite "sheath". If the sheath cracks, tears, etc, the steel cable gets exposed to the elements and rusts and/or begins to unravel/fray inside the sheath. Thus freezing the cable in place. On the rear tire is the spring loaded e-braking mechanism but it doesn't have enough "stank" to retract the frozen cable back when the e-brake handle is released.
    I'm only replacing one cable in this DIY, but it is only because I replaced the right one about 6 months ago. IMO, if you replace one, you might as well replace the other. The cables only cost me about $45/each.
    Here's what the adjuster is supposed to look like when functional:
    Note the two "hooks" are pretty much even and the "hoops" are the ends of the brake cables. When pulling/releasing the brake, these hoops should move equally and simultaneously front and back. When one freezes, the adjuster attempts to correct this and rotates the opposite way to the extent that the good cable hoop falls off the hook and will disengage the e-brake system.
    Here's the dysfunctional e-brake "released" ie pushed down. Note that the left cable doesn't move so the swivel rotates to the right. As a result, the good cable (right) is over-rotated and the hoop falls off the hook:
    Here's the dysfunctional ebrake "engaged" ie pulled up. The swivel is pulled forward and because the left cable doesn't move, the swivel rotates to the left.
    The tools:
    Not kidding...that's it
    Time: It shouldn't take you more than 2 hours if you are mechanically inclined. This really isn't that hard.
    Disclaimer: This is just what I did. When in doubt, you should take your car to a certified mechanic and have this done professionally. Always use proper safety equipment to include eye protection (crap WILL fall in your face) and never work under a car without jackstands or some way of definitively preventing the vehicle from falling. You will not survive a crush injury if these cars fall on you.
    Finally...The DIY:
    First remove the rear tire of the side affected. In my case I'm dealing with my left cable.
    Note the c-spring with cable and retaining ball at the end as well as the retention clip (pry open, rotate until you can slide it backwards to the rear). The first pic above was actually the finished product. 2nd pic is spring unloaded. 3rd pic is the original (old) brake cable. Note the tearing in the cable cover.
    Next go inside the car, slide all the seats forward and incline seats as much as possible to give you enough working room. Grab a seat in the center rear seat and remove the ashtray
    Remove the lock button plate from the console and disconnect. This is done by sticking your fingers on both sides and feeling the retaining tabs. push both these tabs outward and the plate should fall out.
    This should give you unabated access to the armrest bolt and aluminum guide plate under it
    Remove the center bolt and the arm rest comes out of the top
    Reach under the console and push on the bottom of the pocket. The floor plate pops out and reveals a suspicious looking hole. Inside that hole you will find another bolt that secures the front of the guide plate. Remove it
    Next remove the two rear bolts on the guide plate and you will see the back of the e-brake handle (adjuster) and the dysfunctional cable hoops. Make sure the cable you are replacing is no longer hooked on the adjuster.
    Note the locked cable on the left. Trust me...it won't move.
    Step out of the vehicle (you're done inside for now) and go back to the back wheel well.
    In the next pic, note the little notch at the top of the spring groove. I moved the bottom part of the spring up to that notch and it made the top part of the spring line up with the hole and release without too much effort. Just keep in mind when you compress the spring, it IS under tension so be careful not to catch it in the orbital socket if it slips out of your hands. You can use pliers or channel-locks, but I managed to get it with my hands (yeah...meaty hands help, LOL).
    Follow the cable until you see a metal bracket (it's bolted to the lower control arm) and the cable wrapped into retaining clips. Unbolt the two bolts with your handy 13mm socket wrench and continue forward.
    Next you will see that the cable goes under a heat shield. Simply unbolt the heat shield and this will reveal the next two retaining clips. I simply just popped the cable out of the clips instead of unbolting the clips. NOTE: This is where I found that these heat shield nuts do not hold up to weathering at all. A few were so rusted that they just broke off. So having a replacement stash to include the screws are definitely handy.
    As you go forward, you will see another retaining clip. You should note that it is plastic and wraps around the entire cable. These clips are open towards the middle of the vehicle. Meaning that if you are on the left cable, the clip opens at the right side and if you are on the right cable, the clip opens on the left side. I simply took a flat screw driver and placed it between the cable and clip. Then rotate the screwdriver counter-clockwise (again if on the left clip...its the opposite rotation for the right clip) to create a separation big enough to poke another screwdriver in and pop it open.
    The next step is optional, but I found it helped open the workspace up and give me a better view of the area at hand.
    Pop out the black plastic heat shield retaining clips at the back of the shield that covers the center exhaust section to shield the drive shaft (If you have a FWD, I would imagine the setup is the same just without the driveshaft). The two bolts on the front of the shield actually secure the drive-shaft yolk (wraps around the shaft to stabilize). When you undo the bolts, the drive shaft will loosen slightly and want to fall down. I held onto the shaft until the heatshield was removed and then loosely threaded the bolts back to prevent the shaft from hanging loosely as I worked.
    Sorry for the bad pics on those two. I didn't realize they came out that bad until I started typing this up. But hopefully you get the idea.
    After you remove the cable from the wraparound retaining clip, give the cable a good pull and it will pop out of the back of the console. Then walk it out towards the back. Congrats! You just removed the cable. Now you can compare the new to the old. Right off hand you will see that the new cable will allow you to easily manually slide the cable back and forth in the plastic cover. The old will be seized and ready to serve bitch duty in the trash bin.
    When you're done with the comparo, slide the new cable in the way the old one came out. Before I did this, I place a big bright lamp over the back of the console. This will illuminate the hole you will need to slide the end of the cable into from underneath the vehicle.
    Kinda hard to see in the pic. But trust me you will definitely see it when you're under the car.
    Because that drive shaft is moved slightly, you should see the hole pretty well. Once the cable finds the spot, push hard on the cable until it pops in. then temporarily secure it in the wraparound clip. Go back to the back end of the cable and push the cable forward. This will push the hoop forward. Go back inside the car and secure that hoop. This will make sure the cable stays put while you push/pull and the cable to resecure it.
    Work backwards until you get just to the point of securing the back end of the cable (the retention ball). Before placing the ball, go back inside the car and hook the hoops onto the adjuster. If you are only doing one cable, this will allow the cable to move forward to easily secure the other one (the one that doesn't have much movement because it's under tension).
    Finally go back to the wheel and place the end of the cable in its home. This may take a bit of effort. But it's still much easier than trying to hook both of those hoops on the adjuster while both are under tension. TRUST ME!!! Replace spring and don't forget that retention shim at the base. and double check your work.
    Mount your wheel, remove your jacks, and lower the car back down.
    Enjoy the glory that is now a working e-brake and reassemble the center console.
    Hope this helps someone. Thanks for reading.
    MY BUILD
    Senior Member Two Rings Teej2008's Avatar
    Jul 20 2008
    2002 1.8 B6
    Grand Rapids, MI
    Fantastic
    02 B6 A4 - Amulet Red
    11 B8 A4 - Ibis White
    97 NSXT - Berlina Black
    07 FX35 Sport - Platinum
    www.soundcloud.com/mrjhaefizzle
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    Nice writeup
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Senior Member Three Rings blackfc3s's Avatar
    Oct 15 2010
    Custom build 29er Mountain Bike
    Nebraska
    Audi hasnt changed there e brake design in 20+ years. Based on this write up, it looks the same when I did my e brake on my 1988 Audi 90 Quattro. Good Stuff!
    Jul 27 2009
    North Andover, MA
    To the OP or anyone else, I am working on this now planning to replace both cables. I have managed to remove all the clips, but I am stuck on removing the ends of the cables from the handle mechanism.
    I can't figure out how to rotate the end of the cable to come off the hook of the pulley. Any thoughts?
    Below are pictures.
    2002 A4 1.8t Tiptronic
    APR stage 1+, forge hybrid dv, TT 225 injectors, NGK copper plugs, pro dry filter, test pipe, borla cat back, 35-20% tint
    Sep 03 2009
    San Antonio, TX
    I believe that small rectangular hole directly below the center (slightly to the left of the white mark in you pic) is the quick release button. If I'm not mistaken, you should be able to press a small flathead screwdriver in there and temporarily disengage the tension.
    MY BUILD
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Quote Originally Posted by sa_seahawker View Post
    you need a little custom flat head to put in the hole and then you twist it to unlock it. It is basically a key that will unlock it to set it free. what works best for me that I always used is the little center cap KEY that comes in your cars tool cap. it fits in perfect and has a lip on it that will press against the button as you turn.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Jul 10 2011
    sandy/utah
    Thanks
    Quote Originally Posted by dmansr25sd View Post
    Below are pictures.
    Dude your pics and explanations helped so much, thanks for helping me out with fixing my e brake!!
    Oct 29 2005
    10speed
    San Francisco, CA
    Good deal! Had this happen to me a few years ago. What a bitch it was not having an E-brake. I pulled the whole console out and finally fixed it eventually
    - Clint
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Vote for this in the DIY section. It will save many a minute for many.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    Nice writeup! Another vote for adding this to the DIY section.
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    kudos man. this is one writeapp that been always lacking arounf here...
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Active Member Two Rings ttvick's Avatar
    Jun 05 2008
    TR6|V8 Explorer|ML320|Phaeton|Mini
    Fayetteville / Raleigh, NC
    Can anybody tell me whether the ebrake cables are the same for Avants and Sedans?
    "I couldn't find the sports car of my dreams, so I built it myself."
    -Ferdinand Porsche
    looking to get into my first A4...
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by ttvick View Post
    yes
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Junior Member Two Rings
    Nov 06 2013
    Baltimore MD
    Smile
    This is a wonderful write up, thank you. I had the left cable pop off the adjuster hook because the right cable freezes on cold days. Today's adventure was reconnecting the left cable at the adjuster. A new cable to replace the right one will come later.
    One question: the right cable is easy to attach as it is accessible. But the left one is under the console and hard to get at. I undid the left cable at the caliper and got enough play at the adjuster. But it was very dificult to connect the left cable. Does anyone have tips on that?
    Thanks,
    John
    2003 A4 1.8t 5 speed - my brother
