Results 1 to 23 of 23
    Senior Member Two Rings jdaudi's Avatar
    Oct 26 2010
    US
    Exclamation Need to remove MMI Buttons - HELP!
    Hello All,
    I accidently spilled pop all over my MMI buttons, and now they hardly move.. I need to somehow clean them. I pulled the spinner off and got that, but the buttons directly beside it are still unmovable. Can someone give me directions on how to remove the buttons and/or trim to clean the buttons? The pop is built up all around them.
    Here's what my MMI looks like.
    Active Member Two Rings Audi_Fan's Avatar
    Mar 29 2011
    2012 Audi A4 2.0T
    Boston,MA
    1) Pull upward the leather around the shifter. Don't be shy to use a little force.
    2) Carefully pick around the silver trim until it comes off.
    3) Pull upward the entire MMI unit.
    4) Disconnect two plugs.
    5) Unscrew 4 screws on the bottom of the unit.
    6)Take it apart; use rubbing alcohol, q-tips, and magnifying lens.
    For all the rubber parts inside, you can wash them under warm water with soap.
    Once you have cleaned everything thoroughly, let it dry for few hours before reinstalling.
    Oct 26 2010
    US
    So I pull the leather upwards to get the silver trim off?
    Oct 26 2010
    US
    Well I got the gear shifter apart. But the aluminum trim I can't. There's clips in there I can't seem
    To maneuver without bending or putting dents in it.
    Oct 26 2010
    US
    talked to dealer. he says thats wrong, you have to take off all the wood trim
    Mar 29 2011
    2012 Audi A4 2.0T
    Boston,MA
    Pull up the shifter leather, disconnect the shifter indicator, and then pull off the entire panel with the wood. That should work.
    Oct 26 2010
    US
    How do you just "pull off the entire panel with the wood"
    Mar 29 2011
    2012 Audi A4 2.0T
    Boston,MA
    yes place your hands in the area where the shifter sits and pull the whole panel upwards with little force. It will snap right out. This is how it worked for me on the Q7, I can't imagine it being much different on the A6. Once you pull the shifter cover up, look inside see if there are any screws that hold the MMI into place.
    Apr 07 2010
    2019 A4, 2018 Subaru Outback
    Southington, CT
    From the Bentley. Sorry for the lack of pictures but this should help.
    Center Console
    Front Center ConsoleRemoving
    On a vehicle with automatic transmission, place selector lever in position "S" .
    Switch off ignition.
    Remove rear center console Rear Center Console .
    Remove the climatronic control module J255 Heating, Ventilation and Air Conditioning - Repair Group 87 .
    Remove gap cover over ashtray - arrow - .
    Open front ashtray.
    Remove front ashtray insert.
    Remove bolts - 1 - and - 2 - .
    Release ashtray - 3 - with a screwdriver - arrow - by positioning screw driver on opening - 4 - .
    Remove front ashtray housing.
    If applicable, disconnect electrical connection.
    Unclip shift or selector lever boot - 1 - on both sides and pull up to remove - arrows - .
    Vehicles with automatic transmission:
    Release retaining spring - 2 - and remove selector chart - 1 - - arrow - .
    Disconnect electrical connector.
    All:
    Remove bolts - arrows - .
    Lift front console a little on rear edge and pull back from instrument panel.
    Disconnect electrical connectors.
    Trim
    Removing
    Pull shift lever or selector lever boot up.
    All:
    Carefully release clips - 1 to 3 - and - 6 - on Multimedia Control Head E380 decorative frame - 5 - with a narrow screwdriver.
    Lift decorative frame off from center console and Multimedia Control Head E380 - Item 4 - .
    Installing
    Installation is reverse of removal, but note the following:
    Push decorative frame down until locking tabs engage.
    MMI
    Multimedia Control HeadRemoving
    Remove front center console Front Center Console .
    Carefully release clips - 1 to 3 - and - 6 - on decorative frame - 5 - with a narrow screwdriver.
    Remove Multimedia Control Head E380 decorative frame.
    Remove Multimedia Control Head E380 - Item 4 -
    Oct 26 2010
    US
    Quote Originally Posted by ManyAudis View Post
    Center Console
    Open front ashtray.
    All:
    Trim
    Removing
    All:
    Installing
    MMI
    This seems a little too crazy without pictures
    Apr 07 2010
    Southington, CT
    Quote Originally Posted by jdaudi View Post
    I recommend that you purchase the Bentley manual for the car. It will pay for itself many times over.
    Oct 26 2010
    US
    ANybody else have any suggestions?
    Established Member Two Rings anpk05's Avatar
    Aug 29 2008
    2005 A6 4.2L S-Line/
    Long Beach, CA (562)
    Anybody kind enough to post some instructions to remove MMI panel on a 05 A6. Its needs cleaning, dealer asking for $275.
    TIA
    Dec 27 2010
    Morehead City, North Carolina
    Does the Bentley manual show pictures and diagrams in it? And do places such as ebay or other sites sell them used for a reduced rate?
    Aug 29 2008
    I followed the above instructions and took it apart, pretty easy for the amount of steps it had. However i got stuck where i have to take off the rear center arm rest and rear ac controls. The MMI came loose after i took off the front ac module, front ashtray and the side plastic covers. Any body know what i have to do next?
    Oct 26 2010
    US
    Pictures please, someone. I still cannot operate my buttons...
    Aug 29 2008
    I still couldnt complete what I started, couldnt take off the front center console. Otherwise everything came apart. Its better to invest in a bentley manual.
    Sent from my SGH-T959 using Tapatalk
    Oct 26 2010
    US
    I dont see the point of buying a manual when you have forums where people are supposed to help you. dumb
    Established Member Two Rings bofa deez's Avatar
    Nov 03 2008
    bellevue, wa
    ok so i have done this about 30-40 times already with the same concern of the sticky mmi buttons... do this at your own risk but lightly spray some aerosol glass cleaner on the affected buttons first, then basically start moving the buttons/ pushing buttons untill it frees up a little, then a little shot of some compressed air gently on the cracks of the buttons to evaporate any leftover glass cleaner. This has worked many times for me, but some times it may take a couple tries to completely get the buttons to move freely.
    hope that helps. it may not be the perfect way to do it, but its worth a shot. Its either that or take the whole console out.
    Oct 26 2010
    US
    Quote Originally Posted by bofa deez View Post
    Isn't there a way to just use some type of suction cup to pull the buttons out one by one?
    Nov 03 2008
    bellevue, wa
    yea only if you wanna break every single button
    Oct 26 2010
    US
    How much are the the buttons. That may be the way to go
    Veteran Member Three Rings MainlandMig's Avatar
    Apr 06 2010
    Atlantic City Metro Area
    reviving an old thread because its a common problem and this thread shows up in searches
    * the MMI Interface unit or pieces of it can not be popped up... (maybe in othe models but NOT C6) ...just the power/volume nob COVER and maybe large nob COVER.
    * the buttons can not be purchased new separately.
    * the dealer recommends swapping out the MMI Interface unit as a whole.
    * you can attempt to dissect the unit and give it a good cleaning but that requires removing the center console which requires removing arm rest and Climatronic unit.
    http://forums.audiworld.com/showthread.php?t=2832795
