i just installed the $46 VDO regulator from Amazon over the weekend. it is going up very slow and is so strained - it wont go all the way up.
i just replaced the window regulator 2 years ago - so i am familiar with the task. last time i bought the part from world impex and it went in very easily and worked great - unfortunately it only lasted 2 years.
i took it apart, checked everything, lubricated it, and carefully re-installed it and it is still tight. without the window attached, the glides slide reasonable well. but it is difficult to get the window on the glides. something seems a bit off, which i am guessing is causing it to bind.
i am not sure if there is something i can do to remedy this or if i should try to return the amazon part and get one from ECSTuning or other source.
