I'm having similar issues.
I purchased an FX400 with the steel single mass flywheel, the 240mm setup, off a member here on Audizine.
Had it installed. First day, the clutch seemed to grab IMMEDIATELY, then the noise started. A chattering, and at times almost a grinding noise.
A detailed description:
Chattering in idle, louder as the car warms up, very loud with the AC on.
When in gear, grinding almost, horrible. People get into my car and wonder if that's what an Audi should sound like. I feel embarrassed. My mechanic told me to give it a couple of miles, similar to what I had read on the forums here: give it a couple thousand miles. Noise goes away when the clutch pedal is pressed.
I do have some of that stuttering in first gear as described above but nothing major. Just give it a bit more gas and that's it.
That was June last year. I told the mechanic at the time and he said that was the nature of the switch from the stock dual mass flywheel to the single mass flywheel, and to just turn the radio up. I kinda figured it would pass after a while based on what other users in the forum are saying. Fast forward to today: no improvements, if anything the clutch is noisier. Car gets hot, noise gets worse. AC on, noise worse. When in gear, going third or fourth or fifth, at about 3.5k to 4.5k rpm, sick grinding sounds. Clutch grabs decent. Nothing to write home about or too different from the stock clutch setup.
Sent an email to both the seller of the clutch and my mechanic. Both really cool people but I guess I'm in the situation described above by Old Guy, each party refers me to the other:
I am going to assume that you purchased the clutch yourself and took it to a shop for installation so unfortunately that puts you in a precarious position. The installer is going to point the finger at the hardware and the clutch supplier may blame it on the installation.
I would have a conversation with both parties to make them aware of the situation and see what you can work out.
Mechanic: Met with him, really cool guy, drove around. He said he speculated the noise was coming from the clutch release bearing/pressure plate. And to keep talking to the guy who sold me the clutch (I already sent the seller an email and clutchmasters as well). Mechanic literally said: Talk with clutchmasters...I don't think it says anything on their website that a chatter noise is normal... He also said that the installation went fine when asked about the stuff below (what the seller said).
Seller says: Has your mechanic taken a look and pulled the tranny? In very rare cases the fork may have bent or the TO bearing may have failed especially is it was not clipped into the fork, but even then sometimes it happens.
I'm so tired of the noise I cannot take it anymore.
I don't know what to do. CM has not replied. Can anyone offer any advice. I poured like $2000 or so fixing the car last year, the last thing I expected was to have to be dealing with this again. In fact, I was never really happy/satisfied with it (as it was making noises from day one) and I think I've waited long enough for the noise to go away (about an oil change worth of miles).
Thanks,
Dan
