Results 1 to 40 of 64
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Thumbs up :: EuropaParts.com :: The Essential B8/B8.5 S4 Maintenance & Upgrade Guide
    Ultimate Service Kit (S4/S5 B8 3.0T)
    Order everything to perform the ultimate service on your Audi S4/S5 B8 3.0T:
    • Engine Oil: Your choice of engine oil brand. All our selections will work great in your engine but feel free to select your favorite brand.
    • Oil Filter: OEM oil filter.
    • Drain Plug: Your choice of the regular or magnetic oil drain plug. Magnetic plug attracts and holds metal particles preventing their circulation through the lubrication system which, in turn, prevents excessive wear to the engine's components.
    • Dipstick: Many new Audi models come with no dipstick and just a plug. Measure your oil level the correct way!
    • Oil Change Additives: Professional chemicals you can use to clean and de-gunk the engine during the oil change.
    • Air Filter: OEM Mann air filter or K&N high-flow, performance filter.
    • Cabin Filter: Charcoal cabin filter filters out smells in addition to soot, dirt, pollen, and other pollutants.
    • Fuel Filter: OEM fuel filter.
    • Spark Plugs: OEM spark plugs.
    • Wiper Blades: Front OEM Aero wiper blades (set of 2).
    • Repair Manual: DVD.
    Engine Oil (1 x 5 liter bottles)
    • Liqui Moly Synthoil Premium 5W40 Engine Oil (5 Liter) (Liqui Moly, LM2041)
    • Pento High Performance II 5W40 Engine Oil (5 Liter) (Pentosin)
    • Total Quartz 9000 Energy 5W40 Engine Oil (5 Quart) (Total)
    • Motul 8100 X-cess 5W40 Engine Oil (5 Liter) (Motul)
    • Motul Specific 505.01 502.00 505.00 5W40 Engine Oil (5 Liter) (Motul)
    Engine Oil (2 x 1 liter bottles, choose same as above)*
    • Liqui Moly Synthoil Premium 5W40 Engine Oil (1 Liter) (Liqui Moly, LM2040)
    • Pento High Performance II 5W40 Engine Oil (1 Liter) (Pentosin)
    • Total Quartz 9000 Energy 5W40 Engine Oil (1 Quart) (Total)
    • Motul 8100 X-cess 5W40 Engine Oil (1 Liter) (Motul)
    • Motul Specific 505.01 502.00 505.00 5W40 Engine Oil (1 Liter) (Motul)
    Oil Filter
    • Oil Filter (3.2L, 3.0T) (Mann, 06E115562A)
    Oil Drain Plug
    • 1 x Oil Drain Plug (14mm) (Genuine Audi VW, N0160276)
    • 1 x Oil Drain Plug Gasket (14mm) (Genuine Audi VW, N0138157)
    • 1 x Magnetic Oil Drain Plug Kit (14mm, 10 Seal Washers) (Metalnerd, N90813202)
    Dipstick
    • Oil Dipstick (3.0T, 3.2L) (Genuine Audi VW, 06E115611H)
    Engine Cleaner
    • Liqui Moly Pro-Line Engine Flush (500 ml) (Liqui Moly, LM2037)
    • Motul Engine Clean Auto (300 ml) (Motul)
    Air Filter
    • Air Filter (Mann, 8K0133843)
    • K&N Performance Air Filter (KN Engineering, 8K0133843)
    Cabin Filter
    • Cabin Filter (Charcoal) (Mann, 8K0819439B)
    Fuel Filter
    • Fuel Filter +$60.95 (Genuine Audi VW, 8K0201511A)
    Spark Plugs
    • 6 x Spark Plug (Genuine Audi VW, 101905631G)
    Wiper Blades
    • 1 x Wiper Blade Set (Aero) (Genuine Audi VW, 8K1998002A)
    Repair Manual
    • 1 x Audi A4/A5/S5 B8 2008+ Repair Manual on DVD (Bentley Publishers, 9780837615547)
    If you own an Audi or VW you need a powerful tool that will help keep your vehicle on the road. Ross-Tech's VCDS helps diagnose real problems instead of swapping out costly parts. With features found only on dealer level factory tools, VCDS surpasses the performance of aftermarket diagnostic tools and rivals factory tools for a fraction of the cost. Always know exactly how your vehicle is running instead of paying someone else to diagnose the problems, usually leaving you with a huge repair bill.
    With Ross-Tech's VCDS you can:
    • Gain full access to all systems in cars from 1990 through the current model year
    • Scan for and clear DTC's with 13,000 fault codes decoded into plain text
    • Alter settings normally accessible only to dealerships
    • Code replacement modules and select options
    • View and log live date and much more!
    EuropaParts.com is an official distributor of Ross-Tech's VAG-COM Diagnostic Systems for Audi, Volkswagen, Seat, and Skoda vehicles. We ship worldwide!
    We have all Ross-Tech products in stock... CLICK HERE to view our entire Ross-Tech catalog which includes;
    • Diagnostic Tools
    • Professional Kits
    • Extension Cables
    • Adapters
    VAG-COM Diagnostic Tool with HEX-USB+CAN Interface
    Essential for any Audi / Volkswagen owner, this VAG-COM cable and software will allow you to perform the same advanced computer diagnostics as your Authorized dealer. In addition, you will be able to perform various country-specific modifications to your car (removing seat belt chime, enabling gauge test/needle sweep, enabling lap timer, operating windows and sunroof with remote, and much more).
    • Works with all diagnostic-capable Audi / Volkswagen cars from 1990 through the current model year.
    • Acts as a "dongle" - activation for the full-function version of VCDS software is built-in!
    • Use VCDS software on any suitable PC with an available USB port - no activation codes required.
    • Bi-Color (red/green) status/activity LED.
    • 12-month guarantee against defects.
    • Visit Ross-Tech's HEX-USB+CAN technical page for more information.
    FREE insured ground shipping within the 48 contiguous United States. Inexpensive next day and international shipping is available at checkout.
    Turn your PC into a powerful diagnostic tool!
    VAG-COM Diagnostic Tool with Micro-CAN Interface
    This Micro-CAN cable is a low-cost interface is compatible only with the Audi A3 (8P chassis), Audi TT MK2 (8J chassis), and VW Golf MkV-based cars sold in the North American market. See Ross-Tech's Micro-CAN technical page for a list of compatible models.
    • Acts as a "dongle". No "Software Activation" required! When used with this interface, VAG-COM is always fully-functional on any PC that meets our requirements.
    • USB connector plugs into most modern laptops! (USB 1.1 or 2.0)
    • 12 month guarantee against defects
    • For more details and a list of supported models, see Ross-Tech's Micro-CAN technical page.
    VAG-COM Mods
    Your Audi has a few secrets that can be activated with this tool. For example,
    • Removing Seatbelt Chime
    • Enabling Gauge Test/Needle Sweep
    • Enabling Lap Timer
    • Operating Windows and Sunroof with Remote
    • And much more...
    VAG-COM Diagnostic System (Professional Kit, USB Interface)
    Everything a busy shop needs to turn a PC into powerful diagnostic tools for VW, Audi, Seat, or Skoda automobiles. This VAG-COM Professional Kit gives the technician a handy carrying case with all the items needed including:
    • One (1) x HEX-USB+CAN Professional Interfaces
    • One (1) x Extension cables
    • VAS 5051/2 "2x2" Adapter for Older Cars
    • VCDS Software on CD-ROM
    • A Full Color Printed Manual
    • Live Telephone Technical Support for One Year!
    VAG-COM Diagnostic System (2-Tech Professional Kit, USB Interface)
    Everything a busy shop needs to turn two PC's into powerful diagnostic tools for VW, Audi, Seat, or Skoda automobiles. This 2-Tech Professional Kit gives the technician a handy carrying case with all the items needed including:
    • Two (2) x HEX-USB+CAN Professional Interfaces
    • Two (2) x Extension cables
    For the shop that specializes in VW/Audi work, this Pro kit equips 2 techs and 2 computers!
    VAG-COM Diagnostic System (Ultra Professional Kit, USB Interface)
    This VCDS Ultra Professional Kit is a turn-key factory-level diagnostic system for cars made by the VW/Audi group. VCDS software running on the included Netbook PC provides full support for vehicles from 1990 through the current model year. VCDS will access all diagnostic capable control modules with the ability to read and clear fault codes, adapt modules, perform basic settings, and read/log/graph live data.
    Ross-Tech offers these small powerful, full featured Netbook computers with a 10 inch LCD display, a 160Gbyte or larger rotating hard disk drive, and wireless connectivity for 802.11b/g/n networks.
    Free updates of the VCDS software are available via the Internet to keep the tool current.
    The VCDS Ultra Pro-Kit gives independent shops the ability to perform diagnostics at a level comparable to factory equipped dealerships at a price/performance ratio unmatched by any other product on the market. Let VCDS help put money in your pocket!
    Ross-Tech will provide a Netbook PC from a major manufacturer such as ASUS, Dell or Samsung. The exact model of PC will be dependent upon availability at the time of order.
    • Netbook PC running Windows 7
    • VCDS pre-installed, ready to run
    • OpenOffice Spreadsheet by Sun pre-installed
    • Recovery flash drive
    • HEX-USB+CAN Professional Interface
    • VAS 5051 2x2 adapter for pre-1995 model years
    • 16' USB extension cable
    • VCDS manual
    • Netbook PC manuals
    • Power adapter for the Netbook PC
    • Full manufacturer's warranty for the Netbook PC
    • Carrying/Storage case
    This adapter connects between the 2x2 port in older vehicles (pre-OBDII; pre-1996) to the OBDII connector used for current generation diagnostic tools. Use this adapter in conjunction with the VAG-COM cable to run diagnostics on older Audi and VW's.
    VAG-COM USB 2.0 Active Extension Cable (16 feet, 5 meters)
    This VAG-COM USB 2.0 Active Extension Cable is used to extend the reach of a Ross-Tech USB Interface from the computer to the vehicle. It connects between the USB port on the computer to the USB plug on the interface. The length of this cable is 16 feet or 5 meters.
    It is constructed of high quality signal cable and active repeater electronics which boost the USB signal for maximum reliability and performance over extended distances.
    Up to two (2) of these cables can be plugged together to extend the reach of a Ross-Tech interface to a maximum of 38 feet (12m). Ross-Tech has tested and certified this length of extension. Lengths beyond 38 feet on the USB cables are neither recommended nor supported.
    Please Note: these are the only USB extension cables Ross-Tech will support at this time. They have tested them extensively and found them to perform to their standards.
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    New forum sponsor? Great first post to cover all the basic wants/needs
    Website looks great! Welcome :)
    Ignorance is bliss.
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by Phrost View Post
    Thanks we are indeed the forum sponsor.
    Established Member Two Rings S4MAXSPEED's Avatar
    Mar 01 2011
    2018 Audi SQ5
    SE Aurora, CO
    Do you have any full car shots of those Stasis Wheels? Also are they available in any other colors?
    Gone:
    04 R32 BMP -Turbo'd & Blacked Out!
    04 S4-Miltek exh., sways, Strat Intake&S.S.
    11 S4 Ibis 6MT- EPL Stage 2 and more
    '13 Q5 3.0- EPL Stage 2 and more
    '14 H-D Breakout- BX Custom
    Current:
    20 Tesla Performance Model 3
    18 SQ5- DIY Blackout, more mods soon..
    Veteran Member Three Rings vincent9993's Avatar
    Apr 02 2007
    Dune Buggy
    St-Leonard
    Nice post and webstore, have you thought of your neighbour north of the border? Any shipping consideration and/or promotion for us?
    Thanks
    Now:2015 Phantom Black / Magma Red S4 Prem, MT6, ADS, Nav, Carbon trim
    - WeatherTech DigitalFit mats
    - Winter wheesl: 18x8 RS4 reps 245/40R18 Gislaved NordFrost
    I have Vag-Com
    Past: B5 A4 2.8, B6 A4 3.0, B7 A4 3.2, B8 S4
    Feb 24 2011
    Houston
    Quote Originally Posted by S4MAXSPEED View Post
    +1
    Mar 01 2010
    BC
    how much for full line of Hawk Performance Brake Pads? are they ceramic brake pads??
    2010 S4 6MT
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by Un1k View Post
    Front HPS 123.25
    Rear HPS 66.94
    We also have the Hawk Ceramics
    Front Ceramics 128.56
    Rear Ceramics 73.31
    Aug 22 2010
    Piscataway, NJ
    I will see if I can find some
    Veteran Member Four Rings phillips2024's Avatar
    Mar 03 2011
    Southern NH
    Good stuff. I just picked up the ross-tech from you guys
    2017 Audi S8+ | 2021 Audi RSQ8 | 2021 Cadillac Escalade Sport Platinum | 2007 Porsche Turbo
    2021 Sea Ray 350 SLX | 2020 Polaris Ranger Crew XP1000 | 2022 Polaris Indy VR1 850/650
    Senior Member Three Rings SM_ATL's Avatar
    Jan 25 2011
    2013 Porsche 991S, 2012 GTI, 2014 Infiniti QX60, 1995 E36 M3
    Atlanta
    Quote Originally Posted by Jim@EuropaParts View Post
    Is there any third party data about performance improvements brought by Hawk brake pads (stopping distance, repeated stops, fading, etc.).
    Do the Ceramics perform better than the HPS or is it mostly about generating less dust? Is it true that ceramics do not perform as well as classical 'steel' pads until they get at the right temperature?
    In brief, is it worth replacing OEM parts that are not worn out yet or should I simply consider Hawks pads as a minor upgrade when the time comes to replace the pads...? These are naive questions calling for a honest answer
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    Quote Originally Posted by vincent9993 View Post
    Thanks
    We ship to Canada frequently, and while we can't offer free shipping on most things, we work as hard as we can to make the process quick, efficient, and painless as possible.
    Quote Originally Posted by SM_ATL View Post
    In my experience (on other cars), the HPS are a good replacement for stock pads which provide less dust and will give you a bit of increased braking performance. The Ceramics are a step up, and would be something to consider replacing your pads with now, before they're fully worn out. The Ceramics do perform better than the HPS, although they dust a bit more (maybe on a OEM-dust level, not more than that). The Ceramics also perform well from the start...in my experience, you don't need to build heat into them before you notice a difference. Hope this helps!
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    How do the Hawk pads compare to the EBC brake pads? I'm looking to replace my OEM pads soon, with something that will minimize brake dust while also still improving performance. Thanks in advance!
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Senior Member Three Rings Can_I_Haz?'s Avatar
    Apr 19 2011
    2011 S4; 89 Mustang 5.0 Notchback
    Los Angeles, CA
    I purchased a B8 S4 last week and its horribly quiet and the mod bug is sarting.
    I have 2 questions regarding the exhaust.
    1) What is the difference between high and low rpm resonator catback? This is something I have never heard of and I am by no means new to hopping up cars. I hate making assumptions so clue me in.
    2) What is the typical WHP gain with a cat back exhaust on a B8 S4 mine is a DSG if it matters. Ive had cars that used different parts for different trannies due to clearance issues.
    What I am looking for is a nice quiet exhaust that is loud enough for me to know when to shift. This car is so quiet, I find myself staring at the rpm guage to see when to shift up or down. Thats ok for drag racing but very dangerous in the twisties. A little extra HP would be nice. Definatly dont want something that announces my arrival when I come home from work if you catch my drift.
    Dec 22 2009
    Piscataway, NJ
    Quote Originally Posted by b6bydesign04 View Post
    The HPS will reduce the dust over OEM (by quite a bit) and give you a nice performance bump. I haven't personally used EBC pads, so I can't comment on that. If you're looking for a better-than-OEM replacement, I think you'll be happy.
    Quote Originally Posted by Can_I_Haz? View Post
    The high-RPM is designed with the manual transmission in mind (in that you would be keeping the RPM's higher), and the low-RPM is designed for the DSG (in that the trans would keep the RPM's lower). However, the resonator pieces are interchangeable, so if you found the low's to be too quiet, you could swap in the high units. The WHP gains are subjective. For one, the DSG cars have more drivetrain loss over the manual cars. Second, the dyno/weather/etc conditions give differing numbers. There might be a thread on here with some figures, but I don't want to misquote anything.
    Active Member One Ring pmbalt's Avatar
    Jan 21 2011
    2011 GTI, 2010 Silverado
    Olympia/WA/PNW
    how much for the Stasis S4 tune?
    Registered Member One Ring flake533's Avatar
    May 12 2011
    Portsmouth/RI
    Considering the VAS-COM purchase but unsure of the complexity of mods with it. How easy/user friendly is it? First Audi and very wary of jacking it up....thoughts?
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Quote Originally Posted by flake533 View Post
    Not that difficult, if you use DavidB8's site http://www.audienthusiasts.com/ it walks you through things. It looks complex and is hard to understand at first, but it's more of a "once you see and use it you understand it better" kind of thing. Understanding basic binary and hex code is a plus, but by NO means required. If you are not sure on something just post a thread asking. DavidB8 and RLarsen over on the B8A4 forums are masters of VCDS and always glad to answer a question.
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Registered User Four Rings primetime's Avatar
    Mar 05 2010
    5 four ring cars and 1 P-car...
    Anyone have any information on our plugs? I plan on pulling mine friday and having a look at them... will probably replace with a copper and lower heat range...
    Dec 22 2009
    Piscataway, NJ
    Very easy. There's a lot of information on the forum how to use it, and Ross-Tech's website has a very comprehensive 100-page PDF instruction manual. But its fairly intuitive, and a lot of guys on the various forums have done step-by-step tutiorials on how to take care of the most common stuff. We have them in stock with free shipping (Ross-Tech VAG-COM)
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    do you guys have any upcoming sales with discount codes? I'm looking to pick up some stuff and i missed that last sale from waterfest?
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by windyctyaudi View Post
    Hey! PM me what you need, we can work something out.
    Aug 22 2010
    Piscataway, NJ
    Just updated the original post... check it out guys!
    Active Member Two Rings AverageJones's Avatar
    Feb 06 2012
    Stuttgart Germany
    Quote Originally Posted by pmbalt View Post
    +1
    Sprint Blue | DSG | B&O | Black and Silver Silk Nappa | Brushed Aluminum Inlays | 255/35/19 Titanium Sport Package | Sport Rear Diff. | Roc-Euro Intake | APR Stage II+
    Veteran Member Four Rings svander's Avatar
    Mar 16 2011
    '11 S4
    Seattle Metro Area
    All images on this thread are broken FYI
    Jan 11 2012
    Can I please get a price shipped to Toronto Canada l6c2b4 for the vag com and supercharged badges?
    Senior Member Two Rings mikeh14's Avatar
    Apr 30 2012
    San Diego, CA
    Just wanted to post a quick note... I just ordered a dipstick, and within 20 minutes of ordering, I had an email confirmation that it had been shipped, with a tracking number. Very fast!
    2012 Phantom Black S4: S-Tronic - Sports Diff | AccuAir B8 Sport Kit | AWE Intake | AWE Exhaust | GIAC Stage 2 v2 | GIAC DSG Tune | AWE Pulley | AG M580 20x10 Brushed Candy Apple Red | StopTech 380mm BBK | Deval Carbon Diffuser | RS Grill | Red supercharged badges | 15% tint
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by mikeh14 View Post
    We try to do our best!
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Just got my filler plate, dipstick, and locking lugnuts. Very easy transaction. Thanks again.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by dparm View Post
    No, thank you!
    Jul 08 2011
    Escondido, CA
    Do you give board members a discount? I have bought a few items from you and really want to get the Sun Shield (A4/S4 B8) for my car. Do you have it in stock and if so what would be the board member price?
    Thank you,
    Andy
    Active Member One Ring AudiSportKUL's Avatar
    May 25 2014
    Kuala Lumpur
    Repair Manual
    As per above item. How much is the repair manual shipped via UPS to Shah Alam, Malaysia. Zip Code 40150.
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by AudiSportKUL View Post
    Repair Manual
    Good morning... we use UPS/FedEx/USPS so the prices will vary. If you add the product to your cart it will give you all shipping options + pricing.
    May 25 2014
    Kuala Lumpur
    noted with thanks!!
    Aug 22 2010
    Piscataway, NJ
    noted with thanks!!
    Anytime!
    Apr 24 2013
    Canastota, NY
    Question about the fuel filter, I bought the ultimate kit from you guys but didn't see it come with the gaskets and seals you need to replace when you do the fuel filter. Should it have been included?
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by MaXaZoR View Post
    No... the filter is 1 part number and does not include and seals or gaskets.
    Established Member Two Rings WeeKenny's Avatar
    Jan 05 2015
    Scotland
    Does the repair manual cover everything inc full engine strip?
    All torque settings etc for the whole car?
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by WeeKenny View Post
    Torque settings yes, I don't think there is an in depth guide on how to do a full engine strip but I'm sure it will help.
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by Hugh@EuropaParts View Post
    I'm not sure the guide has torque specs for every fastener in the car as per WeeKenny's question, are you sure?
    I could be wrong but every guide I've had there are a few fasteners I needed to Google or talk to a shop.
