Results 1 to 40 of 45
    Established Member Two Rings JohnnyTooBad's Avatar
    Aug 14 2009
    NoVA
    Want to add HP to a stock B7 A4 2.0T
    Unfortunately, I don't seem to be able to do a search, so even though this has probably been asked 1000 times, I guess I'll ask it again.
    I have an '06 2.0T Avant, bone stock (6 sp automatic tranny ). What's the best way to add about 75-100 hp, and how much would it cost. And even though I would like to think I can, I probably *shouldn't* try to do it myself. Mainly because I have a bunch of small kids and not enough time and definitely not the expertise to do it quickly enough. So I'll have to pay for labor.
    Or am I SOL because I don't have a manual?
    (DEAD) 2006 B7 A4 Avant 2.0T. Blue/Tan, Auto. 100% Stock, except for some window tint
    Replaced with a unicorn.... 2011 A6 Avant 3.0T, also Blue/Tan. Premium Plus, S-Line, Cold Weather Package.
    Veteran Member Three Rings brucebanner's Avatar
    Sep 09 2009
    Bellingham, WA
    Ecu flash, hfc or test pipe and hpfp should do it
    Sent from my PC36100 using Tapatalk
    2011 Daytona Gray Audi Q7 S-Line Prestige
    RIP
    2010 Phantom Black Pearl S4
    Jan 06 2008
    Dacia Sandero
    Arizona
    Flash w/ APR, GIAC, ReVO; High Flow Cat; exhaust.... /thread
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by brucebanner View Post
    Not sure if that will be enough to get upwards of 100 extra on top.
    I think turbo replacement will have to come into play to get the higher estimate. Today I dynoed in at about 255 crank and 203 to the wheels on a tiptronic.
    What i have
    REVO Stage 2
    • 3” Custom Testpipe and downpipe
    • 3” AWE Dual Tip Exhaust (from mid-pipe back)
    • OEM Diverter Valve
    • Carbonio Intake
    • Tank up using BP @ 93
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Senior Member Three Rings SoFarGon's Avatar
    Jun 01 2010
    North East
    I have similar mods... I'd be upset with those numbers, seem kinda low
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by SoFarGon View Post
    It's hp to the wheels so its not THAT bad, but 250 to the wheels would be better instead of 203
    Jun 01 2010
    North East
    Quote Originally Posted by Coderedpl View Post
    Word up! I think it's all about tq anyway... I'm sure yours picks up pretty quick. Mine is nice off the line... But in the long run a lot of cars would catch us... 1/4 mile... We have the advantage
    Jul 27 2007
    Orange County, NY
    It's definitely not weak, still puts a smile on my face everytime i step on it.
    May 20 2010
    I got APR ECU upgrade done last year at New German Performance in Lorton when APR was having their sale. 4 programs, security, etc. for $650+ tax, incl install. But there shouldn't be a reason you can't search--searching's been my saving grace and I can't count the number of times it's prevented me from asking dumb questions
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    ur not sol but having an auto tranny and adding lots of hp (100 is a good amount) seems kinda backwards.....only because ur adding all that performance but the transmission is going to hold you back, not in a strait line but def if you were to auto cross it and stuff ya kno
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Aug 14 2009
    NoVA
    Thanks for the input! Good stuff. So you guys aren't having to replace any engine internals, such as valve springs, etc? Good to know I can do this with a auto tranny. I had to get the auto because the wife can't/won't drive a manual and needs to be able to drive it. It drives me nuts. I put it in manual mode 100% of the time.
    So what did you guys spend on these mods (total) to get your wheel hp up to around 250-275? And did you pay for labor or DIY? I could also go backwards here and ask, what kind of HP can I get for $1500?
    I'm not looking to do any sort of autoX or anything like that. I just want more power out of it. Shoulda got a 3.2! I'd really like to swap out 1st gear in the automatic, for something longer if I up the hp, but I have no idea if that's even a possibility.
    Jul 08 2010
    tucson
    danbury
    if 1500 is what you have and want to max out your performance
    - chip
    - test pipe
    - down pipe
    - cheap fmic
    -k&n air filter
    chip is around 500, test pipe is anywhere from 50-200, down pipe is around 150 if you get it made for you at a shop or something cheap fmic is gonna be around 300-400
    things to not waste your money on
    carbonio intake
    forge dv
    any intake whatso ever
    any downpipe back exhaust (example, greddy g2s)....why? because most of the hp that you recover from doing an exhaust comes from the stock cat and oem down pipe therefore since your budget is tight it would be for sound purposes mainly
    labor? the chip most shops dont charge labor on, test pipe your looking at 1 hour, downpipe your looking at 1 hour (prolly 1.5 hours if done together) fmic is about 3-4 hours k&n airfilter should be done by yourself....so could the fmic but just so you have an idea all these parts are known as bolt-on parts and you might be hitting around 250 whp if you have a good dyno run
    the b7 a4 is expensive to make quick and 1500 is not too much to play with....my thoughts? just get a chip and see how you like it, dollar per hp it is the best value for our cars...
    [CENTER]Scott
    2011 S4
    Senior Member Two Rings Grada89's Avatar
    May 04 2009
    B7 A4
    Ft.Lauderdale
    Buy some sick stickers. 10 hp per sticker
    Registered User Three Rings Will@R.A.I.'s Avatar
    Jan 01 2011
    Annapolis MD
    here's my input
    Unitronic tuning
    RAI downpipe (you can even stay with the stock exhaust)
    KMD or similar high pressure fuel pump
    Snow Water/Meth (which we are about to run a killer deal on)
    these should net you some pretty serious gains. I'd be surprised if you didnt make 210+ wheel. The downpipe you could probably do yourself, but I see your in Nova, If you feel like making the trip we could get all these squared away for you. I bet we could even throw in a free dyno too.
    Jul 27 2007
    Orange County, NY
    ^ I wish you guys would say...."Get our turbo kit"
    Jan 01 2011
    Annapolis MD
    in due time!
    Veteran Member Four Rings GarrettReid's Avatar
    Oct 26 2010
    Orlando
    Quote Originally Posted by [email protected]. View Post
    in due time!
    Now think of mods for my cvt
    2014 Audi SQ5 Black w/Lava Gray and Magma Red
    SOLD: 2007 Land Rover Range Rover Sport Supercharged Black w/Black
    IG: GarrettReid
    Established Member Two Rings Creepin's Avatar
    Jan 08 2011
    Beaverton OR
    I just did a Unitronic's 1+ chip Friday... LOVE it! Seriously it is awesome! I'd start there... Only 600.
    B7 A4 2.0T/Black on black/Unitronic 1+/Forge Spacer/APR Snub mount/LED 6000k HID prjectors/6000k HID fogs/LED interior/H&R springs/K&N drop in/20% tint and tails/Podi boost gage and front skid plate/Yakima roof rack...
    Senior Member Three Rings WasGTIguy's Avatar
    Jun 09 2009
    Orangeville, Ont
    What i have
    REVO Stage 2
    • Carbonio Intake
    Wow, I expected more from the supporting mods. That's still less than a stock 3.2. They dyno around 224 that I've seen
    http://www.rri.se/popup/performanceg...h&ChartsID=732
    2003 Jetta GLS TDI (upsoluted) Eibach Longbeach Phatbox SOLD
    2007 GTI (DSG ftw) APR goes weee SOLD
    2007 A4 Avant Quattro 3.2 S-Line Titanium 6MT
    Check out my 3000km roatrip
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Well for about 7k you can get 400hp to the wheels....
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by WasGTIguy View Post
    I got a feeling my flex-pipe leak or something else comes out to be the issue here.
    Account Terminated Four Rings
    Oct 18 2008
    Delray Beach, FL
    3.2 Liter - claims 255 horsepower and 243lb-ft torque. 224 whp means that there's only a 12 % drivetrain loss. I also just saw another guy post that he dyno'd at 213 wtq (another 12% drivetrain loss example). That seems to be a very low amount of drivetrain loss.
    def love the sound of my 3.2 (manual) ~ I put down 213awtq and most of it is there from the low 2k rpm range... takes off quite quick. also pulled on a stock 06 G35 coupe which surprised me a bit
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by GarrettReid View Post
    easy, 6spd swap....
    [CENTER]Scott
    2011 S4
    Jun 09 2009
    Orangeville, Ont
    Quote Originally Posted by greensto View Post
    That almost makes me think that Audi was conservative with the 3.2's output as well as the 2.0T. I think the crank output of the 3.2 is more than 255hp.
    Jan 01 2011
    Annapolis MD
    drivetrain loss on quattro is around 20-22%, more if you factor in the automatic transmission. also you have to look at the type of dyno used ie. Mustang vs dynojet. They both function differently so the numbers they get shouldnt be directly compared. Coderedpl's numbers sound about right to me.
    Veteran Member Three Rings jayphil82's Avatar
    Apr 05 2008
    Quebec, Canada
    I believe that a Stage 2+ car with IC, Water/Meth and 100 oct tune can have around 300 CHP. Of course with an auto tranny you will loose a lot of hp to the wheels but you should be close do 210-220 whp.
    So you need:
    HFC/test pipe with downpipe (034 + downpipe or RAI complete downpipe)
    HPFP (APR, KMD ...)
    Stage 2+ tune for water/meth or 100 oct file
    Water/Meth kit
    Intercooler
    2006 DG Audi B7 A4 2.0T 6spd
    • Performance: APR Stg2+ 93oct using 94oct gas / AFE Dry Filter/ 034 HFC/ APR HPFP/ Treadstone TR6 IC / OBX Cat-Back
    • Handling & Braking: Stasis SS Coilover / RS4 Sway / Carbotech Bobcat Pads
    • Look: Drop / 19" VMR V713 / OEM S4 mirror / DDM 6000k bi-xenon
    • Other: Evolution skid plate/ Ross Tech VAGCOM/ Snub Mount
    Established Member Two Rings RightonRed's Avatar
    Aug 14 2008
    Nothern Virginia
    Quattro/Tips are losing ~28% to the wheels on a Mustang from my experience. Had mine run multiple times in it's stock configuration on the same dyno (RAIs) and it showed 28% from wheels (157hp) to crank (201hp). Would recommend at least a visit up to RAI just to see what they have to offer, they are solid people.
    Btw: Check out RAI's DP with the HFC, well worth the investment in my opinion.
    Red
    Tango Red 2018 RS3 - Tech, Dynamic, RS, Driver Assistance, Black Optics
    Brilliant Red 2008 A4 2.0TQ Tip S-line KOR Turbo (sold)
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I dynoed right in the same area. Stage 2, full exhaust, stock ICs, and I was right about 210 HP at the wheels, and about 255 Tq to the wheels. The torque is what makes our cars feel so much faster. If you did a stage 2+ tune, FMIC, exhaust, meth, HPFP, then you might be hitting 250 HP at the wheels. Maybe. But you sure as hell aren't getting there for $1500. Double that price and you'd be close if you installed everything yourself.
    2021 Audi S4, P34 Intake
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    BASIC PERFORMANCE UPGRADES (BPU):
    Software upgrade (REVO, APR, GIAC, UNITRONICS, etc) $500-800
    Exhaust upgrade (AWE, APR, Milltek, Stasis, etc) $800-1300
    Test pipe or high flow catalyst (RAI, 034, Eurocode, VMR, etc) $80-400
    Upgraded intercooler system (AWE, RaceTec, ER, ATP, etc) $700-1200
    High pressure fuel pump (KMD, APR, Autotech, etc) $300-1100
    You're looking around $2400 at minimum plus installation if you're not a DIY type of person. Most of your options/questions for performance upgrades and beyond, can also be found in the New Member Guide sticky: http://www.audizine.com/forum/showth...2-*READ-FIRST*
    B8.5 Audi SQ5 | APR Stage 1
    Apr 05 2008
    Quebec, Canada
    Quote Originally Posted by RightonRed View Post
    Red
    If my math are correct:
    157whp vs 201chp = 22% drivetrain lost (201-157)/201
    157whp if we apply 28% you would need to do 157 / 0.72 would mean 218chp
    Apr 05 2008
    Quebec, Canada
    If you are at Stage 2 with full exhaust and you dyno is at 210 whp (which sound a little high, what kind of dyno was it?)
    Adding the HPFP give just about 8 peak whp
    Typical IC gain is around 7% peak
    Meth probably add only around 8 peak whp with already a good IC
    That would give around 240whp or 308chp considering 22% drivetrain loss. That sound pretty good an probably the maximum a K03 can achieve.
    Jul 27 2007
    Orange County, NY
    On a mustang dyno i don't think my numbers would drop MUCH lower, would they? Would seem kind of silly
    Registered Member One Ring A4ourbullit's Avatar
    Nov 09 2011
    chicago
    Quote Originally Posted by Creepin View Post
    was this the first mod done from your stock b7?
    Veteran Member Four Rings Ed Gein's Avatar
    Sep 21 2011
    '10 GTI, '08 Scion tC, '01 CBR 600
    Maine
    Quote Originally Posted by mr shickadance View Post
    - chip
    - test pipe
    - down pipe
    - cheap fmic
    -k&n air filter
    carbonio intake
    forge dv
    Well said sir, I would however add that you should definatley upgrade your diverter valve if you get it chipped. The oem diaphram units are almost guaranteed to blow under the higher boost levels. The revised piston one will do the job, you dont need a fancy forge one like mr shickadance said.
    Senior Member Three Rings audisline08's Avatar
    Jul 20 2011
    Alabama/Ft. Benning, GA
    X2^^
    Jan 27 2007
    NC
    Quote Originally Posted by Ed Gein View Post
    I'm pretty sure Shickymean t if you already had the D revision DV.
    vizi
    Jul 08 2010
    tucson
    danbury
    whats a DV?
    [CENTER]Scott
    2011 S4
    Senior Member Three Rings blazeblunts4's Avatar
    Jan 29 2011
    Cali
    - chip
    - test pipe
    - down pipe
    - cheap fmic
    -k&n air filter
    carbonio intake
    forge dv
    dot
    2014 S4
    Sep 21 2011
    Maine
    Quote Originally Posted by viziers View Post
    vizi
    maybe, but surprisingly no one had mentioned upgrading the dv
    Senior Member Two Rings Ais4Slow's Avatar
    Nov 17 2010
    UPLAND
    Invest said $1500 on the down payment for a different car.
    Oettinger. APR. Stasis. 034. ST.
