Results 1 to 21 of 21
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    DIY: Removing B6/B7 Avant Roof Rails
    Alright guys, sorry this took so long. The pictures aren’t great but the steps are correct; please post if you have any questions.
    The B6/B7 avant roof rails can be easily removed without dropping the headliner. There are 3 allen head nuts holding each rail on that can be accessed by removing all the trim around the headliner. Unfortunatlely, the cargo area also has to be dismantled to get this trim off.
    For this DIY all you need is a screwdriver, a torx set, and a long 8mm allen wrench.
    Step 1: Remove cargo area floor.
    Step 2: Remove 4 torx screws along the back bumper, remove trim that covers tailgate latch.
    Step 3: Remove all 4 tow hooks. There are two torx-head screws on each.
    Step 4: Remove side panel. There is one screw on each side panel, where the panel meets the D pillar trim. After removing this screws, you can just pull the side panel off; there are four metal clips that are very strong. Pull straight out towards the opposite side of the car. Pull, pull, pull and then pull more. You will feel like youre going to break the panel. The panel is very strong though. I’ve done this on 4 avants have not had any problems whatsoever. Below is a picture of the back side of the side panel and you can see the 4 metal clips.
    The best strategy is to find the metal clips with your hands and pull as close to them as possible, just to make sure youre not bending things too much when you pull. The four clips are show below.
    Step 5: Remove torx bolt behind clothes-hanger hook. Open the spring loaded cover and you will see the torx bolt behind there.
    After removing this bolt, all you have are 2 metal punch clips like the side panels, and a metal clip that you slide the d pillar trim away from, towards the back of the car.
    Like the side panel, try to stick your hand under the D pillar trim and pull from where the clips are located so as to reduce the leverage you are putting on the trim piece. After removing the two clips and the torx bolt, pull towards the back of the car and the trim will slide away from the last clip. Do not pull outwards; you will break the clip. Below is a picture of the back side of the trim showing the attachment areas.
    Your first allan-head rail nut has been exposed! It is an 8mm nut.
    Step 6: Remove trim above rear door. This is held on by 4 screws and one big torx bolt. After removing the D pillar trim, you have already exposed the first torx head screw. Next, like the D pillar trim, push the spring loaded cover open on the clothes hanger hook to expose the large torx bolt. Remove this.
    Pop the covers open on the “oh shit” handles with a screw driver. You will see 2 torx head screws. Remove these.
    Pop open the plastic cover with “Air Bag” bag written on it. Remove the screw you have exposed. You can now remove the trim above the rear door. You have now exposed the second roof rail nut. It is also a 8mm allan-head nut.
    You should look like this now.
    The trim above the front door and A-Pillar doesn’t have to be completely removed, just pulled aside to expose the last rail nut. Pop the covers open on the “oh shit” handles and remove the screws. Pull the trim back and you have exposed the last nut. This one is tricky, and you may want to unscrew one of the curtain airbag screws and pull it down to get enough access to it. Your best bet is the longest, skinniest 8mm allen wrench you can find.
    Reinstallation is the same as removal, but from the front of the car to the back.
    Black
    Aluminum!
    Veteran Member Three Rings CCA4's Avatar
    Oct 25 2009
    Ford Raptor
    Erie, PA
    lovin the aluminum rails man, that looks great. some brushed mirror caps would really set the rails off!
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by CCA4 View Post
    Workin on it...everyone wants an arm and a leg for them though!
    Veteran Member Four Rings michgo's Avatar
    Oct 21 2007
    Wagon/Variant/Avant A4 B6
    Bravo sir. Well played and thank you very much
    I heart wagons.
    'It's actually a pretty big pet peeve of mine when people mess around with my photos', MmmBoost
    shave it mold it sand it paint it
    Oct 21 2007
    If you decide to leave your rails off, you can simply use sedan racks to carry your racks
    I heart wagons.
    Jan 29 2010
    north ga
    Kinda defeats the purpose of getting rid of them doesn't it?
    Oct 21 2007
    Quote Originally Posted by BCsniper View Post
    I am in love with the look of the wagon without roof rails. So subtract then add for me
    I heart wagons.
    Jun 21 2005
    Milton, Ontario
    Quote Originally Posted by michgo View Post
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Senior Member Three Rings patastinky's Avatar
    Apr 07 2011
    2015 Overland
    EARTH
    wtf!
    Apr 01 2005
    one wagon one truck
    Michigan
    wow, love the contrast in color.
    Veteran Member Three Rings Cadiburns's Avatar
    Feb 17 2010
    Chicago
    LMAO! Nice lunar mobile. It's hideous.
    B5 Casa S4 Avant | Tial 605s | EPL | Aquamist
    Established Member Two Rings snail_power's Avatar
    Mar 29 2011
    Is there any holes left behind by removing the rails?
    01 S4 Avant 6spd
    00 2.8 Avant 5spd
    old:2007 Avant S-Line Titanium 6spd man (victim of rear end totaling)
    2006 S4
    Sep 02 2008
    Boonies VA
    Quote Originally Posted by Cadiburns View Post
    To each their own, while I would not do it to my Avant I think it looks good.
    Quote Originally Posted by snail_power View Post
    If you are removing the rails completely, then yes, you would have holes left behind. 3 on each side.
    White Wagon
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    You'll have three rectangle holes on each side.
    Nov 03 2011
    All Over!
    A very old thread, but I thought I'd add to it anyway.
    Yes, there'll be 6 holes left in the rain channels. There are rubber bungs from Audi, that plug the holes. Apparently they're harder to insert than your average blind grommet, which would suggest they're water tight.
    1986 Type 85 Audi 90 quattro
    Active Member One Ring Bert31's Avatar
    Apr 10 2017
    Albuquerque, NM
    Does anyone know what part # that is? Thanks
    Senior Member Three Rings studiobmx's Avatar
    Jun 20 2016
    1.8T Vanagon, B7 Avant, C5 Allroad, NCV3 Sprinter, Q5 (wife's), CB550
    Tacoma
    Feb 04 2016
    Boston
    Quote Originally Posted by Bert31 View Post
    Anyone?
    Apr 10 2017
    Albuquerque, NM
    Quote Originally Posted by NEAllroad View Post
    Anyone?
    Let me look, I found the part # and ordered through Genuine Audi parts. This summer I actually removed my roof rails.
    2005.5 B7 Avant Quattro 6MT
    Feb 12 2008
    Michigan
    do the side airbags need to be disconnected?
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    No
