Results 1 to 21 of 21
Thread: B5 or B6?
    Apr 09 2011
    Casselberry, FL
    Question B5 or B6?
    Hi guys, I've been looking around this forum for a while now. I am wanting to get my first car pretty soon and I am torn between either a B5 A4 or B6 A4. I would get it with quattro and a manual transmission. I just want to know the pros and cons of each and which one would be easier and less expensive to mod in the long run. Are there any features in one that the other doesn't have? Why do you like one over the other? I would appreciate some help with this and am glad to be part of this forum now.
    Mar 10 2009
    il
    You should pick up a B6.
    Veteran Member Four Rings DonnieDark0's Avatar
    Mar 02 2009
    bs 54
    Long Island NY & Kent OH
    depends on your style. Totally different body styles. I love the b6 and I love the b5. B6 will most likely last longer style wise cause its more updated. But B5 just looks and feels more nimble and aggressive. Look up tons of pics of both and see which one suits your fancy. Just dont get auto. =)
    Garage: b5 s4 silver stg3 f21s
    RIP Daz 4/14/16. Legend.
    Established Member Two Rings nikothegman2003's Avatar
    Jan 24 2008
    '03 A4 3.0Q, '01 TT-Q cab. '86 Me/Be 300SDL
    Bronx, Westchester, New York
    i say B6, and if youre not planning to do too many engine mods get a 3.0 MT-Q, otherwise cop the 1.8
    Jun 30 2008
    Erie, Pennsylvania
    From a reliability and build quality standpoint, I'm going with the B5 on this one. I've seen too many things on the B6 that have been a step down in quality from the B5 chassis. Including:
    Fuel Pump
    Interior quality (buttons rubbing off, etc)
    Paint peeling on front fenders and other areas
    Thermostat and multiple coolant sensors
    Cooling fan control module
    Vacuum/PCV system got completely out of control
    Etc
    The B6 chassis seemed to add complexity and issues, while not addressing some of the faults of the B5. But you do get a newer car with more features and newer styling. Although, I prefer the looks of the B5, myself. Just my opinion here. There are plenty of B5 issues to go around as well.
    Dec 05 2007
    They are basically the same vehilce, just slight differences:
    -pre 01 A4 has a narrowband primary 02 sensor, while AWM and B6 has a wideband (comes in handy for tuning issues)
    -97-00 1.8t has slightly stronger bottom end, due to larger wrist pins
    -B5 has return fuel system while the B6 does not
    -B6 has slightly smaller fuel feed line than the B5
    -to state the obvious, body styles are different
    -B6 is heavier
    -B6 can have 6 speed
    -other minor differences
    Other than that, it would depend upon what style of body and interior you want. It will basically boil down to that. Finding a B5 in good condition is rather hard to come by. Same thing may exist in the B6 side of things, but the same issues are relevant. being that I have been in a B5 for a couple years now, I would pick up a B6 if I had the right opportunity. But I adore the B5 body style, and was probably the main reason I picked this car over many others. The 1.8t was what I was loking for when the gas prices were incredibly high (like they are getting curently), and was a perfect fit with great tuner ability. All in all, you should be happy with either one. Just know what you are getting yourself into. You can't treat an Audi like you can a Japanese automobile. She will sh*t on you the second start to neglect her (ie beat on the turbo while hitting a hard corner not knowing the condition of your control arms or turbo, not change your fluids, not change your tb on time, etc). I can beat on my car all day long (not that I do). But I treat her well.
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    I like how the B6 has a stiffer and much more rigid chassis than the B5.
    That was the whole big deal about the B6 when it was launched in the day too.
    And the interior is much better.
    Other than that, I reckon it's pretty overweight for a standard car and looks it too. Whatever floats your boat.
    00 A4 1.8TQ MT (AJL)
    12 1M
    18*8 RPF1 | Vogtland GT 575F/675R | H-Sport Sways | 320mm B8 Brakes, 300mm S4 rear |
    GT2871R Elim | QMS tuned AJL 627cc EV14 @ 4.3bar | 034 3" DP (8psi backpressure!) | Milltek | JHM SSK
    3090lbs
    Oct 05 2010
    I agree with the post above.You can also always go check both of them out and test drive them to see how you like it, right?
    Senior Member Three Rings dirtyb5a4's Avatar
    Jan 02 2010
    99.5 1.8t 5spd quattro(rolled) 97 1.8t 5spd quattro
    lowcountry, sc
    Id recommend a 99.5. Strong bottom end, with facelift looks and interior. Unless you want the curvy(imo fat looking) b6
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    Every generations, the body get stiffer since the S1 rally car.
    Most of the mechanic is the same... (not completely sure)
    And from my 2001 interior to a friend 2002, the differences are minimal. The only thing I like better in his B6 is the rear view mirror that indicate S-W-E-North. I do a lot of road trips so it's sort of practical... but then again I dont use it.
    B5 Sedan > B6 Sedan
    B5 Avant < B6 Avant
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    b6 is the best of both worlds imo.
    only EARLY b6's have the peeling issues, unless someone didnt take care of the car.. but it seems to be hit or miss on ANY of the cars. I have a 98 a4 in my shop that has creame/blue interior and the door pulls are white b/c everythin is peeled off.. I am currently working on 2 b6's, both 04's, neither have ANY peeling issues at all and one has more miles then the 98 car.
    AEB's do have the bigger wrist pins, but it seems, that the 01+ tuning abilities will over shine the AEB all day. B6 guys are making 320-330 AWHP on their 19mm wrist pinned bottom ends all day for 100k miles or more with GT28RS's and other turbos that people have bent rods in AEB's at 315-320 AWHP.. I def believe the AEB's have the stronger bottom ends but lack the tuning abilities to take use of it..
    B6's have bigger fuel tanks which you gotta love 500 miles to a tank on the highway.. My 01.5 at 75 cruise will do 440-450. The 5 speeds REALLY need another gear at 75mph.. If you can afford a 04-05 b6, get the 6 speed. I just did a trip to SC and back and at 75 I could get 440-450.. at 80 it dropped to tad under 400 and at 85 cruise set in all of this.. it was 340-350 to a tank.. (stock sized tires)
    It really depends upon your budget as to which car you plan to get. b6's have a much better fit and finish, better quality leather. I havent seen a torn a4 seat yet in a b6. Better stock stereo.. the b6 non bose setups sound better then my replaced and symphony hacked bose in my 99.5 car..
    Its preference.
    Will look better together (door blade is getting painted) or if i could stand back further and get a good shot of it with my DSLR, but i have 4 cars beside it and not enough room to stand back.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Senior Member Three Rings truls000's Avatar
    Feb 08 2010
    gone!
    Ive har both the B5 and now have a B6, both are good car. You will be happy with either of your choises :)
    Mar 02 2009
    bs 54
    that avant picture makes me want to get 1 lol.
    Veteran Member Three Rings miggity02's Avatar
    Mar 22 2008
    '17 SQ5, MK7 GTI
    East Bay, NorCal
    I have both. B5 has more potential to be nimble and is a bit lighter than the B6. I do think the B6, proportionally, is sweet: B5 some say are too small, B7s are oversized or too tall for the chassis, B8s are too big in general etc...That being said, everyone above all have valid points for each model. I wish my B5 had a 6th gear, I really like the stock Bose in the B6, shifter is smoother in B6, more exterior mods for B6, B5 even with avant can be more nimble. It's up to you!
    My .02
    '17 SQ5-034 Stage 2 ecu/tcu-JHM 187mm CP-034 inlet, RSB, sub frame inserts-Eurocode trans/diff mounts-Alu Kreuz-B8/H&R-Neuspeed RSf72 20x9.5 et25-Magnaflow 11385-OEM airbox mod-aFe 11-10121
    Mk7 GTI-034 Stage 1 ecu/tcu-H&R springs/B8-Neuspeed rse11r
    Triumph Street Triple R-Full Arrow and tune
    Apr 09 2011
    Casselberry, FL
    Thanks guys. I agree with FNK about the avant and sedan preferences. I really don't care if its a sedan or avant. I'm just looking for a fun daily driver with potential in the future.
    Established Member Two Rings twofaze's Avatar
    Jul 26 2008
    Fort Worth, Tx
    deep down, everyone wishes they had a 99.5 B5....
    in da hood we say "don't drink & drive, park & sip"
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    Quote Originally Posted by twofaze View Post
    not really, i have a 99.5 and an 01.. the 01 drives better and more effortlessly then my 99.5 ever did
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Aug 13 2008
    Indiana
    Quote Originally Posted by Lazer Viking View Post
    a 99.5 and 01 B5 of the same engine trans and all will drive the same since they have the same basic parts (now the 1.8t's do have more power in the 01 so that's slightly arguable) but the chassis is the same.
    -Nic
    Veteran Member Four Rings ballinb5's Avatar
    Jan 16 2011
    CA
    Get a b6 avant, or b5 sedan. end of discussion
    Jun 26 2008
    00' Noggy Stg2
    Quote Originally Posted by somebody5788 View Post
    you have no clue 2.8 boy... the DBW cars drive much more effortlessly then the DBC cars do. My 01 car drive away from a red light or a stop sign like its not even a boosted car.. I can actually use the gas pedal.. the DBC cars, cant.. they just dont have the smoothness at all.. you try to drive away normal and its into boost.. I drive normal and enjoy the car for what it is.. i dont need to live in boost, i'm not a 16 yr old HS kid.. I am sitting at 125 miles and just slightly slightly under the 3/4 tank mark.. my AEB use to use more oomph, more effort I should say, to go up hills and to move itself from a stop light. and would get about 300 to atank in town.
    here is another thing.. i can shift my 01 at 2200 and drive it anywhere with no loss of power with it still gaining speed/momentum and not like a grandma whos in the way... my 99.5 if you would shift below 3k, even shipped (my 01 is stock), it would feel like it needed to goto 3500 or so to keep the same pace of speed moving.
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    LOL.
    DBC>>>>>>>>>>>>DBW
    And all you guys are hatin on the b5 avants?! Damn haha. I love mine.
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
