Results 1 to 40 of 43
    Veteran Member Three Rings E.Anderson's Avatar
    Jun 23 2010
    Oswego, IL
    For those of you who are staggered
    What tire size are you running? I'm thinking about getting 19x8.5 and 9.5 rear with
    225/35 up front and 235/45 rear
    Will that size difference be small enough that it will run fine with quattro?
    Veteran Member Three Rings schizzy's Avatar
    Jun 29 2009
    2008 SRT4
    New Jersey
    it will be fine running staggered set up
    Ocean Blue b7 a4: -Revo stage II -apr/BB exhaust w/ tp -eibach/kw coil overs -19" sportec mono 10 -forge dv -rs4 swaybar -rs style grill -euro jet pcv fix -apr snub mount -custom intake -m3 spoiler -35% tints...... TOTALED BY DUMP TRUCK
    Current: 1990 vw
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    I was thinking about doing the same set up but am not sure on the tire sizes to not ruin anything or how the off set sizes work. I am thinking a VMR wheel like the 701 with 9.5 in the back to have that deep concave look to it.
    Established Member Three Rings b7kevin's Avatar
    Jan 04 2011
    East Haddam, CT
    My understanding is that running staggered is fine. What effects the AWD system is when you have bigger tires, so in this situation having 35 and 45 would effect the system. Width doesn't matter, its all in the height.
    2006 A4 Brilliant Black 6MT
    - Revo Stage 2+ - AWE HPFP - ST Coils - K&N - 034 TIP - Newsouth Vent Gauge - Neuspeed Snub - OEM DV Upgrade - E-Code test pipe - AWE Quad tip - s4 rear valance - de-badged - vag'd -
    -Wake up an address the biggest issue of our freedom. National DEBT.
    Jun 23 2010
    Oswego, IL
    Quote Originally Posted by b7kevin View Post
    Thats what my understanding was, so I would need a 225/45 up front?
    Jun 19 2009
    17 ram 1500
    Hartford CT
    So I am on my stock TI wheels now with ET 32. no if I go with a ET 40 does that mean the center of the wheel is set back more allowing for more lip or concave?
    Jun 23 2010
    Oswego, IL
    It's the diameter from center of the wheel to edge of the tire i beleive. Offset has nothing to do with it. So running 19's in back and 18's up front will not work.
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by E.Anderson View Post
    I am not running 18's up front and 19's in the back. I am thinking 18x8.5 ET 35 front and 18x9.5 rears. Just a bigger ET of 45 (i think or 40) in the rears. I have 8mm spacers in front and 10 in rear
    Jun 23 2010
    Oswego, IL
    I know, It was just an example. If your tires are the same size 235/45/18 and 225/45/18 (the sidewall height 45 being the magic number or 35 if you wanted) then i'm thinking you're fine.
    Hopefully somebody with more knowledge/experience can chime in on this
    Jan 04 2011
    East Haddam, CT
    ^^^Thats fine just keep the sizes of the tires similar the front number 225,235,245..etc denotes the width of the tire in mm. The center number 35,45...etc is the height of the tire. I would just rock them both with say a 45 or whatever your taste is. I mean your correct its a marginal difference of mm however anything that contribute to premature part failures isn't for. I'd play it safe.
    Jun 19 2009
    17 ram 1500
    Hartford CT
    So I want 18's because I want to use the same tire so I don't have to buy new ones 235x40x18 front and rear tires . I want to go with 18x8.5 fronts with ET 35 and 18x9.5 ET 45 rears. There will be a little stretch in the rears just want to make sure this would be safe including the ET of 45 in the rear tires with running 10 mm spacer in the rear to clear everything.
    Veteran Member Three Rings audib7maniac's Avatar
    Oct 23 2009
    New York, NY
    225/35 runs these all around, u need to have the name size tire all around if you have quattro.
    -Rob
    B5 S4:Tial 605/Ard bipipes/Snow meth stage 3/h beam rods/wagner smic/044 Fuel Pump/Stern motor & tranny mounts/Apikol rear diff mount/034 rear diff crossmember control arms snub mount/JHM SS BBK f&r/AWE DTS/neuspeed rear sway/034 f&r sway bar end links/ST coils(airlift coming soon)/custom AMS 4" dp 3"exhaust w/ Borla muffler/RS4 Grille/VEI Digital Boost Gauge/J-Fonz Base Tune
    AMS AUTOWERKS FTW!
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by audib7maniac View Post
    -Rob
    Boston haha
    Veteran Member Four Rings Kubus's Avatar
    Aug 10 2009
    2017 Audi S3
    Montreal, QC
    So much wrong in this thread. 35 or 45 is not tire height. It is a percentage of the width
    So if you have 235 width and a 35 profile, it will be 35 percent of the 235. You need to match it up so the rolling diameter will be the same
    Taking 235 with a 35 profile and a 245 with a 35 profile will not yield the same rolling diameter.
    Stop posting nonsense.
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    way too much bad info in here. a 235/45/19 would not even fit. The rear et is higher because the wheels are 9.5" wide. Your stock TI wheels are 18x8 et32. Look up a tire calculator and make sure that the 2 tire sizes are within 3% of the tire diameter to keep the diffs happy.
    Veteran Member Four Rings GarrettReid's Avatar
    Oct 26 2010
    Orlando
    /end thread
    start over.
    2014 Audi SQ5 Black w/Lava Gray and Magma Red
    SOLD: 2007 Land Rover Range Rover Sport Supercharged Black w/Black
    IG: GarrettReid
    Senior Member Three Rings Boxmods360's Avatar
    Jan 14 2010
    refrigerator, tools, Audi
    Florida
    I am running:
    Front 235/35/19 8.5
    Back 265/30/19 9.5
    2008 A4 2.0T Quartz Grey - Vag-com - TSW Croft 19" 8.5F 9.5B - 10" Alpine Type R sub w/ PDX-M6 amp in a custom made fiberglass box - AUX mod - smoked reflectors - Plasti dip grill & window trim- 5000K Fogs - Red LED interior - Homemade Carbon Fiber trim - 640 mod - REVO ST1 - APR carbonio - OEM Xenon headlights w/ Phil's LED w/ 6000k Headlights
    My CF trim <-click-
    Oct 23 2009
    New York, NY
    Quote Originally Posted by groundround View Post
    Boston haha
    Boston Will never be as great in NYC sorry to burst your bubble haha
    Quote Originally Posted by Kubus View Post
    x2. This is correct listen to the man lol
    AMS AUTOWERKS FTW!
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    wow, what a clusterfuck of fuckups here...
    start over please, this thread made my eyes bleed (no i didnt read it all)
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Three Rings RiCHV382's Avatar
    Dec 22 2007
    Palm Beach, FL
    Boston haha
    Cape cod!
    New: 2018 A4 Prestige / Black optics / moonlight blue /
    toatled: 2014 A4 Prestige / Black optics / monsoon gray / ecodes / Accuair elevel / Airlift / 20x10 Fifteen52 Alexi wheels
    sold: 2008 A4 s-line quartz gray / KW V2 / Bentley Continentals
    sold: 1992 audi 100CS quattro avant
    Jun 19 2009
    17 ram 1500
    Hartford CT
    [QUOTE=audib7maniac;6245185]Boston Will never be as great in NYC sorry to burst your bubble haha
    What the streets wont ever be as fucked up as yours!! prob not haha but the one I live on is about as bad as you can get.
    All I was saying is that I am interested in going staggered VMR V01 I believe. I wanted the 18 or 19x 8.5 front and 9.5 rear. What tire size would i need to get but want to go no less than 40 on the thickness EXAMPLE 245/40 to the rears
    Aug 31 2007
    Miami
    19s with a 40 series sidewall will not fit the car... end of story.
    IG | @fukn_fafa
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by Geoffafa View Post
    Ok and this is the kind of thing I am trying to find out.
    Why wont it fit?
    What will I have to run?
    If your eyes are bleeding then don't open this tread it's that simple. I am trying to learn here. If your the wizard then fuckin teach, if not then go smoke a butt and calm down.
    Senior Member Three Rings bartles's Avatar
    Apr 11 2010
    Denver/ Chicago
    Quote Originally Posted by chrislane31 View Post
    How does one calculate this %?
    Gone to the darkside...
    Mar 24 2007
    Google tire calculator. I think miata.net has one or get the tire overall diameter and divide it be the other tire size and see what the percent difference is.
    Jun 19 2009
    17 ram 1500
    Hartford CT
    confusing, do i enter what i want the front to be and the rear to be and then what?
    Senior Member Two Rings rowyourown's Avatar
    Jan 13 2010
    New York
    also, 1010tire.com has a tire calculator
    http://www.1010tires.com/TireSizeCal...?action=submit
    Eibach springs, Bilstein sport shocks, GIAC, 034 HFC, RS4 rear sway, V710s, Hankook Ventus V12 235/40/18
    Senior Member Two Rings audi1234's Avatar
    Nov 18 2008
    B8 S5
    LI NY
    Quote Originally Posted by Boxmods360 View Post
    I am running:
    Front 235/35/19 8.5
    Back 265/30/19 9.5
    x2
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    tire width divided by 25.4 mm per inch times profile (0.35) times 2 (two sidewall heights per diameter) plus 19 inch wheel diameter equals the overall diameter.
    [(235 mm/25.4) x 0.35 x 2] + 19 = 25.48 inches
    [(265 mm/25.4) x 0.30 x 2] + 19 = 25.26 inches
    Conclusion: the diameters are less than 1% different so the differential will never see the difference.
    From the top of the thread:
    front - 225 by 35 by 19: diameter = 25.20 inches
    rear - 235 by 45 by 19: diameter = 27.33 inches Conclusion: 8.4% difference. This will mess up a diffy for sure.
    Oct 23 2009
    New York, NY
    I wud just stay with the same size tire all around just to be safe. And you want tire stretch because you will rub like crazy
    AMS AUTOWERKS FTW!
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Just trying to get all the right info before I make a purchase:
    Wheels are -
    Front: 19x8.5 offset of 32mm
    Rear: 19x9.5 offset of 35mm
    Is anything under 1% diameter difference legit? I'm looking at 235/35R19 in the front and 265/30R19 in the rear which is a 0.87% difference. But moving to a 275/30R19 is only a 0.08% difference. I used http://www.1010tires.com/TireSizeCalculator.asp And I'm AWD. Thank you for any assistance.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    -Rob
    Is that a fact? There is so many thread on wheels, but everybody giving their own opinion and you still dont know what is good at the end.
    So, can a Quattro be staggered, wider wheels at the back? If yes what size usualy people go, 18x8.5 and 9.5 or bigger?
    thanx
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by Mister W View Post
    thanx
    No. It's not a fact. It's the opposite of that - it's just plain wrong. It's been stated several times in this thread already, as well as dozens of others on the subject:
    It's fine to run a staggered setup with Quattro as long as the ROLLING DIAMETER of the two tire sizes are within 3% of each other.
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    FTWL...droppin knowlwdge :)
    Jan 29 2011
    Otterburn Park, QC
    Thank you for clearing it up. And btw , what size would you recommend in 18" , staggered wheels and tires, offset flush as possible without spacers?
    Aug 18 2009
    A Unicorn
    Portland, OR
    That would depend on the width of the wheels. ET is relative to width. For instance ET 35 on an 8 inch wheel is not the same as ET 35 on a 10 inch wheel. Post your question with specifics about the wheels you're interested in in the FTWLTBDWICTW thread in the chatterbox.
    Jun 23 2010
    Oswego, IL
    Fronts are 19x8.5 rears 19x9.5. with that much stretch 225/35 and 235/45 should be less than 8%...right?
    Aug 18 2009
    A Unicorn
    Portland, OR
    Yes, that's under 8%. But for Quattro you need to be under 3%
    Jun 23 2010
    Oswego, IL
    well then, i guess my only option is new tires
    Sep 30 2009
    Indiana
    E.Anderson: Read post #29 in this thread. I directly answered your question and posted the formula for determining overall diameter. Allow me to quote myself - "an 8% difference in diameter will mess up your diffy for sure!". If you change the tire profile between the front and rear you must change the wheel diameter to compensate.
