Results 1 to 19 of 19
    Sep 15 2010
    Baltimore
    Bosch Icon wiper blades size
    I'd like to get replacement Bosch Icon blades as it seems those as the best. (Are they the best?) Which size should I purchase? ECS Tuning has a set, 421A for the driver 421B for the passenger, (link) . Is that 21inch set-up the best? What do you guys have? I think the Bosch website says 2x 421A but I'm not sure that's accurate.
    Oct 15 2010
    Fairlawn, OH
    I have the 21" ones and they work fine. Cant you find them any cheaper than that near you at a store? Those will be $50-60 after shipping knowing ECS's shipping prices
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    The Bosch Icon blades are buy one get one free at my local Oreilly's. Check there if you have a store near you.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Aug 13 2008
    Indiana
    Whats the difference between the Icon and their Evolution? I have the 2nd one and it looks exactly the same.
    -Nic
    Veteran Member Four Rings revolution337's Avatar
    Apr 03 2009
    4.2 A4, 82 Vanagon, Mk7 Sportwagen
    Pennsylvania
    I just used 421A for both passenger and driver side and it works fine.
    Life is too short to drive ugly cars.
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by somebody5788 View Post
    I was wondering this as well. I use the Icons. Michelins or Rain-X are probably better, but the Icons look the best visually as they cover the hookup mechanism.
    Aug 13 2008
    Indiana
    That's the thing, so do mine? I feel like Bosch is selling the Evolutions as Icons and charging a little more lmao
    -Nic
    Jun 30 2008
    Erie, Pennsylvania
    Did some searching. Both Evolution and Icon are bracketless and look similar, but Evolution is the slightly cheaper variant. The ICON has these additional features:
    - FX dual rubber wiping edge (vs. natural rubber on the Evo) for better strength and longer life
    - 2 Different tension variants to fit the windshield better and decrease streaking
    Aug 13 2008
    Indiana
    So basically still it's the same thing they just say it's better lmao. Because the edge design is similar/ the same and the wiper shape is as well. Just sounds like the Icon is supposed to be more even then the evolution and supposedly better edge but that part's debatable as I've usually had better experience with good ol' rubber
    -Nic
    Apr 25 2007
    millersville, maryland
    I like the Icons, 21" is right. They last a long time and for $30 last time you can't beat it. Just get wipers when they run deals.
    Nov 30 2008
    06 Wrx
    Olympia, WA
    I've actually been running some of the rain-x's that look just like the icons, no bad streaking yet.
    The one thing that i like better, and this could just be chance, is that since i have a chip in my windshield, there will always be a streak there. Or so i thought. 2 pairs of the icons streaked form the chip, but noothing from the rain-x's yet...
    Veteran Member Three Rings rAphb0y's Avatar
    Jun 21 2008
    Boston
    Bosch ICON size 21" for both sides (driver&passanger) got mine for $30 iirc buy one get one 1/2 off, they are awesome in both rain/snow
    Jun 30 2008
    Erie, Pennsylvania
    I believe I've been using 21" ICONS for both sides with the "A" tension. I notice a problem where there doesn't seem to enough tension on the outside half the driver's blade (the 10.5" from the center toward the end tip). This problem shows up in heavier rain, when lots of water is pushed into that particular area from the passenger blade. The water piles up and the driver's blade is helpless move it all (on top of the water it is already pushing from the driver's half of the windshield. This leads to a section that is not adequately wiped (ahem...). I was thinking about trying the "B" blade, but it sounds like that is usually spec'ed for the passenger side, as that side has to deal with for curvature.
    I suppose maybe I'll just try the Evo's if I can find them. I've also heard about the new Michelin "Stealth" wiper blades, which are supposed to be pretty good. Anybody try those yet?
    Jan 21 2008
    Tucson
    FYI, Bosch Icon at Autozone, buy one, get one free
    Jun 30 2008
    Erie, Pennsylvania
    I got some Rain-X Latitude blades for this winter. Seem pretty good so far, but quite as pretty as the ICON's.
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    I upgraded to the Aero set from the stealership. The same set as the one on ECS. I'm on the same set of blades for the last 2 years. I can't express how impressed I am with the OEM Audi wiper blades. They are still wiping very cleanly. Love the low profile of the wiperarm and blade. It tucks nicely below the hood and windshield when viewed from inside and doesn't stick up. I would recommend this upgrade for anyone in a rainy environment like the PNW. Well worth it as a Christmas gift to my car a couple years ago.
    Doug
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Oct 30 2009
    Miami, FL
    Quote Originally Posted by Cybersombosis View Post
    For all you junkyard hunters, these are the OEM blades and arms from the B5.5 Passat. I'm definitely going this direction once I find a pair.
    2018 S5 Coupe - stock for now
    Veteran Member Three Rings Scientist's Avatar
    Sep 08 2011
    2001.5 A4 Avant
    Troy, NY
    Quote Originally Posted by mysman View Post
    Correction: Buy one, get the second at 50% off. I stopped yesterday.
    The car ahead exist for only one reason. It's there to be passed.
    Have an OEM cat conv and catback (including the downpipe) with 75K miles on them. Free. Pick up only.
    Sep 08 2011
    2001.5 A4 Avant
    Troy, NY
    That's what I buy twice a year. $9.49 at Walmart.
