Originally Posted by
NOTORIOUS VR
I know a few people that use them... not on an S4, but in high boost applications... they do very well and last long. I would get them over the Bosch plugs any day... but then again I'm biased towards NGK. They're a great plug manufacturer IMO.
I've seen the Iridiums do amazing things when copper plugs wouldn't cut it (high compression and high boost methanol applications)... went from not wanting to rev/boost to pulling right through to redline with nothing more then swapping out the plugs to Iridiums on the dyno (and before the session started a fresh set of coppers went in)
That's interesting, because Copper has like 3X the electrical conductivity and 2.5X the thermal conductivity of Iridium, so spark should not have been an issue with the Coppers. Are you sure they both had the same heat range? Cause if the Copper was only 1 step colder and Iridium was 2 or more, then the colder heat range plug would obviously hold up better under high-boost, high combustion chamber temperature conditions... Or did the two plugs have the exact same gap and electrode/ground configuration? Cause even the smallest alterations in electrode length, angle, number of ground prongs, distance to intake valve, etc., etc. can effect spark under high-boost applications (read spark blowout). But all things being equal, there shouldn't have been that much of a difference by just changing plug material.
OP, I've ran Iridiums in the past trying to chase down a ghost misfire cause I heard they were good for that (still not sure why, but W/E), and it seemed to help for a while... But then again that just may have been the placebo effect going from some semi-used Coppers, so IDK. I'm going to switch back to the cheap NGK Coppers real soon just to see what happens, and I'll make sure to report back.
The bottom line is: Platinums (which you shouldn't really use on t/c'd or s/c'd cars) and Iridiums are generally recommend if you're looking for a long service life out of your plug. That's why BMW and other manufacturers with included-maintenance packages use Platinum... The plugs usually last 40K+ so the Dealerships don't have to change the plugs within the maintenance period.
Copper plugs are cheaper and are actually great plugs for high-HP, high-power ignition applications, but due to the material properties (softness) they tend to wear out more quickly, thus requiring more frequent changes...(for comparison, Iridium is 6x harder and 8x stronger than Platinum, and Platinum is like double that compared to Copper IIRC). That being said, there are a lot of people on here running the cheap Coppers on their stage III's and just change them every (or every other) oil change, so it really comes down to the User preference.
GL!
