Results 1 to 11 of 11
    Veteran Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    B7 RS4
    Québec
    B7 RS4
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    The Conti gets my vote.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    If wet and dry TRACK grip is the focus, either the Direzza Sport or the RE11 get my vote. For daily driving (even "enthusiastically" at times) the Conti DW would be fine and give you a little better durablilty as well. Sport Maxx was a little too noisy for me.
    Oct 06 2006
    South Bend, IN
    the "extreme" category is geared for drivers that want every ounce of dry grip possible, regardless of durability, road noise and (to a small degree) wet grip. The rubber compound is as close to a race compound as is practical, just with a tread pattern. I'd say go for the RE11 or Direzza Sport, and if the durability is not what you like then step down to the Conti DW for the next set.
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    I vote for Continantal DW, I prefer the look and the price.
    I have some Potenza with Race coumpound and they are really heavy and hard!
    Even if my suspension need to be changed, I feel every single cracks in the tarmac. But I guess it's the same with all sport tires.
    When there are cold, they skid a lot even in the hottest part of summer until heated where they stick like mad. I dont find them noisy, well from Pirreli winter tires to summer sport theres a world of difference...
    Overall from the score you mentionned, the Bridgestone are better overall, but 300 buck more.
    Mar 07 2010
    Sherbrooke, Qc
    The 180, 340 & 240 is the thread life, the higher the number, the higher the mileage you can put on those tires.
    A A, or AA A is the traction rating in Dry and Wet
    Max load, the highest number the more load you can put on AND they help figure out how hard they might be (comfort)
    etc
    Continental are the best from the specs
    Jun 01 2008
    Apopka, FL
    I have RE-11's on the G8, they're nice, grip well, have tons of tread after 23k miles(so much that I wonder if they're the original tires), 'work' in the wet, and I haven't noticed much tire roar. comparing them to Eagle GT's on a S4 that's 300lbs lighter and has AWD isn't much of a comparison however. So I couldn't really comment on their ability versus what are essentially mid-range all-seasons.
    Dec 19 2009
    C6 A6 3.0t , 997 Turbo
    tt
    Quote Originally Posted by Mc Suly View Post
    I am leaning towards RE 11 & CONTI DW.
    - Anything I should be looking for specifically for the info below?
    - What PSI should I have to get the full benefits of these tires?
    Bridgestone Potenza RE-11 (Extreme Performance Summer)
    UTQG: 180 A A
    MAX LOAD: 1521 lbs.
    TREAD DEPTH: 9/32"
    TIRE WEIGHT: 27lbs.
    Continental ExtremeContact DW (Max Performance Summer)
    UTQG: 340 AA A
    MAX LOAD: 1356 lbs.
    TREAD DEPTH: 10/32"
    TIRE WEIGHT: 22lbs.
    Dunlop SP Sport Maxx TT (Max Performance Summer)
    UTQG: 240 AA A
    MAX LOAD:1521 lbs.
    TREAD DEPTH: 10/32"
    TIRE WEIGHT: 24lbs.
    If you want a great track tire. Why don't you consider the nitro nt05's or Michelin pilot supersports
    Dec 19 2009
    tt
    If your going to get the nt05's. Get them from discount tire direct. There cheaper and offer free shipping. On top of that they ship stupid fast, comparable to tirerack in shipping time.
    Veteran Member Three Rings Gryphon001's Avatar
    Apr 14 2009
    2018 S5 Sportback, Daytona Gray - 2008 Audi A3, S-Line, Ti, 6MT
    Mississauga, Ontario, Canada
    Been running my Hankook R-S3's on my Stage 2+ fwd A3 for the last two summers. Very happy with those in dry or wet. Will likely get one more summer out of them for a total of somewhere around 30000km before I have to change them out.
    They have great dry grip, especially so when they warm up. The noise I'd not bad at all in them, even 2/3 worn down. Only issue I had was my set was a real b!tch to balance (needed road force balance) and the take a long time to warm up if the temperature drops below 15 degrees Celsius.
    If you want simmilar grip in winters ( didn't look where OP is so not sure he has winter) I found the Michelin Primacy Alpin to be an excellent choice.
    Established Member Two Rings SlowBone's Avatar
    Oct 30 2012
    Chicago
    Hands down the Dunlop Starspec. they are coming out with the starspec 2 soon also. Best grip in dry or rain, and the longest lasting summer tire also. Ill never buy another summer/performance tire.
