Results 1 to 40 of 45
    Feb 25 2009
    Mk2 Jetta, B5 S4, B5 A4
    New England
    DIY Fix for broken Speedometer & VSS Implausible Signal
    I bought an A4 with a non-working speedometer and odometer.
    Scanned the codes and found:
    16885 - Vehicle Speed Sensor: Implausible Signal
    I replaced the sensor, but the speedometer still didn't work.
    I performed an output test on the cluster with VAG-COM and found that all the gauges were working properly... so it wasn't the cluster.
    Here's how I fixed it... I hope this helps anybody who is struggling with this issue in the future.
    This is the part that you need to replace, its a magnetic ring inside of the differential case
    Part # 012-409-182-C
    First, remove the left front wheel.
    Remove the axle.
    Drain the transmission fluid.
    I think these are all pretty self explanatory.
    Next, remove the axle flange. It just pulls straight out of the transmission. The easiest way to do this is with two long bolts with the same thread as the inner cv bolts (8x1.25). Make sure they are threaded their entire length. Thread them into the holes like you would the cv bolts, across from each other and tighten them alternating between the two, this will push against the diff case and pull the flange out evenly.
    Now you'll need to remove the side cover from the diff case. First unplug the VSS, remove it, and push the plug out of the way. Now there are 9 Torx bolts to remove. The one on the far right is the most difficult because of the tranny mount bracket. They are all torqued pretty tight, I had to use a breaker bar on them.
    Here is the cover removed
    As soon as I removed the cover, the shattered pieces of the ring came falling out and my suspicions were confirmed
    A few pieces of the old with the new
    Here is the differential. Notice the last little piece of the ring still clinging on at about the 10 o'clock position
    At this point I took the opportunity to replace the output shaft seal. Simply press out and press in
    Now it's time to install the new ring, it just snaps onto the shaft
    A closer look
    Then it's just a matter of putting it back together in reverse. I added a thin coat of grey RTV (gasket maker) around the edge of the cover to make sure there weren't any leaks
    New axle installed (with new inner CV bolts & new axle bolt), VSS replaced, and hose in the fill hole for new tranny fluid. I used 3 quarts of Mobil 1 75W-90, which was the best thing I could find locally.
    CV grease everywhere... oops
    So my winter beater now has a working speedometer, and as an added bonus the transmission shifts much smoother with the new fluid.
    I hope somebody finds this helpful, because when I was looking for a solution I couldn't find much info on how to fix it.
    Cheers
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    Nice write up and I think I have the exact same problem as I have replaced the tranny speed sensor and the vacuum pump with no effect. Did you purchase the magnetic sensor from your local dealer?
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Feb 25 2009
    New England
    Yup you can get it at a dealer or anyone that sells OEM parts. Chances are they won't have it in stock and will have to order it
    Nov 26 2005
    NM
    Quote Originally Posted by angry12v View Post
    Thanks because my next step was to replace the CC module which is tied into the speed sensor as well and I would much rather do this as it is less expensive. When I changed out my center diff with a STaSIS one I upgraded to RedLine synthetic, and I have enough left over as purchased 2 gallons ......
    Jun 30 2008
    Erie, Pennsylvania
    Very nice writeup. Thank you for taking the time to do it. It is appreciated.
    Registered Member One Ring DJ_Snowman's Avatar
    Mar 23 2011
    97 A4 2.8 Quattro 5speed, 00 Evo VI RS2 2.3stroker w/GT37r 640awhp, 97 Supra Turbo w/T4 GT45r 903whp
    Dallas Texas, USA
    help pleasee!
    great write up really appreciate all the detailed steps! could you give me the exact part code or name to the magnetic ring? im looking to do the same on my 97 a4 with the exact same problem, im a noob to audis just recently bought my first one for a daily driver.. so id appreciate any help you could give me, Thanks!!
    oh by the way, is there any way that this problem could be because a faulty instrument cluster, mine lights up completely! odometer reads out everything works, simply the odometer doesn't go passed the miles it has and the speedo is ALWAYS stuck at zero .. my friend thats a mechanic says he believes its the cluster because he worked on a honda with the same problem and it was the cluster, he specializes in Japanese cars only though so i dont trust his word fully! again thanks for any help man id really appreciate it like i said im a noob to Euros
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Hi, I'm curious how you came to the conclusion that the magnetic ring was the culprit?
    "You know you have a bad idea when Ford guys are making fun of you."
    Mar 23 2011
    Dallas Texas, USA
    Nevermind, i changed my VSS today and that fixed my problem! glad to report i didnt have to buy any more parts! 22 dollars for a new sensor, an hour and a half of labor (that sensor is hard to get to in the position its at, specially with the metal heat guard above it!) and speedo and odometer are back to normal!!
    Nov 26 2005
    NM
    I'm going to replace mine as soon as I get the sensor as I have replaced everything else. I have the same issues, no mph or miles recorded on the trip meter. Also the doors wont lock at 5 mph but I would assume that's because there is not a recorded speed ...........
    Could this effect the cruise control as well?
    Nov 17 2009
    Golf mk3 winter beater
    Laval Quebec
    Just to give a little update , i replaced my magnetic ring about 5 weeks ago because my speedometer wasnt working. The ring was in really good shape everything was looking good but i decided to change it anyways since it was around 35$ CAN.I've put new audi tranny oil and the speedo now works good since then , i did 5000 kilometers and its never stopped working. Thakns for the diy.
    May 08 2011
    uk
    hi,for some resons i could not open them pictures! thanks
    May 17 2011
    2003 Ford Explorer
    Texas
    I can't see the pictures either. Does anyone have a part number for this ring? I can't find one anywhere, and the parts guy at my local VW dealer cant look it up for me since a VW dealer can't "Sell" to audi owners per VW/Audi franchise rules, but if I give him a VW/Audi Part number, he can sell it to me off the P/N. should be the same part on a Passat, though.
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    Aaaarrrgh! I want to see those pics in the worst way. I'm putting a V8 Audi torsen diff in and I'm trying to figure out how that ring is going to fit. Please get those pics back up.
    Feb 25 2009
    New England
    Pics should be back up now, please let me know if you still can't see them
    Mar 27 2010
    solar system
    It's all good, thanks man!
    May 17 2011
    2003 Ford Explorer
    Texas
    Thanks for getting the pics back up! I called my local VW dealer and they can get the part (012409182C) to me for $34US. How much total time did it take you? I'm wondering if I can do it in an evening after work, or if I need to set aside the whole weekend. Thanks!
    Mar 27 2010
    solar system
    As long as you're moderately experienced and don't have a fused pinch bolt I'd say an evening after work. However things can and do go sideways so just make sure you have a backup plan.
    Veteran Member Three Rings JB5's Avatar
    Jul 19 2010
    96 B5 A4- Sold, 06 corollaS (wife's), 97 Ford Ranger, B6 A4 (Daily Driver)
    Snellville, GA
    just need to troubleshoot the issue im having with my speedometer. mine does record the miles driven, sometimes it works and sometimes it stops working. I'm not exactly sure what causes it not to function. will this be something that you think might be related to the magnetic ring? from what i read from different posts, some will not even record the millage run.
    at first i thought that it could have been my speed sensor, however if this fails my car would not even start.
    thanks for your input.
    Jul 19 2010
    Snellville, GA
    can anyone confirm if the Climate Control will detect the RPM if the magnetic ring is broken? this morning my cuslter worked on my way to the tag office. i leave the tag office and its not working. however the climate control does show the RPM.
    thanks.
    Mar 04 2012
    Dublin, IE
    angry12v.. I have just registered on the forum to say thanks.. for both idea and great manual. Your manual just helped to fix A4 driven in Ireland.
    After replacing the ring speedo works again, milage is clocking and fuel gauge behaves better.
    In my case ring did not break apart, but the metal clips, which stops the ring from rotating freely snaped.. I found two of them sticked to the ring itself on the outside.. good thing that the ring is magnetic.. otherwise those metal pieces could be anywhere in the gear box.
    As for the manual there was just one little thing that wasn't mentioned.. one of the 9 torx bolts holding diff cover wasn't accessible without taking off the transmssion bracket (bracket overlap over the bolt). Lifted transmission slightly on the jack to remove tension, removed 4 bolts and the bracket could move enough to uncover the torx bolt.
    I can clearly see on your pictures that bracket is not on the way, but it is in my model.. maybe quattro +avant + right hand side steering wheel makes enough difference.
    Again huge thanks!
    Regards,
    Sergiusz
    Jun 04 2012
    Boston
    How exactly do i test output performance on my cluster? I'm pretty good with a multi-meter, but this is the first time I've heard of a vag-com. I believe my problem is the magnetic ring too, but a mechanic told me that it's my odometer but i have a feeling that's not the case. Please reply. I really appreciate it. Thanks.
    Jul 07 2013
    Melbourne/Australia
    Thank you for your DIY, worked a treat, just got mine working again!!! After changing the VSS to no avail, and checking the cluster with VAG-COM found out it was working, changed out the magnetic ring and voila, it works! Can't thank you enough.
    Feb 25 2009
    New England
    I'm really glad this thread is still helping people over 2 years later!
    I've just run into this issue with the A4 that I currently own and I had to come back to my own thread to remember how I did it!
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    You could have not put any miles on your B5!! I had a similar problem with the speedo not working, and it ended up being the metal sensor that went in the top of the transmission.
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Feb 23 2012
    95 Cutlass Supreme Convertible, 92 Subaru SVX, 1974 BMW 2002, 2000 Volvo XC70
    Erie, PA
    Thanks for this. My original trans had this fail and figured this was the cause after I swapped in the speed sensor from the spare trans. I later swapped it out as I had no reverse as well. Recently, this transmission has had intermittent oddball speedo readings. When I drop it out to do the clutch I'll likely go in there and replace it even if swapping the sensor out takes care of it. Seems that it's fairly common to fail and easier to change with the transmission out anyway. :)
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    A++ Excellent write up! This helped me too!
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    Aug 07 2013
    Wales
    Write up spot on, sorted my A4 for a fraction of the cost. Can't thank you enough! Xx
    Junior Member Two Rings
    Mar 16 2014
    Michigan
    Pretty sure I need to replace mine too. Curious if anyone know if Audi/vw/Porsche are interchangeable. Part numbers are the same. I have found a few on different sites. Porsche one is $10-20 cheaper.
    Using Tapatalk
    Senior Member Three Rings wolfe2118's Avatar
    Apr 09 2012
    Fort Wayne, IN.
    Quote Originally Posted by Trabeate View Post
    I am using the Porsche one now. It is the same.
    Mar 16 2014
    Michigan
    OK that's good. I just finished ordering one. Might take a few days longer than Audi one though.
    Using Tapatalk
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    I just finished up my 5 speed swap and my odometer and speedometer are not working since. I tried another speed sensor I had and nothing. Glad I found this thread! Will be ordering the magnetic ring tonight.
    2021 Q5
    2018 SQ5
    2012 S5
    2003 A4
    2000 S4
    Dec 23 2012
    lots of vw's
    cincinnati
    couple general comments - obviously when speedometer is 0 - several problems could exist.
    1. vss is broke, 2. connector connection is bad to vss, 3. magnetic ring is broke, 4. fuse is blown, 5. cluster is bad.
    Isn't it possible oil is contaminated to the point that vss can't get a good pickup from magnetic ring ???
    If magnetic ring is broke - don't think this would be intermittent problem. cluster is bad - shouldn't be intermittent. fuse is blown - can't be intermittent.
    be nice if a diagnostic flowchart was made to pinpoint the exact problem. I have intermittent speedometer (either on or zero). replaced vss (no help). cleaned old vss and connectors - worked for 10 miles. oil looked fairly dirty when replacing vss. any comments on this problem ? thanks
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Would it be safe to assume that this DIY is the same for an automatic? Is there any way to check the ring without pulling the cover off?
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Apr 09 2015
    NZ
    I just had the speedo & rev counter stop working and also the left hand front indicator. Turns out it was the battery. I had accidentally left the key on and drained it. I was only able to charge it for 8ish hours before using the car. When I got home and charged the battery some more and everything (including the indicator) worked.
    Nov 08 2014
    st albans
    Cant see the pictures to this original post. Can anyone Help?
    May 17 2014
    Raleigh, NC
    I had a similar issue. I swapped to a different ecu and it was reading speed via VagCom (measuring blocks) but it was incorrect.
    Ive bypassed it for now. but the cruise doesnt work and its annoying. Once the trans goes in for rebuild ill replace this part.
    Feb 03 2016
    las vegas, NV
    i am purchasing a 03 audi a4 3.0 quattro on sunday and he told me the only things wrong with it is the speedo does nto working and the check engine light is on .. i alrady had the obd2 scanned and the code came back just for evap. he said all of the rest of the cluster works just not the speedo . after reading all these known issues with the speedo on the a4 im kind of getting worried . would you think it is still agood buy ? he is only wanting 2k for the car and it has160k in almost perfect condition
    Senior Member Two Rings nemick's Avatar
    Aug 22 2012
    Indianapolis, IN
    Still sounds like a decent buy to me
    Neil M.
    2004 allroad 2.7T TIP
    2001 A4 1.8TQ, TIP
    Dec 05 2010
    Brockway/PA
    2003 3 liter 6 sp manual transmission (Sport Package) does not have a VSS on the left side of the front differential.
    May 05 2016
    Johnston IA
    Which fuse may be blown out for the speedometer to stop working? I keep seeing people ask about the fuse. Also your photos are not showing. Could you email them to me?
