Results 1 to 32 of 32
    Mar 13 2010
    nj
    Has anyone tried the KW street comfort coilovers?
    I was looking for a conservative drop and as close to stock ride as possible and decided to go with KW street comfort CO's. I've been trying to dig up any information I could find, but haven't found any B8 S4's with this setup, so I figured I'd post to see.
    I considered a few others, but I wasn't concerned with the other options that had more adjustments...I don't plan on tracking the car and will more than likely have them installed and never touch them again.
    anyone? if not, I'll be sure to post a review as soon as I get them installed.
    Mar 13 2010
    nj
    had them installed yesterday...here's my quick review.
    I set out to get something that would give me height adjustments and minimal sacrifice of ride comfort, so I chose the KW street comforts.
    In addition to the height adjustment, the co's have adjustable rebound dampening. The ride height after lowering the car is at 25.5 inches, measured from the ground to the top of the wheel well arch. We set the dampening to the middle setting. The install was done in about 4 hours.
    The first thing I noticed was when accelerating the car stayed level and same with braking. Going hard into turns, the car felt much better, in that it felt planted. I was surprised when going over bumps and bad pavement the car felt just like stock, I expected it to be a little harsher.
    Once my wheels arrive, I plan on getting the height adjusted and maybe the dampening to be a little more aggressive.
    So if anyone is looking to maintain stock like ride comfort, while still being able to lower the car and a step up in handling...I definitely recommend taking a look into the KW street comforts. From what I was told, they are similar to the V2's in terms of adjustments, but with more stock like comfort.
    Veteran Member Four Rings t0mt0m's Avatar
    Apr 26 2005
    Nothern Va
    pictures...pictures..pictures
    which setting do you have your suspension on in the pictures and did you wait a couple days to let the springs settle.
    B6 A4 1.8t 5MT Quattro - Sold
    B8 S4 '10 6MT Prem+ - Sold
    Mar 26 2010
    US
    So which KW street comfort version did you get TUEV approved # 18010075 or the other one # 18010097
    Other than the TUEV approval (cheaper Price), I don't see any difference in the specifications.
    http://shop.kw-suspensions.eu/index....&pg=160&page=1
    BMW M3 Competition X-drive
    Mar 13 2010
    nj
    I was waiting for my wheels before i took any pics. going to ride on them until wheels get here, about 3 weeks, then mount the wheels and play around with settings and then get the alignment.
    only setting other than height is the rebound dampening and it's set in the middle currently
    Quote Originally Posted by t0mt0m View Post
    Mar 13 2010
    nj
    I have the 18010075
    Quote Originally Posted by wwhan View Post
    Mar 13 2010
    nj
    i think the main difference between the street comfort and v2 is the springs...street is linear and v2 is progressive i believe.
    Mar 02 2007
    Fresno, CA
    I'd love to try them, but I'm afraid they won't go low enough since I've heard they have a more limited lowering range.
    Mar 26 2010
    US
    Quote Originally Posted by phantomblack View Post
    But both numbers, 18010075 & 18010097 , are street comfort not V2.
    I think the 18010097 has the Electronic damping control deactivation kit is included (Fzg. mit elektr. Dädämpferregelung,
    Cars with electric. DÃ ¤ damping control)
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    A4 B8 visitor -
    Any new info re the Street Comfort set up?
    I've had the V1's on since May 2010 on my '09 3.2L Sedan, then with 18" VMR, now with !9" VMR - ride has always been harsh - smallest street pavement bump causes harsh suspension response - as if shocks are not functioning.
    Any ideas/inputs appreciated.
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Mar 26 2010
    US
    Quote Originally Posted by Greg Nelson View Post
    A4 B8 visitor -
    Any new info re the Street Comfort set up? .....
    I have the KW Street Comfort Coilovers on my car. It has 15mm KW spacers # 65030045 on the rear. The ride height is set to around 26.1" all around. The shocks/struts are set to 12 clicks from firm (6 clicks from soft). I like the way it handles and rides, better than factory. We have a lot of buckled roads around here.
    The car also has the Hotchkis F/R sway bar and the Alu Kreuz from Eurocode.
    Mar 02 2007
    Fresno, CA
    Did you need the spacers because the rears settled too low compared to the fronts?
    Established Member Two Rings Yeaayouu's Avatar
    May 10 2010
    Honolulu Hawaii
    where is the best place to order a set of these?
    Veteran Member Three Rings Zed 2.0's Avatar
    Feb 12 2010
    San Diego
    Word of warning about KW and the B8.
    http://www.audizine.com/forum/showth...ging?styleid=8
    Mar 13 2010
    nj
    since my install I've had to adjust the height 3 times, I'm not sure of the height or how much room I have on the front or back for adjustment height....but they do seem to sag with very little time.
    I like the ride, it's a good balance of comfort and performance.
    Mar 26 2010
    US
    No, the Street Comfort KW springs were too low in the rear (25.5") out of the box. Most people had this problem... too low out of the box.
    I have not had any settling ... yet.
    There was at least one person with the KW V2 that sagged after awhile.
    Veteran Member Three Rings bengtc's Avatar
    Mar 13 2009
    2012 S4
    Dallas
    bump, can we get some more opinions on these, also how much do the street comforts drop the car(max)?
    2012 S4 black, prestige, titanium, sport diff
    ** stasis tune ** kw street comfort coilovers ** vmr v701 19x9.5 midnight blue ** awe res exhaust res dp's quad black diamond tips ** injen intake **
    ** alu kreuz ** hotchkis front and rear sways ** spc adj control arms ** 034 end links ** akebono ceramic pads ** ecs slotted/drilled rotors
    ** rs4 grille ** blesk led plate bulbs ** hoen yellow fogs ** drive tech interior LEDs **
    Veteran Member Four Rings Seinsmeld13's Avatar
    Mar 23 2009
    2020 Porsche Spyder
    Niagara Region, Canada
    Another option is the Bilstein PSS10. My installer did a shitty job. The car drove terribly, very harsh. I have since taken my car to guy that specializes in suspension and alignments. He adjusted the height and corner balanced the car. Night and day difference. I also had the original installer refund my installation as their mechanic really messed up the installation. I had asked the mechanic to set the car 4 F and 6 R. Wasn't even close. Anyway I'm running 4 F and R. I'll post some pictures for comparison to the KW's.
    Jun 26 2012
    newton nj
    Was 25.5 as low as they could go?
    Mar 26 2010
    US
    Quote Originally Posted by pennstate93 View Post
    That was the Maximum adjusted height, in the rear, without adding the additional KW spacer. It goes a fair amount lower.
    Oct 25 2007
    Scottsdale AZ
    I ordered these to replace H&R coilovers. Ride quality has just been too harsh especially after moving to the Bay Area. Looking for something closer to OEM but still want a decent drop so the wheels don't look ridiculous.
    I'll post thoughts and comparison after they're installed.
    16 Glacier S6 - Sport, Black Optic, Layered alum, Bloze
    13 Orca Black Q7 - TDI Prestige - S-line - S-line Plus - Air Suspension - B&O - Tech - Towing
    16 Nardo Gray RS7 - GONE
    11 Ibis S4 - Prestige - Titanium - Sport Diff - APR Stage 2+ - 35% Huber Optik - Black BBS CH-R 19x9.5 - KW SC coils - E-codes - RS6 Air Shifter - AK and USS sway-bars and end-links, GONE
    08 GMG S5 - GONE
    01 Casa S4 - GONE
    Mar 26 2010
    US
    Quote Originally Posted by etvois View Post
    +1 Bay area roads are pretty bad, the ADS option would have been a good idea in hindsight.
    Choose damping setting carefully, the top of the dampers need to be accessible (generally removed) to adjust. If you want it soft, then set around 3-4 clicks from soft. At 2 clicks from soft, it may be be too soft to control the springs. Also, tire pressure makes a difference.
    If you don't add any KW rear spacers, the maximum height (rear adjuster set to 1.6") is 1.2" lowered.
    Oct 25 2007
    Scottsdale AZ
    Took your advice.. Installed them at 26" ride height (previously 25.5 on H&R) and 3 clicks from Soft.
    Rides pretty good. Definitely a bit more bouncy and more lateral movement noticeable. Much less harsh though. I'll probably do the whole USS AK and sway-bar upgrade and see if that dials it back in while keeping the harsh ride away.
    Only a few miles of testing so far so can't be more detailed reviewing them yet.
    08 GMG S5 - GONE
    01 Casa S4 - GONE
    Mar 26 2010
    US
    The sway bars stiffen it up a little, the end links stiffen it up noticeably more & helps the steering response. Not a bad compromise, but the ride is stiffer with the end links & it does reduce the bounce.
    Nov 06 2009
    London
    Right guys, I'm bumping an old thread, as when I tried to do some research on the KW comfort coilovers I couldn't find any useful reviews or feedback.
    Well I took the plunge and bought these, my concerns were that they don't go low enough
    Anyway, I've got the car back with them fitted and... WOW
    Seriously, I've owned a number of performance audis and most with aftermarket suspension, ranging from the B5 RS4 to B7 RS4 with PSS9s and KW V3 as well as having run the H&R springs on the DRC
    These KW street comfort are by far the best I've rode in, amazing comfort, much better than the OEM S5 suspension.
    The ride height is spot on, hovering above the tyres all round, with more scope to go lower on the fronts.
    Car is planted with less body roll, I'm in London with some of the shittiest roads and speed bumps, and the car glides over them, steering feedback is reduced slightly but this can be cured by installing ARBs which is next on my list.
    Zero nose dive on hard braking
    It's been 3 days of continuous driving and so far I give them 5/5
    If like me you were on the fence, go for it, I nearly made the mistake of going with H&Rs instead, so glad I didn't
    Nils
    Current: B8.5 S5. Instagram :- n_i_l_s
    Nov 06 2009
    London
    Oh and for the record, I don't track mine, I don't plan to, I drive it enthastucally when the conditions and roads allow
    I wanted to retain comfort as well as have a nice drop, a usuable drive height on a family car
    KW street comforts = winner
    Apr 19 2013
    SF Bay Area
    Well, the ride height is good for now. Just wait about 5k miles and see where the rear sits. Common issue with KW and I'm going through this right now. Rear is sagging so badly that I'm covering 1/2" of the rear tire and can't adjust any higher. Wasn't this bad when i first got them, was pretty low but now I rub on every little bump. Rear only, front doesn't seem to have changed at all and no rubbing issues. I read through all kinds of KW threads and seems somewhat common, but, you know how it is, you only hear the bad stuff....mostly. Anyway, the other complaint is the customer service sucks. And I can attest to that. I just got off the phone with them and the dude got a bit testy and rude with me when I started giving him part numbers and asking questions. He's going to send me the infamous "measurement sheet" to confirm that I indeed have a warranty claim. The adjustment collar is at the very bottom of the spring perch with about 1/4" of exposed internal threads on the purple collar. Meaning that the collar is hanging off the end of the spring perch. The two fixes seem to be use avant springs in the rear, they're longer but same spring rate. The other is put a spacer from KW between the collar and the spring. KW never has them in stock and won't warranty them to you. BTW, the 15mm spacer won't work, you have to go either 30m or 50mm. HOWEVER......It's not all bad. I agree with you, I like the way they perform. Mine is a street car only. The ride is great and the handling was much improved. I originally got them because of their "mild" minimum drop of 0.4" rear.....uhhhhh.....try 1.5" min. Anyway, seems like a good product for the most part, good features like Stainless bodies for corrosion, etc. Just be prepared to go through some headache when the stuff eventually hits the fan. I won't buy from them again. Too expensive for crappy customer service.
    Junior Member Two Rings nicsplosion's Avatar
    Feb 21 2018
    Orange County, California
    Quote Originally Posted by superbee6 View Post
    I just got kw street comforts too and I seem to be sagging after about 10k. I haven't heard about the avant spring option. Do you happen to know how much taller? I'd be willing to lose some lower end height if I can convince myself they won't sag again
    Sent from my Pixel 2 using Audizine mobile app
    2019 S5 Sportback - Quantum Grey - Stage 1
    2015 S4 - Daytona Grey - Stage 2+
    Apr 19 2013
    SF Bay Area
    Sorry, I hadn't looked at this thread in a few days. I think I read where the Avant springs are supposed to be 10mm taller. But when I sat the Avant spring next to the ones I just took out, the difference was about 35mm. KW is currently out of stock on the Avant springs. I have two coming from Germany in a couple weeks, and I'll be putting them up for sale since I bought the last two to get back on the road and they wouldn't give me a refund. Would only send out another set of springs. Very useful to have extra springs laying around collecting dust. And great customer service. Not Buying another KW product.
    Feb 21 2018
    That sucks to hear man. I worked with a local shop instead of dealing with K&W directly, they shipped me a set of replacement rear shocks overnight. I may be only sagging a bit on the right, now that I know the rear shocks were the problem. Not very promising with <24k on them. That said, I'm still on the fence about KW at the moment. We'll see how long the replacement setup lasts.
    Going to have it looked at tomorrow while the new rear shocks are installed.
    Sep 25 2017
    Sweden
    Quote Originally Posted by N11LS_J View Post
    Nils
    What setting(clicks) did you have them dialed in at? :)
    Registered User Two Rings
    Aug 11 2016
    Connecticut
    Holy old thread, Batman!
    I have these coilovers installed, and they're great. Car guy friends can't believe that coilovers could be so comfortable, and it handles a lot better than stock as well.
    I have my dampening set to the stock setting. I think 12 clicks from the left? You can't really change the dampening settings once you install them, so I decided to trust the KW engineers.
