Results 1 to 23 of 23
    Active Member One Ring JMA410's Avatar
    Apr 29 2010
    Merrick New York
    A4 B8 Wheel Offset?
    Hi, I have a stock Audi A4 2010 2.0L Quattro. I am purchasing new rims called MAM RS1's. They don't make these wheels with an offset of 35 the only other options are 30 or 45. Will ET 45 fit my car or will the tires rub?
    Veteran Member Four Rings dumpedb5's Avatar
    Nov 22 2009
    B5 Imola Avant and a MK4.
    City Of Roses
    Take your wheels off and look.
    SQUISHEDTWINKIE
    Apr 29 2010
    Merrick New York
    The tires are 245/35/19 .. will ET 45 wheels fit my car?
    Sep 30 2009
    b
    Quote Originally Posted by JMA410 View Post
    search, you caveman
    Mar 02 2004
    Phoenix, AZ
    The bigger the offset, the more then stick in, not out. For example, the Sport Pkg 18s are ET47.
    I think ET30 would be fine.
    Apr 29 2010
    Merrick New York
    Is there a significant difference between ET30 and ET45? And which size do you think would look better?
    Sep 30 2009
    b
    OMG
    BEFORE MISINFORMATION CONTINUES I WILL INFORM YOU.
    Wheel offset doesn't mean shit without knowing the width of the wheel.
    Apr 29 2010
    Merrick New York
    The measurements for the wheels are 8.5 x 19, 5 x 112
    Sep 30 2009
    b
    et 30 will not work very well on 255's. et45 will look sunk in. You can either get the et45 run spacers, or get the et30 and have potential rubbing issues
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    This looks like to be another lock thread.
    Apr 29 2010
    Merrick New York
    They're 245's not 255's if that changes anything, I found a thread with the exact rims I am looking to purchase but I cannot tell if the ET45s have spacers or not. Check it out, http://www.audizine.com/forum/showth...-b8-from-spain
    Apr 29 2010
    Merrick New York
    What size spacers would be recommended for ET45 if the offset for the car should be ET35?
    Sep 30 2009
    b
    I HATE YOU. it says et45 right in the first few lines.
    Established Member Two Rings Aud!'s Avatar
    Jan 31 2011
    MY11 A4, MY07 Q7, MY10 Prius, MY05 H2
    Rancho Cucamonga
    I'm new here and asking for this to be locked...it's like beating a dead horse...or this case a simple search...lol
    Teeblitz.com - welcome to the darkside............
    2011 B8 CVT AT, Ibis White on Black, premium plus with titanium package, black filler and front valance, K&N intake, APR tuned, 10" sub, 35% windows.
    Apr 29 2010
    Merrick New York
    Quote Originally Posted by Aud! View Post
    How about don't reply to my thread buddy boy
    Veteran Member Four Rings 1RAudiSQ5's Avatar
    Mar 08 2007
    Ashburn Va
    but dude you are asking stupid questions???? "If the offset is 45, what size spacer do I need to get to 35?" REALLY? Can u subtract?
    2019 Audi SQ5 Premium +: CETE module // Vorsteiner VFF-107 22x10.5 // AWE Cold Front // CTS Intake // CTS Turbo Inlet // 034 Trans Insert // AWE Touring Exhaust // 034 Swaybars
    2021 Audi SQ7 Prestige : 034 Lowering Links //
    AKA WantaA4
    Apr 29 2010
    Merrick New York
    Quote Originally Posted by WantaA4 View Post
    It's not that simple. You can't just subtract 45 from 35 and know what size spacer to get because the spacers are sold by inches. I'm just trying to get some help don't need any negative comments thanks.
    Mar 08 2007
    Ashburn Va
    It is that simple. And spacers are sold in mm. You need a 10mm. Is that less negative for ya?
    AKA WantaA4
    Senior Member Two Rings Spartan300's Avatar
    Feb 09 2011
    2016 S3 Sepang Blue & 2013 F30 328xi Sapphire Black
    Montreal
    Ok this thread is going nowhere and nowhere fast!!!
    Can you please google some basic info before posting anything that comes up in your head!
    What are Wheel Spacers?
    Wheel Spacers are used to widen the width of the vehicle for stability and to add clearance to the front end when wider rims and tires are being used. Wheel Spacers are used to spread the distance between bigger tires on dually trucks and will place your vehicle at the original manufactures (OEM) wheel offset when installing aftermarket rims.
    General consensus is that mm as in the metric system is used when calculating or reffering to spacers. To answer your 45 to 35 questio, the answer is 10mm spacers (10mm thick)!!!
    I've also included this handy chart for you in case you prefer inches:
    5MM = 0.197 INCH / 8MM = 0.313 INCH
    10MM = 0.393 INCH / 12MM = 0.473 INCH
    15MM = 0.590 INCH / 20MM = 0.787 INCH
    25MM = 0.983 INCH
    I'm sorry for the tone of my post but you put absolutely zero effort in finding the info you needed as it was pretty much a few keystrokes away. BTW the original offset for our our cars is 43-45mm hope this helps you decide.
    '16 S3 Sepang Blue / Black leather / Progressiv / Convenience / Navigation / Magnetic ride / 19"
    '13 F30 328xi Sapphire Black / Coral Red / Sportline / gloss black with matte red / Style 397 18" wheels
    Gone:'12 B8 S4 Ice Silver on Black/Premium/DSG/Sport Diff/Nav/Carbon Inlays/19' Titanium Wheels/RS4 Grill/AWE exhaust/Alu Kreuz/H&R OE/Pagid RS19
    Gone:'11 B8 A4 Avant Sline/Brilliant Black/Black Alcantara/APR ecu tune/AWE dual exhaust/gone...
    Apr 29 2010
    Merrick New York
    Quote Originally Posted by Spartan300 View Post
    25MM = 0.983 INCH
    Thanks for the help. If the original offset of our cars is 43-45 mm will I even need spacers for these wheels which are ET45? Or should I look for ET35s?
    Feb 09 2011
    Montreal
    I'm starting to wonder if you are serious about your questions but here goes! You already had the answer to your original question with this reply:
    Regardless of 245's or 255's his resonse applies. As for the sunk in look, this is how the stock look is, somewhat sunk it.
    No you will not need spacers correct, as the wheels and offset are pretty much like stock. As for getting ET35 wheels you can't, please refer to your original post bellow!!!
    If you buy the wheels with a 45 offset and want them to sit more flush (like ET35) then get the ET45 wheels and add 10mm spacers. Which will reduce your wheels overall offset to ET35.
    I hope this answers all of your questions!
    Apr 29 2010
    Merrick New York
    Thanks a lot, appreciate it!
    Jun 02 2009
    San Francisco
    We are reinventing the wheel here. (pun intended)
    With 8.5 wide wheels, ET30-33 is where you are starting to get into rub territory with lowered suspension, period.
    For more useful info, please click this.
