Results 1 to 24 of 24
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Is the "flex-pipe" really all that necessary?
    So I was sitting here bored at work thinking about what my car needs "repaired" and done.
    One of those items was the flex-pipe which causes an exhaust leak and my car sounds like shit, thats 1.
    That brings me to the question, Is it REALLY all that necessary?
    My whole exhaust setup is welded and i recently unbolted the testpipe and I was able to push the whole setup back at least a good inch, which makes me think the rubber hangers give enough "flexibility" and a straight pipe would be harder to "rip" than an actual flex-pipe.
    Any feedback?
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Senior Member Two Rings BMT62688's Avatar
    Oct 12 2010
    2013 S5/2003 Vw Passat
    Pittsburgh
    The flex pipe is there to allow for the engine movement when you hit the gas the engine tilts a little a straight pipe would just bend or break so I guess I'm sayin yes the flex pipe is necessary
    Veteran Member Three Rings Adub-Drew's Avatar
    Feb 07 2010
    Wilton, CT
    ^ that would not make the straight pipe break... Idk why you have flex pipe tho, the car could do without it imo.... Never heard of flex pipe being used because the engine "tilts" when under load... Usually people use flex pipe because there either lazy and dont want to get pipes bent, or the lack of money...
    B7 A4 tip (daily) Mk6 Gti Drivers Edition (toy) Soon to come Mk4 R32
    Nov 25 2010
    New Britain, CT
    Flex pipe is there to eliminate vibrations
    Veteran Member Three Rings rvca3112's Avatar
    Aug 08 2010
    brick/nj
    What about the spring that is attached to the downpipe?
    2003 Porsche 911 turbo 623 awhp
    2009 Porsche Cayenne s 317 awhp
    Jul 27 2007
    Orange County, NY
    ^^ mine is just there for shits and giggles now. Haven't used it since i put on my testpipe
    I guess my main concern is scraping the shit out of it again and having to replace it, again.
    I think i'll need that different kind of flex that is more flat
    Aug 08 2010
    brick/nj
    I was rfering to if the spring is needed. Sorry to hijack.
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by rvca3112 View Post
    I highly doubt it. When I did my test-pipe I took it off and never put it back on. Never had a problem.
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    Quote Originally Posted by Coderedpl View Post
    Except for the exhaust leak.
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by eskimopunk View Post
    That's a different story =p
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    have you put any though into having a muffler shop just weld a piece of steel under the new flex pipe, kind of skid plate but only for the flex pipe?
    think panzer plate for your flex pipe
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    Not running one on my car, never had a problem.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by mr shickadance View Post
    Haven't thought about that one. Might talk to the shop about this.
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    the flex pipe is there for a reason...im SURE if AOA found it cheaper, etc, to put in a piece of steel, they would have done so but just like it was pointed out above, the engine will move under load etc. Even my aftermarket downpipe for my B5 from TechTonics tuning had a flex piece. You can even buy just the flex piece if needed.
    either way, if a shop does the work for you,they can delete this flex pipe portion but id like to hear what others/more experienced know & dealt with..OR you can just delete if yourself.....
    Jul 08 2010
    tucson
    danbury
    yea i mean when you think about it, its prolly getting all ripped up because the jagged part of the flex pipe gets caught on the jagged part of roads, if you just had a smooth piece of metal to slide and guard it....prolly would be cheaper and work just as good as a strait pipe
    [CENTER]Scott
    2011 S4
    Jul 08 2010
    tucson
    danbury
    [CENTER]Scott
    2011 S4
    Established Member Two Rings Quattro06's Avatar
    Aug 11 2008
    2006 Quartz Gray A4 2.0T
    Dublin, OH
    My guess would be the flex pipe is there to reduce vibration and reduce stress that would occur with a solid straight pipe because with the engine having that little bit of movement would fatigue the metal overtime causing it to break more sever than when the flex pipe breaks/tears. It's also probably cheaper to put on the flex pipe during the manufacturing process and cheaper to fix if damage were to occur. That's just what I think with the knowledge I know.
    2006 Quartz Gray Metallic. Tint: 50% front, 35% back. Custom Tint Tail by CSN Motorsports. Deval CF spoiler. CF wrapped B-pillar covers. MTM Stage 2. MTM Catback. 034 HFC. Techtonics DP. CIM boost gauge. Forge DV. Votex Side Skirts. 3M Di-Noc wrapped trim.
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    Quote Originally Posted by Adub-Drew View Post
    Uh, that's the exact reason a flex pipe is used.
    Do you need it? Maybe, but I'd imagine that your welds would be more prone to cracking if you didn't have one.
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Aug 08 2010
    brick/nj
    So you think I should look into getting one back in? I lost mine during my hfc install...
    Jul 27 2007
    Orange County, NY
    If you don't have exhaust leaks now why worry?
    Aug 08 2010
    brick/nj
    Because I don't want the exhaust leaks in the future my non s-line brotha. Plus ever since my Hfc install I had this vision that the exhaust would rip a hole in the tranni where it's attached. With all my monster power from my k03 haha.
    Jul 27 2007
    Orange County, NY
    I wouldn't worry about it. I've had the VMR testpipe and now a 3" custom and never had problems with that part, just the flex, for the sole reason of me being low.
    Senior Member Three Rings RandyQUATTRO's Avatar
    May 21 2008
    VW Tiguan
    I don't have the answer but I feel your pain. The flex pipe on my Stasis exhaust developed a crack and it's killing me. It sounds like everything I have come to hate in terms of sound. It's really embarrassing. Was driving next to a silent Telsa today and all I could hear was "putt, putt, putt!"
    2007 6MT Quattro S-line /APR Stage II/ Stasis Exhaust / Stasis Ohlins SLs / 034 Billet Catch Can/ 034 Street Density Motor Mounts / 034 Snub / DICE iPhone integration
    Jul 27 2007
    Orange County, NY
    yea i didnt care in the winter too much but now its driving more insane each day.
