hey guys got nothing to do today (just spent 2 hours finding specs for 2.7t and 3.0t engines) so i though i'd start thread on a comparison of these motors. looking through the specs the 2.7t seems like the stronger motor (minus cast con rods) for high hp builds, although the 3.0t does have direct injection variabable valve timing on both intake and exhaust side. supercharger vs turbo? blah blah blah..... let me know what you think
3.0 tsfi - engine specs
- 3.0 supercharged gasoline engine with fsi direct injection
- four valves per cylinder
- 2-stage variable intake manifold
- Bore - 3.33 in (84.5mm)
- Stroke- 3.50 in (89mm)
- compression ratio - 10.3:1
- fuel requirment - 91 oct
- horsepower - 333hp @ 5500-7000
- max torque - 325lbs @ 2900-5300
- cylinder block - aluminum
- cylinder head - aluminum
- valvetrain - DOHC with hydraulic adjustment
- fuel injection - electronic engine management, drive by wire, fsi direct injection
- crankshaft - forged steel *edit*
- pistons - forged aluminum
- displacment -2998cc (182.9 cu in)
- dry weight - 417lbs
2.7t engine specs
- 2.7 Liters
- 6 Cylenders
- 5 Valves per Liter
- Bore: 3.19 in. (81 mm)
- Stroke: 3.40 in. (86.4 mm)
- Displacement: 163 cu. in. (2671 cc)
- Compression Ratio: 9.3:1
- Horsepower (SAE Net): 250 @ 5800 RPM
- Torque: 258 ft. lbs.@ 1850 RPM
- Cylinder block: Cast Iron
- Crankshaft: Forged Steel, 4 main bearings
- Cylinder head: Aluminum alloy
- Valve Train: DOHC, belt driven, hydraulic lifters / variable intake valve timing and variable geometry composite intake manifold
- Firing Order: 1-4-3-6-2-5
- Cooling System: Water-cooled, thermostatically controlled radiator fan
- dry weight - 489lbs with turbos
