Results 1 to 15 of 15
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Front rotor screw completely stripped...now what?
    Anybody do this to themselves? I'm thinking ahead of time since I'll be doing some service on the front-end of the car and i know my front rotor screw is stripped.....idk wtf will fit there to be honest haha....any ideas?
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Jul 04 2007
    Anchorage, AK / Chicago, IL
    yea, I did that when I changed my brakes a few weeks ago. Busted out the cutting wheel, and grinded away the head of the screw. Are you changing the rotors, or leaving the old ones on?
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by Jmaak View Post
    Plan was to leave the old ones on since they are still pretty good
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    just put it in the river......
    or buy a screw removal tool...
    but I still say it goes in the river, just use a brick for the gas pedal.
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    Why remove it if your not changing rotors?
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Dremel a slot in the head, and screw it out.
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Veteran Member Four Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    Mine did the same... got a drill/bit and drilled the head out... real easy as the metal is very soft.
    22 []S6 Glacier/Arras
    19 []S4 Quantum/Magma
    16 A6 3.0T S-Line/Glacier
    15 []SQ5 Audi Exclusive/Ibis/Magma RIP
    09 []S5 V8 6MT/Ibis/Magma
    06 A4 2.0TQ StgII+ DTM/Moro
    99.5 A4 1.8T StgIII Silver
    DUH! an Audi
    los angeles, CA
    if you changing pads you dont have to remove rotor screw...
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    screw is there for convenience (hold the rotor in place when you're putting the caliper on). The new rotors I just put on my car didn't even have a hole for that screw. I wouldn't worry about it.
    2.0T MTQ | Revo Stage II+ | APR HPFP | 034 Engine Mounts | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | TyrolSport Caliper Bushings | S4 Front Calipers/Carriers/Rotors | Goodrich SS lines | StopTech Street Performance Pads (Porterfield R4 for track) | AWE Vent Boost Gauge | NGK (4644) BKR7E (replaced NGK Iridium BKR7EIX-11)
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    pb blaster (for the rust which im assuming is what made unscrewing it such a pain in the ass) and then what everyone is saying about drilling it out
    the longer pb stays in the easier it will be to get out so give it some pb then wait like 15-30 minutes and try it out then just toss the screw as its not even needed
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    Quote Originally Posted by agkellyboy View Post
    This
    Senior Member Two Rings Grada89's Avatar
    May 04 2009
    B7 A4
    Ft.Lauderdale
    I had zero problems with getting the screw off. No idea why it strips for so many people. Maybe salt on the road up north?
    Veteran Member Three Rings JayStang's Avatar
    Jun 23 2008
    2008 Audi A4 S-Line Ti 2.0T
    Boston, MA
    I actually heard from a dealer the screw is only there to hold the rotor in place on the assembly line. Other then that you can throw it out. Of course you have to get it out first, I vote to dremel a slot as well.
    2008 Audi A4 S-Line/Ti 2.0T Quattro
    2003 Audi A4 1.8T Quattro (crushed by tree)
    Sep 23 2006
    Greenwood, IN
    If you're still having difficulty getting the screw out after making a slot, buy/rent an impact screwdriver. I just did the brakes on a friend's Honda yesterday, and it makes getting the screw out much easier. If you opt to buy an impact screwdriver, Harbor Freight sells a set for $6, but don't use the bits that come with it. They are crap and will twist and break off the tip. I've learned that anything "impact" from Harbor Freight will break. Get a bit from Sears for $2. You can buy an impact screwdriver set from Sears, but they cost $25. Use PB blaster liberally.
    2008 S5
    2016 S7
    Jul 27 2007
    Orange County, NY
    Idk why so many assumed that i'm doing pads. lol I'm going to be doing control arms and i want the rotor out of the way, will make life easier.
