Results 1 to 19 of 19
    Sep 12 2008
    South Central PA
    Head Gasket 1.8T w/ pics
    Have you just found out that your headgasket is leaking/blown? well damn. that sucks man, trust me. I know.
    Well, theres a few options.
    -1. Assume the position and take your car to the dealer and have them put the royal shaft in your bum for labor/parts.
    -2. Take it to a indy shop and still pay $$$ and hope they don't mess anything up, seeing how it is one of them fancy Geerrr-man tuurbo'ed charged cars.
    -3. Get some of that head gasket fixer stuff that you put in your coolant from AutoZone and see how that works out.
    -4. Nut up and do it yourself. Show all your friends and everyone at the office how amazing your wrenchin' skills are, and brag about how much moolah you saved by doing it yourself.
    First off, you're going to need all the basic tools in a "Mechanic's Tool Set", kinda like this:
    - a pair of pliers:
    - set of torque bits:
    - some allen bits:
    - torque wrench:
    - and headbolt tool. If you have OEM headbolts. you'll need this tool:
    - If you have ARP headbolts, you'll need this tool
    You can get both of those tools from here: CLICKY
    I am assuming you know how to do most of this stuff, since you are attempting to replace your HG. So I'll keep it short as possible.
    ****I am not responsible for any damage that you cause to your car or yourself, by following this DIY****
    Well here it is. Ready for you to rip her apart, savagely.
    Take out the headlights.
    Remove the bumper cover and rebar
    Remove FMIC and piping, Drain coolant. (I don't wanna hear it about the green coolant.)
    Put the lock carrier into the service position, remove the serpentine belt tensioner and timing belt covers.
    Remove timing belt hydraulic tensioner and timing belt.
    Remove fuel injectors, and unplug the cam position sensor, and VVT solenoid. remove coil packs and take out the spark plugs. remove coolant line to the hardpipe, move coolant tank. remove PCV stuff. Also remove the coolant flange.
    Remove lines to the turbo, pull the intake manifold back out of the way. Might as well disconnect the cat/downpipe/testpipe/whatever from the turbo.
    Take off the valve cover and remove the plastic caps covering the intake cam.
    This is the tool I am using since I am running ARP headbolts as of now.
    Now, time to take out the headbolts. I always take them out in the order that you're supposed to tighten them. Not sure if its actually necessary, but I do it.
    Now, after you take all the headbolts out, put the VC back on and put a nut on the middle stud, just keep it in place. get a good hold on the head and lift up, make sure you have something to put the head down on.
    Now since you took it all apart, you should be able to put it back together. Obviously its just reverse order. Make sure that you clean both the block and head surfaces very well before you reassemble it.
    Anymore, it only takes me around 2.5 hours to change a headgasket in a 1.8t. This took me around 2 hours just to tear down, since I decided that I would do a write up. and it was really nice out today, so I took my time. Make sure you give yourself a couple days to complete this, just to take your time and not make any costly mistakes, like not having the engine back in time, stuff like that.
    HAVE FUN!!! and feel good about all the cheddah that you saved yourself.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Established Member Two Rings zanadu's Avatar
    Jun 08 2009
    San Jose, CA
    So what sort of headgasket issue were you having? From the pic it looks like piston two is much cleaner than the others, was coolant leaking into that combustion chamber?
    Sep 12 2008
    South Central PA
    it actually wasn't the headgasket. my head had cracked in the number two runner before the valves, leaking coolant into the chamber. so that was giving me the symptoms of a blown headgasket.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Nov 03 2007
    2003 B6 A4, 1988 Bronco II
    NH
    Looks like you have an AMB head. Mine too is cracked on cylinder #2, inbetween valves. I have read a few more threads with people complaining of cracked heads, and it seems to be limited to the AMB. Whoever reads this DIY, be aware of this and get your head pressure tested to make sure it is good before putting it back on.
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    I don't have my Bentley manual installed right now, just moved can't find my cd now :(, what's the torque spec for the stock bolts? I read something 45 + 1/2 turn, is that right?
    2010 VW GTI
    Previous cars:
    2003 A4 1.8T APR Stage 1+
    Sep 12 2008
    South Central PA
    that sounds right, but I can't remember off the top of my head. I have the sheet in my garage, I can double check.
    There should be a torque sheet that came with your headgasket
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Aug 14 2007
    Ottawa, ON, CA
    Oh with the gasket, don't have that yet :) If you don't know it off the top of your head don't worry about, I was just gathering info on the project and figured I'd ask. I'll have my Bentley when it comes time to do the job.
    Is there anything you can suggest that should be replaced at the same time? I'm getting all the gaskets, header, turbo to cat etc, new coolant and oil line washers, maybe just a new turbo mounting kit form ECS which has the turbo bolts plus all gaskets and washers etc. But if there's anything else you know from experience I'd appreciate it. I'm also doing my second timing belt job at the same time and since my 2 year old southbend clutch is slipping, no launches or hard driving just dd, I need to probably take the opportunity to rip it apart and see WTF is going on. I'm hoping it's just coolant leaking onto it as I suspect but I'll know only when I open it up.
    2010 VW GTI
    Previous cars:
    May 05 2010
    B6 A4 1.8T
    Los Angeles, CA, 90059
    worrrrd..i felt so good after rebuilding my engine on my own..very rewarding and saves you like $28551945357.50 (:
    B6 A4 1.8T>>boosted tech CAI::Forge splitter::Rebuilt engine head & block::Victor Reinz steel gaskets & head bolts::SS tubular exhaust mani::TT225 injectors::VMR straight pipe::VMR vent boost gauge::custom FMIC::DNA OCT::custom exhaust::tein SS coilovers::B5S4 brake upgrade::drilled/slotted rotors::19" BBS RS GT's::black halos W/4300K Xentecs::6K fogs::limo tint::debadged::blacked out grill::roof spoiler::lid spoiler::Apexi TT&companion
    ...More to come sooon(:
    Dec 03 2009
    1991 RX-7
    Seattle/WA/USA
    That's what I was going to ask as well.
    What parts do you need to replace (obviously the head gasket itself)
    What parts do you recommend replacing?
    ohm mani padme hum
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    nice writeup!
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    How do you make sure everything is back correct regarding the timing and the cams and all the rotating parts?
    This looks doable for a guy like me if I ever need to do it, but obviously everything has to be properly placed back in its correct position.
    Do you mark with paint pens?
    Whats the procedure here?
    Sep 12 2008
    South Central PA
    Sorry, I never thought of bothering with explaining that.
    The easiest thing to do would be to put the engine at TDC before you take everything apart. Then it'll be easy to line everything up when you're re-installing everything.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Veteran Member Three Rings vjborelli's Avatar
    Apr 18 2012
    Boston, MA
    Quote Originally Posted by B72011 View Post
    There are timing marks on the cams to match up to the head. Also make sure each timing mark on the the cams are exactly 16 links apart on the chain.
    Then you will want to set your cams at TDC by matching the mark on the gear, to the mark on the head. Then go ahead and line up the timing mark on your crank pulley to the mark on your lower timing cover, setting it to TDC as well.
    You are now ready to bolt the head back up to the block, and set your timing.
    Veteran Member Three Rings b6a41.8tbagg's Avatar
    Oct 07 2010
    Nashville
    Great write up,what fmic are you running
    Jan 09 2012
    florida
    Don't you just love inline 4's? There's nothing easier to work on.
    Jun 15 2011
    Exiled.......
    Roughly how much in parts to do a headgasket job? Assume a $60 head gasket + "X" in parts. How much is machining on the head--assuming just a slight warp?
    If I tackle this--I'll do the timing belt, but just interested in the HG job number$?
    Veteran Member Four Rings victimdumper's Avatar
    Dec 20 2011
    Boston / South Shore
    ^I paid about $150 to have my head machined and jet washed. (....that's what he said?)
    but other have found cheaper prices, this was just a local place 2 minutes from my house and he started it right when i handed it to him.
    I also just bought one of the gasket sets which included just about everything for around $80 ish I think, and new head bolts was another $25 or something like that.
    then there's everything else I replaced while it was off that added up
    2005.5 B7 A4 Avant
    Sep 12 2008
    South Central PA
    Quote Originally Posted by b6a41.8tbagg View Post
    Thanks. Its a treadstone TR10E with custom piping.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Apr 07 2011
    Quote Originally Posted by Casius View Post
    Just wanted to add to this write up.
    As Dan mentioned, he removes the head bolts in the opposite order in which they are supposed to be installed and that is the correct way to do it.
    This picture shows the head bolt removal sequence.
    The head bolts should be torqued in three stages.
    I – Tighten with torque wrench to 40 Nm.
    II – Turn 90° (1/4 turn) further using a rigid wrench.
    III – Turn 90° (1/4 turn) further using a rigid wrench.
    This picture shows the head bolt install sequence.
