Results 1 to 12 of 12
    Veteran Member Three Rings Grip99's Avatar
    Feb 15 2011
    ny, ny
    Adding a resonator to my 3 inch diameter exhaust
    I have a 4inch DP leading into a 3inch exhaust after the flex joint. The exhaust has one resonator that then leads into a magnaflow muffler to finish it off. I have about 2 feet of straight pipe before the first resonator. I would like to add one more resonator in the 2 feet of straight pipe to quiet the car down due to a ticket for "unreasonable noise" by the NYPD. Can anyone recommend a company that sells resonators that would help in this situation? I bought this custom exhaust from someone i dont have the number to anymore and i cant figure out the name of the one i have.
    Im not sure if im in the right forum for this question but any help would be cool.
    Thanks
    Pete
    Veteran Member Three Rings NoTec's Avatar
    Dec 24 2007
    Ducati is KING!!!
    Resonators typically change the tone of the exhaust or correct/help/eliminate rasp. Overall volume is usually unaffected. If volume is affected, power is also affected. Louvered resonators will be your best bet without robbing too much power. Me personally, I'd be looking into adding a second muffler because it'll likely cost the same and help reduce the noise output substantially.
    Senior Member Two Rings colombian301's Avatar
    Jun 05 2010
    DMV, Maryland
    What size and what kind is your original resonator that you have on it right now??
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    try using a magnaflow 11219. i believe that is a straight through, stainless, muffler. quieted my 3 inch exhaust down alot!
    Feb 15 2011
    ny, ny
    Im not sure who makes the resonator that i have now, but i do know its 4 inch diameter resonator with 3 inch inlet/outlet...im going to check out the magnaflow 11219 that MOtown recommended as well as the Louvered resonators that notec metioned.
    Any other ideas would be great
    Thanks for your help guys
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    I have brand new magnaflow 3" / 3" out inline muffler that i will sell you for dirt cheap... I just sold my car and no longer need this! i literally bought it a week ago... magnaflow 12219 pm me if you are interested
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
    Dec 24 2007
    Ducati is KING!!!
    I'd seriously consider purchasing a second muffler than adding a resonator.
    Senior Member Two Rings xattica's Avatar
    Dec 12 2009
    12 Lotus Evora, 19 Countryman PHEV, 07 Cooper S
    San Juan, PR
    Any difference of adding a 2nd muffler vs adding a resonator?
    2000 Audi TT 180 * 1996 VW Cabrio AT * 2000 A4 1.8T Quattro Avant AT Stage 3 (sold)
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    4" DP?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 05 2007
    Resonator and muffler serve the same purpose (changing exhaust note), but differently. A muffler muffles (supresses) the exhaust, and the resonator resonates (produce or be filled with a deep, full, reverberating sound) it. As perplexing as that sounds, that is about the jest of it.
    Dec 12 2009
    San Juan, PR
    Well yesterday I installed a custom 2.5" from downpipe to a borla muffler. I used a glasspack resonator but I think is too loud for me. Im thinking about change the resonator to a muffler or adding an additional resonator. I really dont know if adding a 2nd resonator will decreased the flow more than just using a muffler as a resonator.
    Dec 05 2007
    If using a proper resonator for the sound quality you want (they are not all built the same), along with proper muffler for sound quality you want, place in proper position, then you would not have an issue. Also, quality steel and thickness plays a role when it comes to drone.
