When I asked the reason of a broken third gear to the transmission shops and follwers here, I came up with 2 main resasons.
1. Main shaft ends up flexing causing the 3rd gear set to pull away from each other and then starts chipping the teeth off.
2. Some say main shaft is not flexing it self but the gears are not strong enough to handle that kind of power.
So, I had a discussion with a local machine shop and explain these situations to them briefly.
They came with a solution for this issue; they offered first do the metalogical test on the input shaft and the gear.
According to the result ,they will decide if a stronger material would help for input shaft, if feasible they may produce a billet shaft
The production of the gears are also possible however they increase the costs and more work needed.
As a conclution , I am thinking to go with a billet shaft and replace OEM one but I am not sure only a billet shaft itself can solve this issue.
What do you guys think about this issue ? if you think it can help, I can also offer these billet shafts to B5 users !
