The fuel pressure regulator in the filter, is calibrated to provide the correct fuel pressure with the stock fuel pump. Since you are now running a higher flow rate pump, the regulator can't flow enough bypass fuel to regulate the fuel pressure to 4 bar as before. With the regulator bypass back to the tank, at the 100 percent flow rate, the high flow fuel pump exceeds the capacity of the regulator control range bypass flow rate. Therefore, the fuel pressure will by unsteady and at a higher average pressure and flow rate with the high flow pump, compared to the stock pump.
As you already realize, the higher fuel pressure results in higher fuel flow rate from the injectors, directly effecting air/fuel mixture ratios. Consequently, one way to restore correct fuel pressure while still allowing for higher fuel flow when required, is to install a second adjustable inline fuel pressure regulator that is installed in parallel with the stock in-filter regulator. Adjusting the set point of the second regulator, the combined bypass fuel return flow rate of both regulators will reduce the in-filter regulator bypass return flow to less than 100 percent, restoring correct fuel pressure control.
Edit added:
The second regulator is connected with the inlet port connected to the fuel pump outlet line to the fuel filter inlet port and the regulator outlet port connected to the fuel return line back to the tank used by the in-filter regulator. Alternatively, run a dedicated fuel return line from the second regulator, back to the tank with a through wall fitting installed at the access cover at the fuel pump side of the tank, with the return line extended inside the tank to near the bottom.
A local pressure gauge is not required. Adjust the second regulator until the fuel pressure on the existing gauge shows the specified fuel pressure of 4 Bar, 58 psig.
