Results 1 to 40 of 40
    Mar 27 2011
    How do you remove the 130 mph speed limiter?
    I have a 2011 A4 and would like to set the car up to German spec, which would be a top speed of 152 mph. How do I remove the 130 mph speed limiter? Would an APR chip achieve this or is there some other method? Thank you for the help.
    Veteran Member Four Rings MilesM's Avatar
    Jan 17 2011
    RSQ8
    LA / SF
    APR chip would achieve this, as well as removing the 4.5k rpm limit in neutral.
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    As far as I know most chips do this.
    Veteran Member Three Rings miggity02's Avatar
    Mar 22 2008
    '17 SQ5, MK7 GTI
    East Bay, NorCal
    Chip. No speed limiter and redline is raised another 500 rpm or so.
    '17 SQ5-034 Stage 2 ecu/tcu-JHM 187mm CP-034 inlet, RSB, sub frame inserts-Eurocode trans/diff mounts-Alu Kreuz-B8/H&R-Neuspeed RSf72 20x9.5 et25-Magnaflow 11385-OEM airbox mod-aFe 11-10121
    Mk7 GTI-034 Stage 1 ecu/tcu-H&R springs/B8-Neuspeed rse11r
    Triumph Street Triple R-Full Arrow and tune
    Mar 27 2011
    Would the Stasis chip, available through some Audi dealers, also remove the 130 mph speed limiter?
    Mar 22 2008
    '17 SQ5, MK7 GTI
    East Bay, NorCal
    I think all chips do the same basic things...higher redline, no speed limiter, "better" mpg, and quicker throttle at least in the stage 1 format.
    Established Member Two Rings sonofander's Avatar
    Mar 16 2011
    Monrovia, CA
    APR tune FTW!
    Ibis White 2011 Audi A4 2.0T Premium
    APR Stage II, Eurocode HFC and IC Pipe, ST Coils, OEM S4 19"
    Halogen-->Bi-Xenon Conversion, Hoen Xenomatch Fogs, Blesk Plate LEDs
    F1 Ceramic 30%, P+ Stalks, Exhaust Tips, De-badged, Vag-Com Mods
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    i'm APR chipped but i still can't rev pass 4k in neutral when i'm not rolling. APR says the speed limiter has been removed but i've yet to test that out lol
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
    Jan 17 2011
    RSQ8
    LA / SF
    Quote Originally Posted by hiwords1 View Post
    Hit it today. Lol. And I've gone past the 4.5k in neutral multiple times. Hmm, maybe it's a stage II thing?
    Veteran Member Three Rings BMWBig6's Avatar
    May 20 2008
    Georgia
    So how fast is the 2.0T with the limiter removed? And is it limited by aerodynamics, power, or gearing?
    2020 F-Pace SVR / 2016 GLE350 4MATIC
    Favorite Former Rides: 2015 Boxster GTS / 19 E450 Wagon / 2015 X1 M Sport / 11 F-150 Limited / 09 A4 Avant / 08 TT / 03 SVT Lightning / 01 SVT Lightning / 93 740iL / 90 535i / 86 944 Turbo / 83 944
    Senior Member Three Rings EuroEclipse's Avatar
    Dec 30 2009
    2012 Evolution X GSR / 2012 Volkswagen GTI
    Germany/Colorado Currently
    Quote Originally Posted by BMWBig6 View Post
    I'll let you know when I get mine flashed since I can legally do it :) Or one of the other German drivers will chime in.
    Jan 10 2007
    VA
    Why do you need to go faster than 130mph?
    PS...Many speed limiters are set due to tires, so if you do remove the limiter make sure your tires are the correct speed rating before testing it out.
    Aug 27 2008
    Houston Area
    Very doubtful it's gearing. The 6MT is geared for something like 195 mph, and both the 6/8 speed tips are geared taller.
    At 195 you would need more than 300 HP just to overcome the aero drag if Audi's 0.27 Cd and 23.68 sq. ft. frontal area are correct.
    2013 6MT S5 - Monsoon/Black
    Prem+ | Sport diff | Adaptive dampers | Nav | B&O
    Res AWE exhaust | USP intake | USS Sways | OEM 19" speedline | AluKreuz | 034 Trans mount | Interior LED | VCDS tweaks | F1 tint | Xpel PPF
    Previous : 2009 6MT A4 | Quartz/Black | Prem+ 2001 5MT A4 | Silver/Black | Premium pkg
    Mar 27 2011
    mmaroney, What did you "hit today"? Does that mean you have an APR chipped car, but still were stopped at the 130 mph limit? So the chip does not eliminate the limiter?
    Another note: A car that was meant and built to go 152 mph, should be able to go that fast and not have the balls cut out by the government or insurance lobby. For all the wonder of electronics, they have there downside and this is one of them. I used to have a Porsche 944 with a listed top speed of 130 mph, but those cars didn't have limiters, in reality its top speed was 147 mph. Always switch your tires to Z-rated.
    Veteran Member Three Rings quality_sound's Avatar
    Jan 29 2005
    Ramstein AB, Germany
    Why would you EVER want to go that fast in an A4 on US roads? I hit 165MPH twice in my '10 M3 on unlimited sections of the autobahn and that was simply to see if my car had the limiter in place or not. You'll NEVER, under ANY circumstance, be able to hit the limiter in the US. Not on the highway (well, not legally), not on a track, not on a dyno. Doing it just to be more "euro" is kind of silly IMO.
    My $.02
    Veteran Member Three Rings jordancl's Avatar
    Jun 29 2010
    MA 01230
    yes be careful, this reminds me of that M5 thread :(
    Sep 07 2010
    centreville va
    Got my car up to 130mph on rt. 66 in western va on Sunday. A AMG pulled up beside me. He pulled away quicker but for a 4 cylinder in 6th gear and stock i was happy with it. :)
    Senior Member Three Rings neptunesfinest's Avatar
    Jun 03 2010
    New Jersey
    Quote Originally Posted by quality_sound View Post
    My $.02
    Obviously not legally in the US but it's not that hard to get up to those speeds in this car. I wanted to see what the car had so I got up to 123 at one point (nobody on the road, I promise) and the car still had a lot in it...just wasn't willing to push it any further.
    Quote Originally Posted by jordancl View Post
    What happened?
    Jan 10 2007
    VA
    M5 owner posted on a forum asking how to drive his car faster, saying he was pushing 140+ and having shifting issues, 12 hours later he wraps it around a tree and died.
    Quote Originally Posted by neptunesfinest View Post
    What happened?
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    There's a reason speed limiters are installed on US cars - the reason is people like you who would want to exceed such limits on our highways, endangering the lives of people whose lives and family members are worth far more than your thrill-seeking ****.
    If you want 'Euro-Spec' speed, suggest you go to Germany/Autobahn - they'll likely blow your doors off, then you'll hopefully grow up.
    Don't like nanny-state regulations, in this situation appropriate
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Jun 03 2010
    New Jersey
    Quote Originally Posted by b6onboost View Post
    Just read the thread...damn what a sad story...
    Mar 27 2011
    I have driven in Germany in the early 1990's and I driven in Montana in the mid 1990's when the speed limit was "reasonable and prudent" and I have driven the long barren stretches in Nevada many times. Which is why it saddens me that most American's don't have the knowledge or the balls to drive at speeds that Germans would still consider laughably slow as most Autobahnen traffic flows in the unrestricted zones in the mid 150 mph range.
    Why should a car be allowed to go even 130 mph if its so dangerous? As a matter of fact, since we will now all run to the safety of the government, why not mandate speed limiters at the current maximum speed limit in the United States, 85 mph. Then we can all be servants of the government.
    I have a license to carry a gun, I enjoy driving in the mid- 140 mph range, and I am a free American that has never caused an accident after being licensed for over 20 years. I have however been hit from behind by a cement truck while drive 20 mph in traffic, had a van hit my driver's side door while stopped for a red light, and had a drunk hit my passenger side door while she was coming out of a bar. I am responsible. I find the safety Nazis are the people who block the left lanes and cause more than their fare share of accidents. Lastly, in 20 years of driving I've only had 2 points on my license, which is why I'm on my insurance company's top insurance tier and I enjoy a "safe driver discount" while paying the lowest rates for my demographic rating. I would put up my DMV and accident-free record against any safety Nazis and you would find I'm the safer driver.
    Jun 03 2010
    New Jersey
    Quote Originally Posted by mqbond007 View Post
    Definitely true...130 vs 150 is not a huge difference. Both are way over any US speed limit.
    Never understood people who block the left lane. It forces people to weave in and out and pass on the right, especially the really reckless drivers. Why would you want a reckless driver weaving traffic when you can just let him go up the left lane? So many people believe that driving the speed limit is the most important thing in driving and they neglect thinking and paying attention. People who block the left lane are either stupid or just not paying attention. I'd rather share the road with a speeder...
    Oct 27 2009
    Miami, FL | Boone, NC
    wow... I just read the thread too. Really is a sad story - I feel bad for those kids and their families...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Jan 17 2011
    RSQ8
    LA / SF
    Without incriminating myself on a forum (I've read and this is actually possible to do, so please be careful what you post guys.), I can tell you the limiter is removed.
    Jun 29 2010
    MA 01230
    i went 175mph this morning
    Jan 29 2005
    And not having the limiter would change this how? If you wouldn't go past the limiter set at 130 why would you care about removing it.
    Also, you weren't going 123. You were likely in the 115-118 tops. Speedo error. Use a portable navi to plot true speed.
    Jan 29 2005
    I thought he drove it off a cliff on an abandoned runway with 3 friends in the car with him.
    Jan 29 2005
    Not anymore it's not. 130KPH (80MPH) is the recommended speed, even on unlimited sections, and you will be fined/ticketed if you get into an accident going any faster than 130KPH. Even in a solo accident.
    And traffic does NOT flow at 150MPH on the unlimited sections. Not even close. Most traffic sticks around 80MPH with fast traffic in the 110-120MPH range.
    Jun 03 2010
    New Jersey
    Also, you weren't going 123. You were likely in the 125-128 tops. Speedo error. Use a portable navi to plot true speed.
    I never said I cared about the speed limiter or wanted to remove it...the OP did. Also, there's sampling error any way you try to calculate speed (or almost anything, for that matter) but thanks for the statistics lesson either way.
    Veteran Member Three Rings Cherub's Avatar
    Jun 20 2010
    Golf-R
    FL-Global
    Any idea where a chip for a 09 3.2 B8 can be purchased from? Thanks for any help
    MK7.5 R Daily
    B9 S4 (Pending Sale)
    2 B8.5 & B7 - Sold
    Tints & More..........
    Dec 30 2009
    Quote Originally Posted by Cherub View Post
    Have you tried talking to APR?
    Jan 29 2005
    I meant "you" in the general sense, not you specifically. Apologies for being vague.
    Yes, there is an error but GPS tracking is going to be more accurate than your speedometer, which was the point.
    Feb 19 2011
    Perhaps knowing (or believing) the limiter has been removed is the important thing, even if one is never going to test it. We human beings are funny sometimes.
    I did learn from this thread that my vehicle is likely no longer limited to 130. Considering that I haven't been over 100mph on public roads in 10 or more years, and I don't plan on visiting a track in the foreseeable future, I guess I'll never test it.
    But its nice to know
    Formerly 2011 A4 P+
    Jun 20 2010
    Golf-R
    FL-Global
    Looked on the website and didn't see any chip for the 3.2, I'll e-mail them. Thanks
    MK7.5 R Daily
    2 B8.5 & B7 - Sold
    Mar 27 2011
    Last call to see if anyone else can certify that the APR chip removes the 130mph speed limiter.
    Thanks
    Happy Driving.
    Jan 17 2011
    RSQ8
    LA / SF
    Thanks
    Happy Driving.
    How many statements are you looking for? It's been said multiple times that it does. Lol
    Veteran Member Four Rings mattlqx's Avatar
    Dec 21 2006
    ‘16 F-150, '01 Jetta 1.8 Race Car, '05 Allroad 2.7T, ‘14 Fiesta ST
    Chandler, AZ
    Perhaps the police officer can tell you he clocked you at 137 in a 65 when he pulled you over and put you in cuffs for criminal speeding and then you'll be happy?
    Tons of Audis, Tons of Mustangs. That's just how I am.
    Deactivated Two Rings
    Mar 15 2011
    Arizona
    If you have the sport pkg with the Y rated tires that come with it your tires are rated at a higher speed then the car will go unless your going down a mine shaft.
    Mar 02 2007
    Fresno, CA
    This thread is going nowhere fast (over 130mph).
