Results 1 to 26 of 26
    Senior Member Two Rings dante18's Avatar
    Jan 17 2005
    14 rs5, couple Ducati's, chopper, 95 Land Rover Defender90 #1283, 2015 Range Rover and growing
    PA
    Tire size for 19x8.5" wheel
    Is a 235/35-19 the correct size for a 19x8.5" wheel? I really hope the answer is yes??
    TIA.
    2004 S4 6mt Black\Black & Silver Alcantara
    19" VMR718 in gunmetal, Apikol, AWE non-res with Fast Intentions mufflers, JHM light weight flywheel, JHM Stage III clutch, K&N air filter...
    Senior Member Two Rings Drkside's Avatar
    Sep 04 2009
    Blimp and a jetpack
    rockville MD
    yes, you should be fine. are you lowered? if you are you might get some rubbing.
    2005 B6
    JHM Tuned|JHM SS|JHM 6 piston BBK|piggies(no cats)|Milltek unresonated cat-back exhaust|RS4 RSB
    Jan 17 2005
    PA
    Quote Originally Posted by Drkside View Post
    Thaks for the quick reply! I am not lowered so you just gave me some good news, I already have brand new Nitto's in that size... I just took delivery of a set of VMR V718's in gunmetal, very very nice wheels at that price point I must say. Thanks again.
    Mar 27 2005
    The Cold North
    yeah the 235-35-19's should work just fine on the VMR's. (just make sure the load rating is high enough) I am running 245-35-19's on my 19x8.5's with 41 offset. IIRC the VMR's are 37-38 offset.
    to a fellow duc owner
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Jan 17 2005
    PA
    Quote Originally Posted by EBG 18T View Post
    I believe they are 35 offset? I am very pleased withy the quality and service I received from VMR.
    Thanks for the info and keep the rubber side down...
    Now if I can find someone local who has a used Milltek or AWE non res catback, life would be even better
    Established Member Two Rings james.bigouette's Avatar
    Oct 26 2009
    2005 B6 S4, 2007 VW GTI STG 2+
    MD
    Quote Originally Posted by dante18 View Post
    Where in PA are you? I am looking to go FI so my AWE non res would be up for sale.
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    ON A SET OF 19X8.5 WITH 35MM OFFSET I RAN A 235/35/19 UP FRONT AND A 265/30/19 IN THE REAR WITH NO RUBBING AT ALL
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Three Rings dextrek's Avatar
    Aug 26 2008
    B7 S4
    Detroit
    I am lowered with 235/35/19 and no rubbing. You DO have to take out the small screw from the fenders though.
    -Ben-
    B7 S4 Dolphine Grey
    B6 A4 USP Moro Blue *Sold*
    Jan 17 2005
    PA
    Quote Originally Posted by james.bigouette View Post
    Bucks County... Please let me know I would certainly be interested in taking it off your hands.
    Will travel for the right deal ;-)
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    LA
    if youre not lowered, deff do 245/35/19 and put down some more time onto the pavement. extra tire will help fit the wheel to the tee and fill in a lil more of your fender.
    (Ka-La-Bre-Ah)
    Jan 17 2005
    PA
    Quote Originally Posted by Calabria View Post
    I already have the rubber so I will be using them. Is there really that much of a difference between 245 and 235?
    Established Member Two Rings Merlin00069's Avatar
    Nov 24 2010
    Miami, Fl
    255/35/19's here. Lowered.No rubbing. Ditto on the screw removal.
    Dec 05 2006
    So. Cal.
    there is enough notice. Also, I thought that the VMR's are a +38 offset, which would make it safer for you to run a 245.
    Sep 23 2006
    Houston TX
    Old VMR wheels which started with the RS4 reps were ET38 on a 8.5. The newer styles (in the last couple years) are mostly ET35 on the 8.5.
    Dec 05 2006
    So. Cal.
    Thanks for the clarification.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    235-255 is the safe range.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Established Member Two Rings EBG913's Avatar
    Apr 18 2010
    2012 TT RS - Ibis White; BMW X3 3.5
    Chicago/IL
    I've been wrestling with putting the OEM S5 double 5 spoke wheels on my 2007 S4 (sedan). They are 19" x 8.5" and apparently have a 32mm offset. i keep getting mixed answers on whether they'll fit, w/o rubbing once i get a hubcentric ring to size down the center bore, and whether they will stick out past the fenders. my S4 is stock height. Hoping someone has done this before with OEM S5anyone have any idea if they'll fit w/o rubbing or making significant modifications, etc?
    also - i was planning on getting 245/35 19" tires (all-season b/c i'm in Chicago) - maybe the Continental Extreme Contact DWS? any thoughts/recs on tires?
    I've never upgraded wheels before, so i'm trying to learn all this (like i just learned about offset), so any help would be greatly appreciated.
    Sep 13 2008
    Western Chicago Burbs
    Quote Originally Posted by EBG913 View Post
    yes they will fit with the hubcentric rings. wont stick out past the fenders. the smaller the ET number, the closer they are to the fender. So 32mm will stick out 3mm farther than the VMR RS4 reps which is going to fit easily
    skip the all-season. just get dedicated snows and have them swapped in fall/spring. all of the all seasons suck in the snow compared to snow tires and with the DWS, they wear out enough after 1 year on the audi that they are half as good as they were last yer in the snow
    Apr 18 2010
    Chicago/IL
    Quote Originally Posted by B6JoeS4 View Post
    Thanks for tips.
    Right now i have the stock 18 x 8 45mm offset. will i need anything else besides the hubcentric ring for these to fit?
    And are 245/35's the way to go for this set up rather than 235/35s? just want to really make sure they fit.
    As for tires, i don't really have anywhere to store a 2nd set of wheels at the moment. Are there any decent all seasons that don't wear down as fast? The DWS were the highest rated on TireRack - looked like Bridgestone Potenza RE960 Pole Positions got slightly less worse reviews, but were about $100 more per tire. Same with Michelin Pilots (even more expensive).
    Sep 13 2008
    If you MUST get an a/s tire, then stick to the DWS. I had the RE960 and they were useless in the snow. I would hope the DWS are better.
    Weather you get 235 is 245 is completely up to you. I personally like the 235's because they have an ever so slight stretch-if you can even call it that. the 245's make the tire look too chunky. But if you are in the city, then 245's might be a good idea so you have some extra cushion.
    Not sure if you need anything besides the rings. Pretty sure audi stick to ball seat bolts on the B8 cars. if they did then you are good to go. If not, then you will need a set of conical lug bolts. Do some searching and you'll probably find the answer pretty easily
    Established Member Two Rings bayaud's Avatar
    Jan 04 2011
    66 fastback, 04 nogaro s4, 02 dolphin grey a4
    livermore
    is that 19x8.5 all around and you are running on staggered? any issues so far? i was thinking of doing the same setup on my b6 s4.
    Quote Originally Posted by AudiTechS4 View Post
    Jan 18 2011
    Porshe 951 Turbo with PowerHaus Engine and many Mods
    Moline Illinios 61265
    Who makes high Quality wheel spacer"s and are there any issues with Hubcenteric Rings with wheel spacer"s B6 S4 2004
    Mar 27 2005
    The Cold North
    Quote Originally Posted by audirs20v View Post
    H&R is always a decent quality spacer. But you need to make sure the chamfer on the spacer and the hubcentric ring are the same, otherwise you will have issues.
    2020 Chevy AEV ZR2
    Sep 13 2008
    Although expensive, the RS4 guys go ape shit for the MTM spacers. I have H&R and they're great
    Apr 15 2007
    WNC
    how would 255/35/19 be on a 19x8.5 wheel on a car on springs/shocks with no spacers?
    2013 RS5, 2014 Q7
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by rnp614 View Post
    Well without posting the springs you're on, or the wheels' offset, how can we answer that?
