Results 1 to 13 of 13
    Established Member Two Rings PGJ's Avatar
    Jul 25 2010
    B5 S4 Avant, 1972 Volvo 1800E
    RI
    Doing suspension - what else should be replaced
    Recently picked up a 2001 Avant (6-speed! all stock!...took me 20 months to find it...) w/ about 70K. I'm getting the stasis SS coilover suspension installed. I was looking through some DIY write-ups and nothing really addressed what wear/tear items should be replaced during the suspension install. I'm coming from an e46 3-series and I know that just about everyone who does a suspension on one of those has their shock/strut mounts replaced (usually w/ M3 mounts). Is replacing mounts recommended? Anything else? I'm actually having my BMW tech do the install and since he's not as familiar w/ an S4 I wanted to point anything like this out to him.
    Dec 09 2005
    Sayaovong
    I would suggest considering replacing all the control arms/tie rod ends, while your replacing the suspension. The car would ride like new again with new control arms.
    2003 RS6 Ebony
    2010 Q5
    2014 Q7 S-Line
    Jul 25 2010
    RI
    this is already starting to get expensive....
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    Quote Originally Posted by Drifters View Post
    X2
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Active Member Two Rings cactus_b5s4's Avatar
    Feb 12 2011
    Southern New England
    And perhaps the axles.
    Last year I picked up a '00 s4 and replaced the above along with the front axles. My car is very smooth on stock shocks and springs.
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    I'd do the 4 upper front control arms, tie rod ends and upper strut bushings. About $500 for those parts typically.
    Established Member Two Rings joespaman's Avatar
    Feb 17 2011
    2003 Porsche Boxster S, 2008 Ford Mustang Bullitt
    Athens, TN
    Wheel Bearings if you are in that deep doing control arms and tie rod ends, and an alignment. Aren't these cars fun!?!?
    Veteran Member Three Rings jesters22's Avatar
    Oct 14 2009
    new jersey
    could look into wheel bearings aswell, ontop of the control arm kit. a normal control arm kit could be anywhere from 300-500+ for a full 12 or 14? or how ever big the kit is. make sure u get heavy duty tie rod ends.
    PARTING OUT A SILVER 2001.5 S4 PM ME FOR PARTS
    http://forums.vwvortex.com/showthrea...2#post83363922
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by Skyler@Achtuning View Post
    ABSOLUTELY. Just went through this myself... I think when you do any suspension modifications you should replace these things. I had tired mounts that started knocking like crazy and man, replacing them the car feels way better than before even before I started hearing knocking from them.
    Veteran Member Three Rings 2kblacks4's Avatar
    Jan 04 2007
    2000 black s4 6spd
    Birmingham Al
    The mounts that go on top of the strut. http://www.ecstuning.com/Audi-B5_S4-...Shocks/ES1903/
    4:11 posi track out back, 750 double pumper, edelbrock intakes, bored over 30, 11 to 1 pop up pistons, turbo jet 390 horse power, where talking some fucking muscle!!
    Veteran Member Four Rings Dutchsider's Avatar
    Aug 19 2010
    NEPA
    while your at it, you might as well go big turbo too
    Jul 25 2010
    RI
    are you referring to the strut mounts that 2kblacks4 linked to? or are these a different part
    Sep 16 2009
    Delray Beach, FL
    gt2871s
    2001.5 S4 - Stolen
    2011 M3 - Blown up
