Results 1 to 40 of 57
    Mar 04 2011
    Indiana
    Hard to fill gas tank and knocking sound
    I recently purchased a 2005.5 A4 B7. I've been having problems filling it up with gas because it kicks the pump off every gallon or so. I've searched through the forum and found that it may be the charcoal canister or leak detection pump. I think I know how to troubleshoot it but I can't figure out how to get the hoses off to find out which one is the problem. It appears to be a ring that needs to twist or slide but I'm afraid I'm going to break it. Can someone explain how to get both of the hoses off to determine what the problem is? Also can they be cleaned out or do they need to be replaced? If they need replaced, where would be the best place to purchase? I also have a knocking sound that appears to be coming from the same place. It happens after the car is warmed up at idle and for about 20 seconds after I turn the car off. Are these problems related or two separate things that need to be checked out? Sorry for all the questions but I'm new to Audi and need some insight. Thanks.
    Mar 04 2011
    Indiana
    Anyone?
    Established Member Two Rings Sreddington's Avatar
    Apr 11 2010
    Boston
    I have the exact same problem, 05.5 too.... please take a pic or something if you figure it out on what we have to replace. the knocking noise drives me crazy haha and not to mention taking 15 minutes sometimes to get 20 dollars of gas in the car!
    Established Member Two Rings A4B7GA's Avatar
    Apr 20 2007
    A4 B7 5.5, 05 Exploder
    Bal Harbour, FL
    I had this same issue. Not sure if this is correct but basicaly my tech told me that one of my fule pumps had died and the other was working overtime to makeup for it causing some negative pressure in the tank and the knocking sound is the tank returning to its normal size...I thought this was complete BS...but after they replaced my entire fuel tank, two pumps, and the evap canister its all gone.
    Now, I did also have the hard time filling my tank. Before the replaced everything, it happend at every station...now only at one.
    so...thats what I know...oh yeah...I have a 5.5 also
    my mod list...really boring $!ht + APR
    Established Member Two Rings nferguson's Avatar
    Jun 11 2008
    So, Ca
    Mine did that exact same thing So I Just had the canisters replaced under warranty.
    05.5 stock b7 for now
    Veteran Member Four Rings adub's Avatar
    Nov 20 2008
    spiders
    Orange County
    When you go to put the gas in, turn the it upside down.
    ...seriously.
    Oct 06 2009
    WI
    Quote Originally Posted by adub View Post
    ...seriously.
    i have a 05.5 with the same issues. turning it upside down works for me every time!
    Veteran Member Four Rings vbrad26's Avatar
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    haha definitely turning it upside down next time...
    Apr 11 2010
    Boston
    Quote Originally Posted by 00grand00 View Post
    yes turning it upside down works to fuel up. The more annoying part I would say is the clunking at idle sometimes and when the car turns off after a drive. So ultimately fuel pumps need to be replaced?
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    i have the hard to fill up issue...but not this clunking...
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Me, no clunking, but I can't fill the tank. I will pump it upside down next time.
    2021 Audi S4, P34 Intake
    Established Member Three Rings b7kevin's Avatar
    Jan 04 2011
    East Haddam, CT
    wow. sounds like a pita, i would bring it to audi despite the cost to fix that
    2006 A4 Brilliant Black 6MT
    - Revo Stage 2+ - AWE HPFP - ST Coils - K&N - 034 TIP - Newsouth Vent Gauge - Neuspeed Snub - OEM DV Upgrade - E-Code test pipe - AWE Quad tip - s4 rear valance - de-badged - vag'd -
    -Wake up an address the biggest issue of our freedom. National DEBT.
    Nov 20 2008
    spiders
    Orange County
    Well I have owned three cars that have done this. My s4 does it too on occasion. I thinks it's called vapor lock- where air get in the tank and triggers the nozzle to shut off.
    Dec 03 2008
    2018 SQ5
    It also seems to me like gas pumps have become much more sensitive to shut off, not just our cars...
    Nov 20 2008
    spiders
    Orange County
    That too.
    Mar 04 2011
    Indiana
    Just tried filling upside down and it helped some but still kicked the pump off. I can't seem to get the large hose off the canister to check it. From what I understand, the ring slides toward the canister and the hose pulls out. I've pulled with everything I have and can't get the ring to budge. Not sure what I'm doing wrong. Was able to get the small hose off but that didn't help much.
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    I have had the problem filling up for a while and possibly the knocking sound and today the car died on the highway with a quarter tank left and will not restart. Ala got a cel yesterday so hopefully that is related and it is an easy fix. Anybody that had the fuel pumps and canisters replaced have any part numbers? Posing from the aide of the road waiting for a tow truck.
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by chrislane31 View Post
    Fuck that sucks, chris. Not fun any time of the day, much less 5:30 am. Do you think it just stopped supplying fuel?
    Mar 24 2007
    I dont know now. I added a gallon of fuel and it started but still had it towed to a shop and filled it up and it appears to be driving fine. I was not out of gas because the warning light had not come on yet. I got the P0089 and P0456 codes but the 0089 code can be for a ton of stuff. I think I am going to change the fuel filter and just drive it and not let it get below a quarter tank and see what happens.
    Senior Member Two Rings GDC's Avatar
    Nov 18 2010
    Calgary
    I had the same problem car died with about a quarter tank, they shop said it had physically ran out of gas and the fuel gauge was calibrated wrong from the dealership. They recalibrated it for me and it has been fine since. $200 tank of gas... Great...
    b7 audi 2.ot black/black
    go. Stage 2 APR 93, Rev D, Custom CAI, TR18 FMIC with Doublezero30 Piping, 034 hfc, Stasis catback
    show. stasis ss coil (24ftg), 18x9.5 Kup, Cupra Lip, tint, S4 mirror caps
    Mar 24 2007
    Any idea how they recalibrated the fuel tank?
    Apr 20 2007
    Bal Harbour, FL
    So, my warranty expired last week of august and now the problem is back...dropped the car off and now they say they need to replace the fuel tank...again! They were "so kind" to offer to cover the parts but I need to pick up the 1K in labor....good thing I called AOA before I took it in...after the dealership called me, I called my SA with AOA right away and she asked " what would I like"....I responded that I shouldnt have to pay for anything. This car has had consistent problems with the fueling system and just because an arbitrary date passed....Im not even 65K miles...should I have to pay for anything with a consistent issue.
    For those of you who have been having this trouble; I will be mentioning this forum and other 5.5's with the issue...if you want me to add your VIN/name on my next call...PM me.
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    I did not have a knocking sound, but mine was hard to fill. My issue was resolved by replacing the main charcoal canister under the rear of the car. There are a few threads that talk about it and give troubleshooting advice to analyze exactly what is causing your issue.
    Here's a couple links for you:
    http://www.audizine.com/forum/showth...nd-fuel-filter
    http://www.audizine.com/forum/showth...?highlight=LDP - See post 5
    Yes, most of the threads you find will be for a B6. Part #s may be off, but the systems are the same.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Dec 03 2008
    2018 SQ5
    I ended up having the knocking sound also, but only heard it after the car was shut off. Came to deduce that it was the n80 valve failed, and pressure was either expanding or imploding the gas tank. Replaced n80 and no more clanking. Still clicks off during fueling, but not as bad as before.
    JR
    Veteran Member Three Rings J.Owen's Avatar
    Aug 12 2010
    I run -361* of Camber.
    Bucks County, PA
    I have both the knocking and the hard fill on my 05.5. I replaced the n80 valve not too long ago and it seemed to help out, but not cure the issues completely. Once my brothers S4 is off the lift I plan to check out my charcoal canister.
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    dont worry check this carbon canister diy out
    http://www.audizine.com/forum/showth...lem?highlight=
    Apr 20 2007
    Bal Harbour, FL
    Update: My SA from my local Audi Dealership just called and first hit me up for a 10 on the service response...then stated that everything was covered and they are awaiting a complete fuel system (Tank, Pump, Valve...)
    Score!
    Nov 27 2011
    Orange, CA
    I just picked up a used 98 A4, having same problem i look like a kid out of high school trying to fill up gas at the pump, twisting, pushing and turning the nozzle every 20seconds. I will give the upside down trick a try today. From the search it seems the canister could be the culprit ?? I dont have any knocking sound just this hard to fill up gas.. Anyone have suggestion where to pickup the canister ?
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by Coupee36 View Post
    Most people just remove the canister all together. Iirc, the thing is close to 200 bucks. There is a good diy for it in the b6 tech section.
    Sent from my SGH-T959 using Tapatalk
    Nov 27 2011
    Orange, CA
    When you say, most people just remove the canister all together, are you implying driving the car around without the canister?
    Thanks, i followed the links above and found the DIY on removing the canister.
    Feb 19 2007
    Louisiana
    just try cleaning the filter...i tried removing my canister but my car smelt like gas from the outside
    Established Member Two Rings NODO-GT's Avatar
    Jul 30 2010
    Audi A4 B7 2.0T Quattro 6MT
    Tbilisi
    Hi guys,
    Just to make sure, to fix the knocking, i have to replace n80 valve?
    Dec 03 2008
    2018 SQ5
    This is the video of my knocking sound. Happened after the engine was shut off, coming from gas tank area.
    http://www.youtube.com/watch?feature...&v=ozsCOanAG7w
    And yes, if that's the sound, the n80 fixed it for me.
    JR
    Jul 30 2010
    Tbilisi
    close to sound i have, but it's not that intense, there are longer pauses....
    Any side effects if I don't fix it?... cuz i barely can hear it.
    Dec 03 2008
    2018 SQ5
    It might put a little strain on your lpfp. I did notice smoother throttle response after fixing this. Its really easy and cheap, why not give it a shot?
    JR
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Well Ive got this issue...I have been hearing a thudding sound over small bumps/cracks in the road and when trying to fill up today fuel litterally gushed back out the filler neck and i could?hear/see pressure building up. So have we deduced a evap canister issue?? I will be looking into this shortly..
    Sent from my SM-J700T1 using Tapatalk
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Junior Member Two Rings
    Mar 15 2018
    Piedmont, AL
    Sorry to revive an old thread, but I'm confused. I don't have the thud sound, but can't put gas in my 06 A4 Quattro 2.0T. I had this problem with my 01 Jetta. So I bought a used charcoal canister. That fixed it and I could fill up like normal once. I stopped it at the first click. The next time, it's back to the same thing. I checked the N80 valve and it's ok. Am I missing something here?
    Sent from my SM-G930V using Audizine mobile app
    Veteran Member Three Rings B7S3wannabi's Avatar
    Mar 27 2017
    2005 ZCP Competition M3, 2016 Audi S3, 2018 Tesla M3P, 2016 Ducati 959
    Loudoun County, VA
    Quote Originally Posted by Brotherturtle View Post
    Clear the vent tube from the canister to the filler neck. Compressed air through it from canister side to filler neck with gas cap off. Should be good to go.
    2006 Sline A4 Quattro 2.0T - K04R - Sold
    2016 SQ5 Black Optics - Mythos Black - Sold
    2005 BMW ZCP Supercharged M3 in Nardo Gray
    2016 Audi S3 Black Optics - White
    2018 Tesla Model 3 Performance - White
    2019 Ducati 959 - White
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    I had both the hard to fill issue and knocking issue and I replaced all the following parts with new OEM
    -updated hose instead of charcoal filter ($50)
    -new n80 ($80)
    -new fuel filter ($30)
    -new EVAP box ($200)
    Now I only have the knocking issue (much less but still) and have given up on resolving it.....
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Mar 15 2018
    Piedmont, AL
    Quote Originally Posted by B7S3wannabi View Post
    I don't understand what could clog that line. But at this point I guess anything is worth a try.
