I had been having a series of ignition coils burn out on me over the last 2 months coupled with misfire codes on my third cylinder. I was about to buy the Hitachi upgraded coils from ECS when I stumbled across a recommendation in the Canadian Regional forum recommending that I check out a local vendor. With the coils still in the online shopping cart I went into my garage to install my last spare and for the first time took a glance at the Ignition Coil Connectors and found that my wires were badly cracked. Naturally being an idiot, I wiggled the wires around while the car was running and sure enough, the car farted a few times and eventually stalled out completely. Wires it is…
Happy to say that THIS sorted me out…for anyone searching for a fix to their misfire woes, don’t forget to check your wires and connectors to see if they need replacing…this solved my issues. The Audi dealership was charging $18 for each connector itself and $10-12 PER WIRE…Fawk!!!
After reading the writeup on the connectors, I should have figured this out a whole lot sooner (Product description included to help future search button whores).
“Ignition Coil Harness/Connector Repair Kit: Kit Contains: 4) High Temprrature Leads and Terminal - Pre-Assembled in an OE Type Connector. 4) Heat Shrink Butt Connectors. 1) Terminal Extractor Tool.
Failed or Burned Up VW/Audi Coils are Most Commonly Caused By Poor Electrical Connections, Wire Harness Breaks or Fouled Spark Plugs.New Connectors Should be Replaced When replacing Ignition Coils, Especially If There Has Been More Than One Coil Failure. A Loose Connection (Caused by Engine Vibration, a Cracked Connector Housing, Cracked or Broken Wire Insulation) Can Cause a Voltage Spike Which May Not Only Destroy or Burn Up the Ignition Coil, But Also the Neighboring Coil Because the Harness Wires are Bridged Together. The OE Connectors Are Not Designed to be Repeatedly Unplugged and Re-Plugged. VAG Recommends Replacing the Connectors if There is a Chance of a Loose Connection.
Product Notes: Repair Kit Ignition Coil Harness/Connector Repair Kit: Failed or Burned Up VW/Audi Coils are Most Commonly Caused By Poor Electrical Connections, Wire Harness Breaks or Fouled Spark Plugs.”
