Results 1 to 11 of 11
    Dec 19 2007
    York, PA
    How to clean inside of coolant expansion tank?
    i looked all over and cant find shit. is there any ideas or ways people have cleaned theres out on the inside to make it look new again? i want to refresh my old grey tank.
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Someone mentioned it on a thread here. Let me see if I can hunt it down.
    *Edit, bam! I'll not give you shit for having posted in that thread........
    http://www.audizine.com/forum/showth...ight=gray+tank
    Active Member Two Rings poneman's Avatar
    Feb 16 2009
    2003 Audi A4, 94 Jeep, 06 WRX, LT500R Quadzilla, + quads, mtn. bikes, 9000lb lift!
    Saratoga, NY
    I used an acid solution I use at work for cleaning beverage piping, it's a mix of phosphoric & nitric acid diluted 50% with water. Got 90% out though not all of the brown stuff came out of the baffles. I didn't want to soak it for too long as I thought it may eat away at the level sensor probe. BTW=A cheap way to get phosphoric acid is Behr concrete etcher at Home Depot, it's strong and works good at getting rust,scale off things if you don't happen to have drums of acid at your disposal. Worst case, $20 for a new one: Click
    [ APR 1+ - Stasis SS - 18" VMR - Forge Splitter - IE Rods - JE - Supertech Valves - Frankenturbo ]
    Veteran Member Four Rings Valve_Cover's Avatar
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    buy a bottle of coolant flush (8$) at any parts store. Dilute it into water 50/50. Remove your coolant tank, block the holes, fill with the solution, and let it sit for a half hour shaking it every few minutes. Got mine looking like brand new.
    I'm just here for the free coffee
    Dec 25 2004
    Earth
    Why not simply buy a new one!
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    I think he likes his gray one.......
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    Quote Originally Posted by Kittrell View Post
    Actually I bought a brand new clear one with the new style cap, and after 6 months it was all yellowish for some reason, so i cleaned out the grey one and put it back in lol..
    Dec 19 2007
    York, PA
    yeah i remember seeing the topic once before but i couldnt find it. thanks man.
    Dec 19 2007
    York, PA
    i have a white one now, i want to use my grey one again. ;)
    Veteran Member Four Rings ocod's Avatar
    Feb 17 2009
    05 A4 1.8TQM, 05 Nissan Xterra, 99 Sea Doo Sportster
    miami
    Quote Originally Posted by n7plus1 View Post
    you sir are in luck. While strolling classifide section I saw Kirk's ad for cheap stuff and remembered your post/request.
    you can PP a finders fee
    http://www.audizine.com/classifieds/...4-stuff&cat=21
    KO4 APR Stage II+ // tt injectors // Podi SW gague // NGK BRK 7E .28 gap // 2.5" Test Pipe // Forge 007 DV //
    APIKOL Snub Mount // Stock N75 // 20%Tint // DTH FRP Skirts // 270 miles to empty // B7 key fob // 35W 5K HID's
    Dec 19 2007
    York, PA
    i have my grey tank still. just sitting in storage
